i have just said this situation in games but some user have offende me and call me "troll" or "noob" because i see this ghosting in a youtube movie
And now the noobs are they.
Ridicolous !![]()
Ridicolous !![]()
http://www.lesnumeriques.com/dell-u2412m-p240_11538_88.html
NO GAMES sorry
[*IMG]http://img1.lesnumeriques.com/produits/88/11538/U2412M-reverse-ghosting.jpg[/IMG]
GoldenTiger said:Lol, right..... not!
Yes, and if you were a troll and noob back then, nothing has changed.
A cherry-picked photo from a bottom-tier review site isn't convincing anyone. These are the same "reviewers" who said the Acer GD245HQ/GD235HZ was such a great screen and neglected to mention a huge problem with the monitor: There are non-defeatable sharpening halos around all text on colored backgrounds.
Nice reviews.
You still don't know what you are talking about, and you haven't spent any time learning either, so back to the ignore list for you.
Go buy their top pick the AOC E2795Vh 27" MVA panel that apparently has better pixel response than the U2412M. There's your next screen.
my obsession to ips responsive time is there because i play and i wanted buy it.
Youtube videos can introduce any number of small artifacts, from cameras or compression. Your assertion that a youtube video could be used for what you're trying to use it for is pretty ridiculous. Crappy cameras have weird ccd scan rates that could introduce tearing easily, flash video compression can introduce plenty of artifacts. It's simply not a good set of data to draw conclusions from.
That said, anyone have any info on the deal others were getting to get this monitor at $320? Any information is welcome, it seems the posters who were talking about it are not replying to my PMs. Any help appreciated!![]()
You could always try calling Dell small business on your own and nagging them a little bit. If it's worth a few bucks on the price why not?
That is what I did on Friday. It took a little negotiating but they gave me that price when I said I would buy two right then.
Funkdancer, have your monitors improved as well?
edit: spoke too soon. After 2hrs power on time the slight bleed has begun to return. Seems to be related to temperature maybe?
If you look hard enough for something you are sure to find it.
I have been gaming on this monitor for countless hours now and there are no issues with gaming. Even though I usually have a keen eye for this sort of thing, I never notice any ghosting or trailing, and I am sure I would have to record a video to find it. I play FPS, RTS, MMO, and simulation flying / racing games.
I have a 2407, 2408 and 2410 and hte u2412 all next to eachother right now powered off 2 GTX 580's and the only thing that is apparent between any of them when gaming is the wide gamut of the 2408 and 2410. The colors look different, and thats it.
The 2412 has a slightly faster response time which you can notice when you switch back and forth between monitors that makes it BETTER for gaming.
The AOC is actually faster than the 2412 according to PRAD like senna says. I remember seeing a few high response time values with certain transitions in PRAD's review of the 2412 but I will have to double check. The 2412 being slow makes sense because the rest of this years LED backlit IPS panels have had nearly twice as slow response times (LG IPS2361V vs Dell U2311H) and there have been some major quality differences between the same models.
Compare the important information in DV's reviews with PRAD's and they are usually very similar...
OK, just bought 3x U2412 for my upcoming eyefinity/NV suuround. Got it for $1060 with tax+shipping.
Next up GPUs. Probably 2x 6970 for CF.
That was my impression as well. Good monitor for office use but for gaming buy something else.The AOC is actually faster than the 2412 according to PRAD like senna says. I remember seeing a few high response time values with certain transitions in PRAD's review of the 2412 but I will have to double check. The 2412 being slow makes sense because the rest of this years LED backlit IPS panels have had nearly twice as slow response times (LG IPS2361V vs Dell U2311H) and there have been some major quality differences between the same models.
A bit of time has passed, how's your display now?
It's pretty much the same, i.e not visible unless scrutinising a black screen in pitch darkness. But it does tend to get ever so slightly worse after the monitor has been on for a few hours.
But I am sorry to say that I will be returning the 2412 because of the colour error with blue luminance on my unit (+46%). It's becoming quite noticeable on content with blues and I don't think these monitors are supposed to be like this. I may roll the dice on another 2412 as everything else about it is great.
I think that's an issue with the factory calibration on these screens. The blue channel seems a bit too strong on mine, which is why my blue setting on RGB Custom Color is at 89 versus 96 for Red and 93 for Green.
But if you don't like it and can't fix the problem, send 'er back!
You know you can actually fix the blue by switching to Multimedia picture mode but then there's too much red luminance
By any chance have you measured blue luminance on yours? Was it as bad as mine?
Does anyone know if the U2412M supports DisplayPort 1.2? I'm trying to eliminate any possible tearing issues caused by running monitors in a TriFinity setup with differing connection types. If I could just drive all 3 monitors off of one DP out and then daisy chain the rest, I think that would be the best solution, but I've been told you need DP 1.2 for that to work, hence the question.
Overdrive on/off and Overdrive GAIN, so possibly the ability to tailor OD if the RTC overshoot bugs you (ie. reverse ghosting)
For those in Canada, this monitor is now on sale through August 16 for $349.99: http://accessories.dell.com/sna/products/Monitors_Flat_Panel_Widescreen/productdetail.aspx?c=ca&l=en&s=dhs&cs=cadhs1&sku=320-2676
Awesome. I turned off OD on my NEC2490 right from the beginning. I really couldn't see a benefit and I thought I saw an occasional extra jitter when I was doing lag testing.
Does this mean trolls will shut up? Sadly unlikely but this is great find that potentially addresses another niggle for some.
at the end, not a bad price don't you think?
Just ordered mine: $1,014.42 for 3 after tax with free shipping and getting the price match. Should receive them on or before the 23rd, so a week or less if that's true.![]()
Just got my monitor guys. Ordered on August 8th and recieved today.
I used your settings 10e and they seem fine to me.
I've only used it for one hour so far, but the colors are much better on this than on my BenQ V2400W.
Anybody know if they plan to release a 27" version of this monitor and if it will be 1080?
Here you go:
I tried it with and without the OD. The only real big difference is the slight reverse ghosting on the trailing edge of something with OD on. The OD gain also works to allow you to balance things out for less or more.
What OD setting would you recommend for gaming? Is it even worth messing with if there's a chance of voiding the warranty somehow?
Hey, I remember trading PMs with you a while back on that V2400W. Glad you like the U2412M now.
http://www.tftcentral.co.uk/news_archive/24.htm#new_dell_monitors
Will be a 27" VA panel type, but it might be nice (P2712H)
