No, you're not limited by the 10/100 port on the AP. You are limited by the radio itself. The 10/100 port is enough for the regular UAPs. A gigabit port wouldn't improve speeds at all.
why do you say that? the laptop connects at 300mbps. if i do a file transfer from my server the the laptop, i can see the laptop max out at around 100mbps.
Wireless is half-duplex + overhead, wired is full duplex. 300mbps half = 150mbps full.
http://www.speedguide.net/faq/what-is-the-actual-real-life-speed-of-wireless-374
80ish Mbps is generally considered pretty good for 802.11n. I get about 100mbps on my dedicated PTP links with very specific hardware. With some consumer routers you can completely trash the 5ghz range for everyone around you and bond multiple channels.
so it would max out at 150mpbs right? i can only get 100mbps doing local network transfers (1gb to 802.11n).
Below is a breakdown of the various 802.11 WiFi standards and their corresponding maximum speeds. Theoretical wireless speeds (combined upstream and downstream) are as follows:
802.11b - 11 Mbps (2.4GHz)
802.11a - 54 Mbps (5 GHz)
802.11g - 54 Mbps (2.4GHz)
802.11n - 600 Mbps (2.4GHz and 5 GHz) - 150Mbps typical for network adapters, 300Mbps, 450Mbps, and 600Mbps speeds when bonding channels with some routers
802.11ac - 1300+Mbps (5 GHz) - newer standard that uses wider channels, QAM and spatial streams for higher throughput
Actual wireless speeds vary significantly from the above theoretical maximum speeds due to:
distance - distance from the access point, as well as any physical obstructions, such as walls, signal-blocking or reflecting materials affect signal propagation and reduce speed
interference - other wireless networks and devices in the same frequency in the same area affect performance
shared bandwidth - available bandwidth is shared between all users on the same wireless network.
Below is a breakdown of actual real-life average speeds you can expect from wireless routers within a reasonable distance, with low interference and small number of simultaneous clients:
802.11b - 2-3 Mbps downstream, up to 5-6 Mbps with some vendor-specific extensions.
802.11g - ~20 Mbps downstream
802.11n - 40-50 Mbps typical, varying greatly depending on configuration, whether it is mixed or N-only network, the number of bonded channels, etc. Specifying a channel, and using 40MHz channels can help achieve 70-80Mbps with some newer routers. Up to 100 Mbps achievable with more expensive commercial equipment with 8x8 arrays, gigabit ports, etc.
802.11ac - 70-100+ Mbps typical, higher speeds possible over short distances without many obstacles, with newer generation 802.11ac routers, and client adapters capable of multiple streams.
Are all of your hardware specs fully capable of reaching such speeds?
I wonder if there is a bottleneck somewhere internally?
My PC should be able to do gig for sure, i5-4760k with intel pci-e nic, not using onboard realtek. I didn't do much testing directly connected to the ONT though so I'm not sure. Haven't been too concerned with it for right now, the main thing is I get GB to my house. I'll get around to trying to make it faster eventually.
I'm uber jealous of gigabit connection.
Comcast is to roll out 2 gigabit here in San Jose by the end of this month or July.
They just boosted my 105 meg package to around 200 down for free.... which is quite nice.
But, theoretically, ten times faster than this?
Bad ass....
