You do know 99% of smartphones out there can do the same thing?
And those are smaller, can be used as phones, and fit in your pocket....
do they have analog sticks and real buttons?
im sorry touch screens suck for gaming
Why is there so much hate? Size of a handheld as can act as a console with the power of your PC, capable of playing all PC games as well as all android games. Maybe you don't like the sound of it, but this thing is designed to kill all consoles IMO.
Most android games are designed for touch screen gaming, not that it's a good thing.
And there are controllers that have a phone cradle, and that would take away the one biggest advantage this thing has.
FUCK what happened to this forum
every one is so short sighted any more between this and the NASA news thread
i may just stop coming here
I think that's the direction NVIDIA's looking to go. I can envision something like a mini-GRID, where you'll have some sort of Tegra SoC acting as a front end to a small array of GPUs, and all clients to that are just dumb terminals (perhaps also with Tegra SoCs, as with the Shield).I THINK I understand the long-term benefits of this. Eventually we could have tech where we have a single high-performance video computing device in a home (one big badass video card/processor system) and the ability to use it from any screen in the house.
I've had my gaming rig hooked up to my flatscreen since 2006. Wireless mouse and keyboard and wireless xbox 360 controller for single player games... this stuffs been doable for years. What am I missing here?
Wireless portable screen? Range anywhere in your house?
Yeah, not the same.
Because this is the interwebs and now you must hate everything. Ionno why people doubt it's abilities it's just streaming from an actual computer else you just play shitty android games.
Maybe it is just me, but i hated consoles because there are the reasons why graphics sucked. Traditionally speaking, consoles are made to last 10+ years. At the beginning of its releases, games are great as the hardware are capable. But as time goes, developers have to downscale games to run on consoles to an extend that they simply develop games on consoles and then port it onto PC. In other words, PC version is nothing more than bigger skin files from its console counter parts.
This little device opens up new ground for developers to design games that run on PCs or even GPU servers. Pay attention to the PC that was hosting the game for the SHIELD, it was acting like a server where you can start other apps on it. The little glitch during the demo showed that there were 2 SHIELD connected to 1 PC, indicating that 1 PC can launch at least 2 sessions of SHIELD gaming. Maybe it will need more than 1 GTX 680 for it, but it is possible. I don't think a single GTX 680 can launch 2 sessions of 4k res, but i believe 2 720p res is not going to be a problem. If implemented properly, setting up a LAN party will be easier than ever where all your friend has to bring is a SHIELD, or perhaps, any future handheld consoles.
I don't think Nvidia's goal is to sell SHIELD for big profit, but to sell more GPUs. SHIELD is just a doorway to new possibilities. If it is a hit, variations of SHIELD with wireless HDMI and no screen will come. Maybe it will come as a motion detector + wireless HDMI. Maybe it will come in as a wireless 3d goggle (2 independent display for each eye). The whole point is not about the power of the device itself, but how to utilize the power of the PC wirelessly.
Shocked at all the masturbation over this. I must be missing something.
This is a niche product that will likely fade away in a few years.
But that's the biggest point of having the controller integrated. If you were designing a game for the shield, you would know every person has gamepad controls they can use. The devs can test and make sure everything works flawlessly. If you are attempting to use a 3rd party controller to control a touch screen game, you're going to have mixed results on whether or not the controls work.
On top of that, the gamepad has a ton of buttons. Most touchscreen games are going to be designed around little to no buttons so if you attempt to use a controller there won't be a way to simply map a function to a button.
Well to stream it on your Tv, you still need to hook up the device via HDMI to the TV.
So if you want to play on your TV, hookup up your PC to your TV Via HDMI. Just like this device.
There ya go....stream gaming on the TV!
If you want to use a controller, get a wireless 360 controller.
It's alot cheaper buying a HDMI cable and a 360 controller, then this device.
The ONLY way I see this being useful is if you can use it outside your own local Wifi network. (i.e., take it to a friend's house and be able to play games from your PC on the friend's TV).
Still interested, not going to speculate on it failing or not. Once it is closer to release we will know enough to make a real educated opinion of it being something we would want or not, as it stands, I like the idea.
You don't get it. It can wirelessly stream to the tv. They plugged it in for the demo to avoid technical issues.
Wrong
The PC streams the game to the device and you need an HDMI cable from the device to see that image on your TV. They used ethernet to connect to the PC to avoid a disconnection should the Wifi signal get interrupted.
PC gaming - I could either just sit at my PC, play on a laptop, or hook my PC up to my TV. Unlike most people I have an HDMI cable long enough to connect my PC to a TV without moving it, so it seems like an unneccesary expense. And you are limited to what video cards you can have.
But don't be so close minded.
Say for example you are doing all the above today?
What if you call in a hooker, and want some Portal 2 action while doing it doggie style in your bedroom? Hell, this use case, probably will cost me as much as a civilized evening at the peelers, but probably much more immersive.
If I ever do this, I promise to post pics of it on Genmay!
Hey, I am not trying to troll, just trying to point out that, giving reasons why you DONT need it, is usually not as interesting of coming with creative ways on where it can be useful, fun, cost effective, and damn right [H]ard.
A future update of Kainy will add the ability to stream from PC to PC/laptop. It is in fact already working, all he needs to add is sound support.
http://www.kainy.net/viewtopic.php?f=4&t=1051
The developer is pretty amazing, he takes feature requests and adds them rather quickly. The PC to PC feature was asked on December 12 and he had it working by xmas day. More info at kainy.com and kainy.net (forums)
Like a few others have mentioned, I'm actually more interested in streaming games from a fast desktop to a laptop or windows 8 tablet. I can get way better video cards for a desktop and use the laptop for the screen/sound/keyboard/xbox controller.
All I want to be able to do is stream games from my desktop while playing them on my laptop. Or use an external GPU with my laptop. Why must it be so difficult???
You really don't need much bandwidth for these applications. Most cable connections are fine; most higher-tier DSL connections are suitable; FiOS is obviously more than ample.you could if 99% of ISPs in the US didnt SUCK
OH HAI Google Fiber
The WHDI "Stick" enables users to wirelessly view all of their tablet or notebook content on their TVs without the limitations of other solutions. With no latency (less than one millisecond) users can now play their PC games and interactive content on the “big screen.” In addition to all other content, WHDI security and built-in HDCP 2.0 copy protection allow the WHDI Stick to bring also Blu-Ray movies and other copy-protected content to the HDTV.
The WHDI "Stick" is a true plug-n-play product, no installation is needed and it is OS independent. It is the smallest WHDI external product design to date. The 3.2 x 1.2 x 0.6 inch (81 x 30 x 15 mm) transmitter plugs directly into the HDMI port of the notebook and is powered by the USB port. The WHDI "Stick" will transmit the PC screen directly to TVs embedded with WHDI or to any TV using a WHDI receiver adapter that connects to the TV via HDMI.
im throwing money at my screen and nothings happening![]()
I guess I am not the only one who hated consoles than. I suck at writing too, but thank you.4 months already more [H]ard then most of the people in this thread
i suck at writing and this is pretty much what i have been thinking and not being able to say
well said![]()
I did say the power of "your PC". Although it isn't clear in the demo, but it can connect to your PC via WIFI. I hope that I am not mistaken.Just to be clear. This can not play PC Games. Do not make that mistake. You need a PC for this to work. It will not replace your gaming PC. It simply streams the video output and control input via wireless instead of cables. It will however run Android games.
Interesting I guess but I don't see the appeal.
So, if my PC is already connected to my TV (which I've done since 2005-ish), I don't really need this do I? I don't see the appeal of this device at all, but maybe most people still use a computer desk to play on their PC? I'm kind of confused.
Yeah I think its because those of us that have put our PCs under our TVs are in the minority. Not even talking strictly HTPC here, I mean anything. Gaming rig, HTPC/gaming hybrid, whatever. Which is too bad, seeing as how it is nothing but awesome. But it seems to be a very small number of people who do this, for various reasons, so products like this come out to bridge that gap I suppose.
Not sure but it looks like this has not been posted here yet: Anandtech has a little hands-on preview
