p3sty
- Feb 22, 2006
The cx48 has ruined all other monitors for me. I just need 240htz
Yeah I really looked hard to find something else to replace it with and I still haven't seen anything that's really an upgrade. My desk is 36inches deep some I need something at least 48 inches or maybe could do one of the new 45's on an arm. But I really want a ultra wide , I like the 16x9 format.The cx48 has ruined all other monitors for me. I just need 240htz
16:9 is the same aspect ratio as any normal 1920x1080, 2560x1440, and 3840x2160 monitor. Ultra-wides would be thinks that are 3440x1440, etc.Yeah I really looked hard to find something else to replace it with and I still haven't seen anything that's really an upgrade. My desk is 36inches deep some I need something at least 48 inches or maybe could do one of the new 45's on an arm. But I really want a ultra wide , I like the 16x9 format.
I might be missing something but what's the purpose of an ultrawide when you can just crank up the FOV on a 16:9 display to get something even better than an ultrawide? I believe something around 106 FOV gives you the same horizontal FOV as a 21:9 ultrawide but with the added bonus of extra vertical FOV that you can't get on an actual ultrawide.
Just guessing that DV2 being talked about lately in some forums and tech sites might remain more valuable on OLEDs for longer (for movies and shows, primarily), since even OLEDs with high 10% window like LG's G5 tandem OLED ~ 2k nit at 10%, are still a bit more limited at larger % windows:
LG G5 (55" smallest size) in game mode (as per RTings review) :
Peak 2% Window 2,086 cd/m²
Peak 10% Window 2,118 cd/m²
Peak 25% Window 966 cd/m²
Peak 50% Window 616 cd/m²
Peak 100% Window 390 cd/m²
Sustained 2% Window 2,045 cd/m²
Sustained 10% Window 2,066 cd/m²
Sustained 25% Window 920 cd/m²
Sustained 50% Window 608 cd/m²
Sustained 100% Window 387 cd/m²
TCL QM8K (65" smallest model) game mode (per RTings review). The soon to be available QM9K is reportedly even brighter.
Peak 2% Window 3,610 cd/m²
Peak 10% Window 3,516 cd/m²
Peak 25% Window 2,166 cd/m²
Peak 50% Window 1,246 cd/m²
Peak 100% Window 800 cd/m²
Sustained 2% Window 1,632 cd/m²
Sustained 10% Window 1,673 cd/m²
Sustained 25% Window 1,646 cd/m²
Sustained 50% Window 982 cd/m²
Sustained 100% Window 657 cd/m²
You can see where all of the % windows on exceptionally bright miniLED FALD HDR (144Hz currently) gaming tv screens are starting to approach 1000nit, notably even the 25% and 50% sustained, and even 100% (un-sustained) windows, so that there would be little to no compression of ranges necessary for HDR 1000 (1k) at least. Perhaps DV2 will help to tone map for HDR4000, 6000, to 10,000 ranges to look better going forward though, (or to "upscale" HDR10 content to 4k, 6k, 10k nit capable TVs a little better than TV manufacturers offerings might on their own).
The LG G5 at 55" is appealing, but limited to 144Hz so there are some tradeoffs vs faster, dimmer oled monitors (and those with dp 2.1 if 80Gbps)
I've considered the Samsung Ark Gen 2 many times but held off because it's a 55" and for me a 50" is the absolute max size I prefer. The curve is awesome for gaming though.Still using my 48 cx as my gaming display. i have a few tiny black pixels at the top right and left along the edge, but hardly any. A tiny sprinkle of pepper within a 1/2" horizontal area in each spot right along the edge. Not really noticeable.
I could male a 55" work. That's the smallest size of the LG G5 tandem oled currently, and it's the size if the samsung ark some people used (though that is curved).
The tvs are Hz limited now compared to desktop monitors , and don't have dp 2.1 80Gbs. The tvs go much brighter in HDR though. The OLED monitors are limited, especially compared to the G5.
Like what?The CX is like the GTX 1080 Ti, there are way better options out today but nobody would fault you if you were still using one.
Like what?
I'm using the 48cx perfect size has all the features I need with the exception of 240 htz or higher refresh. TBH programs and games lack innovation anymore we seem to have flatlined.
After the 48cx I cannot see myself going to anything smaller. The Samsung odyssey format is horrible for me to narrow after having the 48cx .
48" 16:9 4k
I sit at ~ 38" to 45" away from my 48CX , depending what I'm doing. I consider 60PPD a minimum, and for non-standard subpixel formats, even higher really.
48" 16:9 at 38 inch view distance = 60 degree viewing angle = 64 PPD
48" 16:9 at 45 inch view distance = 50 degree viewing angle = 77 PPD
45" 21:9 at 5120x2160 , ~ 17" tall
45" 21:9 at 24 inch view distance is almost 1/3 short of the center of curvature = 82 deg viewing angle width = 63 PPD
45" 21:9 at 32 inch viewing distance is at the center of curvature of the screen = 66 deg viewing angle width = 78 PPD
The 45" 21:9 is similar to a 34" 4k 16:9 screen with a +640px "wing" on each side.
Cons I don't like about that screen are:
- abraded outer layer/matte
- not as bright as oled TVs (especially new tandem oleds like the 55" G5, let alone future phOLEDs + tandem)
- "only" 165Hz 4k (with a 240Hz model rumored to be produced at some point)
32" 16:9 4k
32" 16:9 at 24 inch view distance = 66 deg viewing angle = 64 PPD (33" 16:9 = 62 PPD)
32" 16:9 at 32 inch viewing distance = 48 deg viewing angle = 82 PPD (33" 16:9 = 79 PPD)
34" 16:9 4k
34" 16:9 at 25 inch view distance = 61 deg viewing angle = 63 PPD
34" 16:9 at 32 inch viewing distance = 50 deg viewing angle = 77 PPD
57" 32:9 "4k+4k" super-ultrawide , ~ 17" tall
A 57" super ultrawide is a lot like a 34" 4k screen with a 1920px "wing" on each end.
The viewing distance numbers come out similar to the 45" 21:9 since they are practically the same height
57" 32:9 (or a ~34" 4k) at ~ 25 inch view distance = 63 PPD
57" 32:9 (or a ~34" 4k) at ~ 33 inch view distance = 79 PPD
(The dotted line was added by me) . . . screenshots are from "Pete Matheson" youtube channel
If just considering the productivity aspect, I can do similar to this head turn below in a triple screen setup, but I get more height, (especially with 4k portrait mode screens on the sides). Additionally, some games don't play nice unless they are fullscreen, so having other monitors with 2ndary inputs connected to a laptop or other (less robust than my gaming) system that I can swap over to while gaming is also a pro for me as well, where a single screen loses that multi-screen space, multi-tasking usability while in game. Alt-tabbing out of games isn't a great solution either. That process can be laggy/clunky. Some games get buggy when you do that at times, too, or even freeze/crash. Apps can minimize or move around as well, which is annoying.
I get the attraction for some people but for me, I'd want a taller screen, even after taking viewing distance vs perceived height into consideration. I also don't like using oleds for static desktop/apps, but I want one for gaming. . and like I said I like to multitask while gaming, so having mutliple screens is a better usage scenario for me. Those factors overall making the biggest pro of the s-uw, the "productivity"space aspect, less useful to me.
WHAT SCREEN IS IN THE PICTURE?
LG CX monitor review scores (Rtings) :
LG CX scores from it's RTings TV Review :
LG G5 OLED review scores media / game mode (RTings) :
LG 45GX950A SDR brightness and HDR brightness scores (RTings) :
TCL QM8K HDR media / HDR Game mode ratings (Rtings) :
<QM9K not reviewed yet>
QM8K SDR ratings (Rtings)
Absolutely. I've had the CX for over 5 years now. I'm still happy with it and don't see any huge need to replace it, despite having some dead pixels on the edges. You just don't notice them in actual use.The CX is like the GTX 1080 Ti, there are way better options out today but nobody would fault you if you were still using one.
I've said it before but I'll say it again. Just higher HDR brightness is not enough for me to swap. The LG CX is good enough where I'm not unhappy with its HDR performance. I've got several smaller, higher brightness displays (OLED tablet and two mini-LEDs) to compare to. Yes, they're better, but they don't really make a huge difference in my overall experience.
I feel like we are again in a transitional period where OLEDs will improve drastically in the next 1-2 years with all the new layer tech etc. I hope that also means we will get 240 Hz refresh rates - ideally with low latency BFI.
I'm still waiting for that overall package that will be a major improvement in every area. At this rate, the likely scenario is that I will buy a house before I upgrade my TV.
After 5 years my CX48 is scrap. My wife went into my man cave to watch tv on Saturday since I was playing Ball X Pit on the tv down stairs. I was sick all weekend and didn’t even go upstairs where my man cave is.
When I got home from work today I went to hop on BF6 and when I opened the door I noticed the tv was on.
The OLED had been on for 4 days. All 4 corners have dead pixels as well as the first few rows on all sides. Also a splotchy grid sorta burned in from the main screen on YouTube.
My disappointment is immeasurable and my day is ruined.
I figured the dead pixels popped up from around 96 hours with no panel refresh. I’m pretty ocd about my oleds. I basically use that one for couch gaming since I have a G8 on my desk. Last game I played was RDR2 a couple of weeks ago and it was the snow area. Pretty sure I would have seen it.4 days is not even 100 hours, definitely not long enough to suddenly cause dead pixels and permanent burn in. You probably already had those dead pixels long before but just didn't notice until now. As for the burn in, try running a long compensation cycle and see if that clears it up.
Any thoughts on the LG G5? S95F isn't available here yet, and G5 is 400 off deal atm (so £1999 vs £2499 for S95F at release). They both seem pretty similar, so go cheaper?
LG uses dithering on its OLEDs
to address problems like chrominance overshoot and instability in low-brightness pixels, which can cause noise or banding in dark scenes. While it can improve overall picture quality by simulating more colors or smoothing out transitions, this processing can sometimes introduce new artifacts, such as visible diagonal lines, especially when viewed up close on certain models
Yeah I have the same worries as you. The matte of the S95F is a damn shame, but so is the dithering on LG C and G panels (B is unaffected but looks no better than our old CX lol). It's the kind of thing that's hard to judge without trying it in person though, but it's a turn-off at this price point.
My other issue with Samsung is that for whatever reason they mix up QD-OLED and WOLED depending on the size and region, and in Europe there's very few Samsung panels that are actually QD-OLED. Like, this prevents me from going for the older and cheaper gen, for example S90F that was actually glossy only comes in WOLED type here, and is no better than LG's offerings (it has the dithering issue as well).
In many ways I love the 32" inch QD-OLED panels out there, other than somewhat average HDR they are virtually flawless.
But I'm really addicted to 48" size and can only imagine going up, not down, or sticking to the same.
There is no such thing as a perfect TV with zero flaws. The pros of the G5 far, far outweigh the cons by miles. In fact, my cousin who got burn in on his CX last year from playing too much FF XIV with RTX HDR on, finally decided to cash in on his Bestbuy geeksquad warranty to get a G5. They sent over a technician to inspect the TV then later gave him this notice the following day:
He called them up, then got issued store credit for $1488.
This means with the sale price of the G5 being $1750, he was able to buy a brand spanking new G5 for just $262!
Yeah sure it's not 100% perfect, but neither is the CX with it's near black chrominance overshoot and vertical streaks, yet everyone just happily keeps on using it without complaining.
I'm in a similar situation. The 45" 21:9, 5120x2160 LG GX950a 's format was perfect really, but I found the overall PQ lacking (they did some weird lift in order to do their "high" brightness mode, the HDR curve was dim in the normal range and the colors were kind of dull, and the matte coating made everything worse with granular looking bright fields of color and text, and flattened blacks.).
I guess I have to wait to see what 2026+ has.
It really may depend on how far away from it you sit. For my purposes where it would be a 55" at around 3.5 feet away, the dithering might rule it out.
great trade in deal for your cousin though
Welp like I said if it's not the G5's dithering to complain about then it'll just be something else in it's place whether it's the C5's diagonal lines/green tinting/lack of tandem panel, S95F's matte coating/one connect box, S90F doesn't use a matte coating but still has raised black levels in a non pitch black room because QD-OLED, or Mini LED TVs having typical LCD issues. All TV's will have some problems or another, but IMO the trade offs are well worth it. Life is too short to be stuck on 2020 HDR displays.
I tried with the gx950a but that wasn't "it". I felt it wasn't even a sidegrade in PQ to my 2020 display , lol , other than the rez and 800R format. Appoaching ~ $2k after taxes here, since they don't make anything smaller than a 55" LG G5, isn't a price tag I'm willing to suffer in your face dithering on. I'd have to see it in person to be sure though, at around my 3.5 foot viewing distance on different viewing material.
the G5 is a day and night difference in picture quality against a CX.
That was the idea, until I learned more about the dithering issue.
