- Jul 5, 2012
ok my lg48cx has bit the pixel gods in the butt whats the best replacement s90f or c5
If you're talking about 48 inch versions, they both use the same LG WOLED panel so just get whichever one you can find cheaper.
my cx48 just hit 5 yrs used every dayMy CX 55 still going strong as my GT7 sim racing display. I’m utterly blown away at the resilience of this TV.
I have compared them not much difference for 1000 dollars unless I'm missing somethingS95F
Well first off, there is no 48 inch S95F, it starts at 55 inches. The differences vs the S90F is brighter HDR, 165Hz instead of 144Hz, and matte instead of glossy so yeah nothing that is really is worth $1000 extra over an S90F.
I just picked up a C5 to replace my CX 48. I tried the 45950a and couldn't stand the coating and the curve. I honestly can't really tell a difference between it and the cx. My CX started getting to many dead pixels around the edges. My son now has it as his gaming tv for xbox. The C6 should be out in like 2 months if you can wait. But the only thing it does is 165hz and a better Ai cpu. The then Samsung looks good but to get the new panel you need to get the 55 and they are all going to a coated screen. I can't stand the coated screen.
Samsung doesn’t support Dolby Vision if that’s important to you.
That matte screen is amazing. I bought a 77" G5 and returned it before the installers even left. I've had the S95F now for 3 weeks and it's been amazing
I don't know if I would personally call the matte screen amazing but it certainly has not been an issue for me. I'm a huge fan of glossy and the matte on the S95F has not been a bother at all.
If you kook at it in a dimly lit room, s90f. My s90c is great, but it's in my basement away from the window.is it a true 165htz for the 55? or gimmicky. s90f over lg c5?
well, waiting for the c6 is pointless the new features are only going on the 77 and 80 something panels this year I might go 55 it's not that much bigger than the 48 I sit back about 30 inches from the screen
Supposedly with the Alpha 11 Gen 3 chip LG has fixed their near black posterisation issues. So a reason to get a C6 over a C5 if that matters to you.
View: https://youtu.be/82InNlCqxlU?si=ePr4aD0XBa3wUJvQ
It seems that for this gen, the specs don't really change all the way down to 42 inch, also. (other than brightness, because smaller heatsink, but that's fair).
So even the smaller models keep the 165hz and same processor etc.
So yeah just want to know about the dithering at this point.
If I had a 55" 16:9 at my pc, I'd be viewing it from around 3.5 feet
55" 4k at 60 deg viewing angle = 42 inch view distance
55" 4k at 50 deg viewing angle = 50 inch view distance.
I use this as a rule of thumb, in order to stay at or near to within the central human viewing angle, as well as hitting over 60 PPD at 4k.
Using the calculator linked below to apply that 60 to 50 deg viewing angle to a 55" would mean
Any 4k screen of any size when viewing in the human 60 to 50 deg central viewing angle gets 64 PPD to 77 PPD.
There is a little wiggle room, but sitting much nearer and you'd get the larger areas of off axis pixels shown in the 2nd picture, and to a greater degree off axis . .
as well as getting less than 60 PPD once at wider than a 64 deg viewing angle - which imo is a bare minimum for perceived pixel density (pixels per degree). 60PPD for LCDs anyway. In fact, text wise, imo OLED non-standard pixel structure benefits from at least 70 PPD, and also on any screen type for desktop graphics and imagery that typically get no sub-sampling or anti-aliasing.
So personally, if I were to end up with a 55" 4k, I'd have to be be viewing it from 42" (60 deg) , and likely closer to (a farther) 4 feet away for my setup. 70 PPD on a 55" is at 46" view distance. I think I could do it, but it's pushing it for my setup's distance constraints even with the screens mounted separately from my desk (which I have right now still running my 48" + other screens on the sides). For my particular setup, I also might have to drop one of the sides screens if I end up doing that, depending.
Your 30" view distance figure would result in a 77 deg viewing angle (17 to 27 deg outside of 60 to 50 deg, or around 9/60/9 .. 14/50/14 depending on how you look at it) , and you'd only be seeing 50 PPD. For reference, a 1440p 16:9 of any size when viewed at 60 to 50 deg viewing angle gets 41 to 50 PPD. So to your perspective, your pixels sizes would look like 1440 - 15xx , and the sides of the screen would be off axis more (where people with 3 monitors across would usually be turning the side screens inward to face them..
https://qasimk.io/screen-ppd/
? They still sell the c5 42 and 48 and the c6 42 and 48 will also be sold in the USA. https://www.lg.com/us/tvs/lg-oled42c6pua-oled-4k-tvAfaik they don't sell the 42" or 48" models in the usa anymore (LG).
| Size | US Model | Costco Model | Short Model Code | Display Technology (North America) | Maximum Refresh Rate |
| 42" | QN42S90FAEXZA | - | QN42S90F | WOLED | 144Hz |
| 48" | QN48S90FAEXZA | - | QN48S90F | WOLED | 144Hz |
| 55" | QN55S90FAFXZA | QN55S90FDFXZA | QN55S90F | QD-OLED | 144Hz |
| 65" | QN65S90FAFXZA | QN65S90FDFXZA | QN65S90F | QD-OLED | 144Hz |
| 77" | QN77S90FAFXZA | QN77S90FDFXZA | QN77S90F | QD-OLED | 144Hz |
| 83" | QN83S90FAEXZA | QN83S90FDEXZA | QN83S90F | WOLED | 144Hz |
I've been focused on G5 threads on avsforum, etc, - and lately the G6 inquiry thread here on H so I was crossing wires. That's because my focus is on tandem stack to compete with QD-OLED screens.
If you were buying a tv for gaming right now for a desk setup what would you buy?
Yeah I got 1200 for my cx warranty so spending another 1000 for th s95 I’m debating but I’d hate to do that then they come out with a 249 htz next year
