- May 5, 2006
To expand on what I was talking about - it's a "metal rope" cable that is also available in a rubber/plastic coated type. You can get them at a hardware store along with some screw down metal cinch hardware and clips, etc. I have my 70" vizio VA tv connected to some wooden framing behind it with a few of these thin cables since it's on it's own shallow tv feet on top of a long tabletop style stand and I have a few cats who like to jump up behind the tv and stand on the window sill. I run the cables from bolt-like metal eyelets I screwed into the tv's vesa/mounting holes to other small wooden-screw style eyelets I screwed into the framing of my picture window behind the tv. I use crab claw like clips on the ends of the cable's looped ends that I can squeeze like scissors to release the cables from the wall if I have to.
What I'm suggesting for the 48" OLED is running a line or loop of this kind of wiring off of an eyelet screwed into the mounting holes and then black zip tying all of your cabling to that snugly, leaving enough slack between the zip tie and the ports of course. Optionally, use cable unions after that point as break-aways.
There are other ways to do it like attaching them all to something screwed into the desk or if the TV is actually vesa mounted, tying them to that mounting hardware, etc. The closer to the back of the TV and the ports you can tie/lock them in the better though.
