Yourflyisdwn
- Sep 16, 2017
Just got the KS email:
"Starting the campaign 2017-11-25 at 21:00 CET"
Christmas has come a month early![]()
Weird, I didn't get one yet. I'll have to sign up again
Had you backed the original KS campaign?Weird, I didn't get one yet. I'll have to sign up again
There’s rumor they are going to skip Volta for a mainstream Geforce release. There is a thread on here about this... the card has a different name but can’t remember
Will price be similar as the last campaign or are we expecting a lower price this time? Sorry if this has already been mentioned.
Oh no, I just signed up for notifications on their website. Although since I signed up for it I haven't gotten any emails so I don't see why I'd get one now lol. They should really be utilizing that. I'm sure there are a bunch of people who have stumbled on their site and signed up for the newsletter, only to be kept in the dark during this whole thing.
You are disqualified for leaking btwJust got the KS email:
Do i get a special edition then?You are disqualified for leaking btw![]()
When can we expect to see full build shots of the other finish?
Do i get a special edition then?![]()
I haven't seen much about the bottom hats. Do they work the same as the top hats?
Also, do you think it would be possible to do a custom watercooling loop inside this case? My only concern is where to mount the pump/res. Perhaps if you've used a short GPU it could be possible?
They haven't talked about it too much but from what I've seen they attach the same as the top, just flipped upside down.
I don't think they're going to support custom loops with this iteration of the case at least. I'm sure you could work something out and do it yourself like you said with a shorter GPU. Maybe if enough people ask about it they'll consider mounting points and other water cooling compatibility options for the next iteration.
Would it be beneficial to have a small top and bottom hat in a push pull? I’m needing a 100% ram comptaible cooler, so any additional airflow options to keep my 7700k cool would be nice. Not planning an overclock.
We have some ideas of adding openings in the top plate for GPU hoses that would allow a dual 120 AIO setup. Will need to take out the jigsaw (is that how you say it?) and test if possiblePachalski It would be nice if there will be a way to install 2 AIO 120 mm like Corsair H55. 1 for CPU and 1 for GPU with Kraken G12.
As far as i see there is one problem: no hole for GPU AIO hoses.
Looking forward for the Kickstarter.
Actually not sure. A cooler like the L9x65 would draw uncirculated air with or without extra fans. The CPU temps would likely be comparable. But to be honest that cooler does a great job, if you are loading the CPU 100% for a long period of time (rendering, searching for the next prime number etc) the 7700k would probably throttle, even in an open bench. Not all use their computers for this type of tasks and for gaming it would easily cover your needs
Any chance of being able to test a push pull top and bottom slim fan setup like he mentioned? Two in a bottom hat and two in a top hat?
I’m torn between this and doing the large top hat with 240mm AIO. My thing is I fly a lot and I’m not sure if the pressure changes negatively affect the “sealed” AIO system. Not to mention the added weight of the rad is fairly noticeable. I’m using this as a mobile gaming rig... weight and size are a big deal. Honestly I strictly game... so I probably don’t need any more than stock speeds. Got a 980ti so for 1080p I should be good.
We are tying to get out hands on every http://noctua.at/en/nf-a12x15-pwm we can get in Stockholm but they are hard to find. We will run the test as soon as we get them. Currently we have one.
Yeah I'm definitely not doing water cooling. I mean I 100% plan to have at least one small top hat with two 120mm slim fans on top for exhaust, my only question would be if it'd be worth the extra $$ for the top hat (on the bottom) plus two more fans. If the temp difference is nonexistent or only a couple degrees then I'm not gonna shell out all that extra cash for a second top hat plus slim fans just to have a slightly noisier computer at the benefit of 2 degrees. I know some people on here are crazy about getting the coolest (temp) computer down to the lowest possible degree, but honestly I prioritize noise level and size over cpu temps.
GPU temps though are what I'm asking for. I doubt having 4 fans instead of 2 is going have a noticeable difference on the CPU, but it might help the GPU out a ton.
Mounting points for custom WC could be done in this iteration before delivery as well, if it's only a matter of some additional holes in the Blade it is almost a no-brainer! No promises, but it could definitely be discussed with the backers during the campaign.
You planning on doing an open air GPU or blower style? I’d kill to fit the 1080ti Strix. I’m only using Corsair SF600 but that’s recommended power so it should work. Considering the way open air GPU exhausts in the case, a top hat with 2 fans would probably be a solid choice. I’m not sure if he recommends a blower style though to ensure no temperature rise within the case. The only downfall is noise levels.
i still haven t understood the plans (or even if there are any) for a windowed side pannel.
any clarification about that?
