D
Deleted member 143938
Guest
DLSS in Control doesn't have a type selection (ie quality, performance, etc). Checking DLSS does open a new "render resolution" option for objects and the like that you can toggle between, which are probably the quality, performance etc equivalents. I mentioned everything is maxx for me, including the DLSS render resolutionWhen people mention DLSS they need to say what DLSS mode they're actually running.
DLSS off:
DLSS on (changes the render resolution choices):
I can definitely uncheck it and it keeps unchecked (and frame drops appropriately). I'm on the latest version (GOG), and nVidia drivers the latest before this last one (461.09)So the 120FPS that Furious Nerd reports on his 3080 with DLSS on is in the generally appropriate range for a 3070 with DLSS on to be in the 90 FPS range.
Furious Nerd - can you turn off DLSS? I can uncheck it, but it always is rechecked when I come back in to the settings?!?
