Waiting for Haswell?
Discussion in 'Intel Processors' started by spincut, Apr 26, 2013.
  1. JimmiG
    JimmiG 2[H]4U
    2,429
    Apr 3, 2008
    Same here.
    -Skipped SB because my Phenom II felt fast enough at the time. The plan was to upgrade when IB came out.
    -Skipped IB because it wasn't any faster than SB and overclocked worse
    -Finally going to upgrade when Haswell comes out.
    The difference between IB and Haswell is small, but the cumulative improvement when you skip several generations adds up. I guess that's the idea with Intel's tick-tock scheme... +10% with SB over Nehalem, +10% with IB, + another 10% with Haswell.
    In the past, we had clock speed bumps, then more cores and IPC improvements. I think that era is over. Clock speeds have stagnated at 3.5 - 4 GHz. Core count has stagnated at 4-6 "real" cores. IPC improvements are limited to ~10%. This has been pretty obvious since around 2005 or so.
  2. Kor
    Kor 2[H]4U
    2,176
    Mar 31, 2010
    Keep in mind you'll be jumping up in supported instructions as well, I dare say we're going to see support for anything pre-Sandy dropped from support for games in the next year or two since anything bellow doesn't support stuff like AVX.
  3. sphinx99
    sphinx99 Gawd
    692
    Dec 23, 2006
    No chance of this, after all how would game publishers communicate this to buyers? Outside of enthusiast forums, nobody knows the difference between, say, Nehalem and Sandy Bridge. They just know that their computer says "i5" or "i7" on it. It would be easier to simply retain support than deal with the fallout of a game working on some "i7" computers and not others.
  4. Vexerz
    Vexerz Gawd
    885
    Mar 27, 2010
    Just from personal experience of being in this hobby the last 15+ years...you will have buyer's remorse. IMO, avoid the forums for at least a few months after Haswell releases.
  5. StormUP
    StormUP Gawd
    628
    May 19, 2005
    Can't wait until they start combining i7 and i5 with model year numbers. Like 2012 i5, 2013 i5, 2014 i5. It's similar to cars and that seems to be a system a normal person can understand to at least some degree and doesn't get in the way of gearheads who want to dig deeper.
  6. Brampton_Boy
    Brampton_Boy Limp Gawd
    137
    Jul 28, 2005
    I'm in a weird position.
    I have had the upgrade "itch" for a couple of years now, and have had my heart set on Haswell for quite a while.
    However, preliminary reports regarding the poor overclocking and heat output from Haswell chips have me rethinking my position.
    My i7 920 @4.4 Ghz can pretty much run anything without issue. However, my motherboard has no Sata 3 or USB 3. Plus, it is a powerhog.
    Given that I primarily game on my machine (the rest of my work is done in Stata or Excel, which is hardly demanding), I can either:
    A) Buy a second 7970 and CF my rig + Larger capacity SSD
    B) Overhaul entire system to Haswell, but stick with my one 7970
    Decisions, Decisions.
  7. alek
    alek Limp Gawd
    145
    Oct 25, 2012
    "no way to have onboard and discrete card enabled at the same time...but you can hook both monitors to your 5850"
    this comment from overclockers.net turned me off this haswell thing alittle.
    i was thinking of utilizing the integrated graphics on one monitor but it cant be done?
  8. RamonGTP
    RamonGTP [H]ardness Supreme
    7,676
    Nov 9, 2005
    I've been doing it on my SB i5 and IB i7 since I owned them. I can't imagine why this would be any different on Haswell. I call BS on that claim.
    That said, it would be a very weak reason to not go Haswell.
  9. kingduqc
    kingduqc Limp Gawd
    180
    Dec 22, 2011
    Can you do things with this onboard gpu? Encoding while recording gameplay is possible? I can't see any benefits of this with a discrete gpu on the machine, kinda wonder why it's in the 350$ chip.
  10. alek
    alek Limp Gawd
    145
    Oct 25, 2012
    Alright that sounds great. Come to think of it on the laptop i can do choose only a few specific apps for the dedicated gpu while the cpu gpu deals with other stuff. The integrated gpu gets mostly all the bells and whistles so I dont see why it shouldnt be of importance.
    It can hardly~ be called discrete with an overclock and a big aftermarket cooler blowing on the cpu (which contains the gpu)
    And yes if it works the same way as on the laptop you can select what gpu to use for each app/game but it will toll the cpu alot tho i think with just 4 cores.
  11. alek
    alek Limp Gawd
    145
    Oct 25, 2012
    I choose apps for each gpu in the nvidia control panel btw and can enable "right click to run with dedicated gpu". Again this is on a laptop.
  12. fullvietFX
    fullvietFX [H]ard|Gawd
    1,786
    Sep 1, 2004
    Waiting for Haswell i3 to upgrade my HTPC.
  13. ADRENALIN_2099
    ADRENALIN_2099 Gawd
    922
    Apr 26, 2008
    Why? Your HTPC's CPU is fine for movies:confused:
  14. RamonGTP
    7,676
    Nov 9, 2005
    Agreed, unless he has other plans for his current HTPC, it seems like a waste.
  15. fullvietFX
    1,786
    Sep 1, 2004
    Giving away my current HTPC minus the HDDs to a family member so he can check e-mail, YouTube, and browse the web. I'm also hoping with the new iGPU that I can use Steam BIG in my living room.
  16. dremic
    dremic [H]ardness Supreme
    5,178
    Dec 9, 2011
    what is availability usually like when these come out?
  17. RamonGTP
    7,676
    Nov 9, 2005
    Should be plenty of availability. I've never had a problem getting a CPU on release day.
  18. Marcdaddy
    Marcdaddy 2[H]4U
    3,628
    Feb 21, 2003
    Guys should I dump my 2600k at 4800 MHz ( also running 3 780s in Tri Sli as of tomorrow ) and go has well or wait one more generation?
  19. vict0r
    vict0r Gawd
    1,012
    Jul 11, 2005
    i'd say wait a little more patiently..sooner than later you'll have the perfect reviews...
  20. Nemik8800
    Nemik8800 Limp Gawd
    252
    Aug 29, 2007
    How long will it take until prices on current gen come down?
  21. Marcdaddy
    Marcdaddy 2[H]4U
    3,628
    Feb 21, 2003
    It hard because I was at my Local Microcenter and on Sunday they ate going to have special pricing on all Haswells and Motherboards. Also discounting Ram pretty steep as well and it's only in store.
  22. Kor
    Kor 2[H]4U
    2,176
    Mar 31, 2010
    They would communicate it the same way they always have, by putting the base processor in the minimum system spec. Instead of reading Core2Duo E8500 it will just say i3 2100, some people might get a little confused but not enough to matter (those are the kinds of people who will just as likely buy a game for a console anyway).
  23. ShuttleLuv
    ShuttleLuv [H]ardness Supreme
    7,032
    Apr 12, 2003
    I don't think it's necessary, unless you want more bragging rights on the newest stuff, but I'm waiting (as I'm sure others are) for overclocking info on it before jumping.
  24. Kor
    Kor 2[H]4U
    2,176
    Mar 31, 2010
    Only if limitations of 8x 4x 4x PCI-E 2.0 become obvious, otherwise no.
  25. wadec22
    wadec22 2[H]4U
    3,834
    Jul 26, 2005
    Haven't been to mine in a couple weeks, did they have pricing or did a salesman say they were going to do that?
  26. socialjazz
    socialjazz [H]Lite
    81
    Apr 2, 2013
    +1
    I have a 2600k and will only jump is there is some decent overclocking ability in Haswell.
  27. FrgMstr
    FrgMstr Just Plain Mean Staff Member
    48,311
    May 18, 1997
    I am still running a 2600K in my personal system. I will very likely be making an upgrade soon.
  28. Nvidia_ATI
    Nvidia_ATI Limp Gawd
    466
    Oct 5, 2011
    Although my 2600K is more than enough for my gaming and occasional video transcoding, I plan to upgrade to Haswell for native PCIe 3.0 support. The extra bandwidth should be useful for a pair of GTX 780s or 880s next year.
  29. SpongeBob
    SpongeBob The Contraceptive Under the Sea
    648
    Jan 15, 2011
    I have a new in box i5 2500k I am thinking about selling. I am not sure what I am going to end up going with it or if I am going to go for Haswell or maybe even switch things up entirely and get a AMD rig to play around with. The 2500k's can definitely OC well from what I've read.
  30. x3sphere
    x3sphere 2[H]4U
    2,622
    Dec 8, 2007
    I think I'll be moving to Haswell simply for the power savings... my X58 setup sucks a lot of juice even at idle and considering I leave my PC on 24/7, I think Haswell could bring a decent savings over a year's time.
  31. silkstone
    silkstone [H]Lite
    65
    May 26, 2013
    You proabably wouldn't be saving as much as you think. I'm not sure of the difference between Haswell and 1st Gen i7's. but compared to SB chips, the difference at idle will only be a few W.
  32. longblock454
    longblock454 [H]ard|Gawd
    1,622
    Nov 28, 2004
    True, saving a 1000 watts per hour here will save you $0.09hr here in Indiana. The price of the upgrade could take 10 years to recoup.
    I'm currently building a DC powered server were each watt counts, and the payoff is in the chase for the lowest consumption.
  33. x3sphere
    x3sphere 2[H]4U
    2,622
    Dec 8, 2007
    Compared to SB, yes, but overclocked X58 draws ~150W at idle for me. Comparable Ivy setups draw like around 80-90W. At load the difference is over 100W.
    I pay 0.26 per kwh on-peak in the summer and having less heat dumped out would probably make my AC run less too...
    It'll probably bring decent savings over a year. I wouldn't expect it to come close to covering the cost of equipment but it's still a nice perk.
  34. longblock454
    1,622
    Nov 28, 2004
    Another benefit, less heat = less fan speed = less fan power = less noise as well.
  35. c3k
    c3k 2[H]4U
    2,100
    Sep 8, 2007
    I'm waiting to see what Haswell brings, and for how much. If Haswell costs too much with not too much gain, I'll grab a 3770k and delid it. If Haswell is a win, well, then I'll grab a Haswell. I'll be happy either way.
    Ken
  36. BatJoe
    BatJoe Gawd
    836
    Apr 4, 2012
    Haswell is suppose to be hot just like Ivy. Big downside.
  37. trick0502
    trick0502 [H]ardness Supreme
    5,134
    Apr 17, 2006
    any word on microcenter bundles yet?
  38. EvilViking
    EvilViking I Drank All Your Beer
    1,248
    Mar 7, 2005
    ^This :)
  39. RamonGTP
    7,676
    Nov 9, 2005
    I'd think its a bit early for MC bundles, we don't even know the costs of motherboards yet.
  40. trick0502
    5,134
    Apr 17, 2006
    dont they usually do bundles on release day?
