The Lian Li Gallery
Discussion in 'Case Mod Gallery' started by Alexia, Jan 1, 2004.
  1. Makeroflostsouls
    Makeroflostsouls 2[H]4U
    2,547
    Jun 4, 2008
  2. jonneymendoza
    jonneymendoza [H]ardness Supreme
    6,252
    Sep 11, 2004
    thats the case im going to get. how did you paint it? got a step by step guide? how did u make more hole son the mobo trey also?
  3. PeteLightning
    PeteLightning [H]Lite
    88
    Aug 22, 2008
    for all the holes in the case i just used a dremel with the reinforced cutting wheel. i left about a 1/4" then went in with a file for the detail. For the painting i lightly sanded before i primed, let dry for about a day, lightly sanded then applied the second coat of primer, let it sit for another day, sanded then i used the same technique for the flat black making sure to get rid of all of the little particles between the coats. 2 coats of primer 2 coats of black total, all rustoleium. and to keep the flat black i did not use a clear coat. spray paint looks pretty good if you do it right. quick note, i got the case before the revision so i had no holes in the mb tray
  4. Benno
    Benno n00b
    3
    Jul 29, 2007
    Here is my new LianLi Chassi PC-A20!
    Take some time to ship this to Sweden....But now its here...:)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. Darkside
    Darkside [H]ard|Gawd
    1,249
    Jun 29, 2004
    @ Benno..haha nice case..quick wire job you did looks good too..enjoy buddy :D
  6. thebeephaha
    thebeephaha 2[H]4U
    2,054
    May 27, 2007
    DO WANT. That case is absolutely perfect.
  7. jaded25
    jaded25 Gawd
    667
    Feb 10, 2005
    Damn that case looks sick.
  8. cornelious0_0
    cornelious0_0 [H]ardForum Junkie
    12,783
    Apr 6, 2003
    Very nice LiLi Benno...and a pretty decent job getting it setup as well!
  9. Benno
    Benno n00b
    3
    Jul 29, 2007
    Thanks!
    I have change the fan to four 140mm,its was two to the beginning.
    Two to the front,one up and one down,one to the middle and one to the backside.
    Will change the harddisk holder to metal....you can feel the vibrations from the disk and
    there are the Lianli not good.At my lian V1100+ was the vibrations much badly...so metal
    to the disk holder!not alu.
    My temps is very fine now!About 5 to 10 degreeds lower against the V1100+
  10. rsquared
    rsquared Limp Gawd
    472
    Jul 5, 2007
    My PC-A16, after I cut holes for radiator bottom-mounting and behind-the-mobo cable routing, and had it powercoated.
    [​IMG]
    [​IMG]
    At front bottom is a four-switch panel; the first two switches control the interior lighting. The other two switches, as yet, do nothing. Not visible in the pictures, I made a small circuit so that when the computer is off, the Bulgin power switch glows dimly instead of being off---partly because it looks cool and partly so I can easily find the power button in a dark room.
  11. aznpxdd
    aznpxdd 2[H]4U
    2,354
    Jan 5, 2006
  12. cornelious0_0
    12,783
    Apr 6, 2003
    It's creative modding like THAT that'll get you noticed around here...very nice stuff! :cool:
  13. tonyh21
    tonyh21 n00b
    23
    Jan 24, 2007
    Got my AVAdirect computer a couple of months ago. Loving every minute! Build quality is great and everything has been working flawlessly. Changed to some quieter fans, Lian Li stock are pretty loud and don't push enough air.
    [​IMG][​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    LIAN LI PC-60BplusII
    CORSAIR, CMPSU-520HX
    ASUS, P5Q Pro
    INTEL Core 2 Duo E8400
    ARCTIC COOLING Freezer 7 Pro
    G.SKILL 4GB (2 x 2GB)
    SAPPHIRE Radeon HD 4850
    CREATIVE X-FI Titanium Fatility
    WESTERN DIGITAL 640GB WD6400AAKS
    LOGITECH Z-5500
    DELL 2407
    MICROSOFT Windows Vista Home Premium 64-bit
  14. Sirk1000
    Sirk1000 Limp Gawd
    222
    Nov 8, 2007
    ^Nice case. Take those damn stickers off the front of it. Plain and simple is the best
  15. TooBooKoo
    TooBooKoo Gawd
    902
    Jul 31, 2007
    Very nice indeed... I love the black with red lighting and that window is sweet.
    Nice touch, adding that circuit to the Bulgin ;)
  16. Benno
    Benno n00b
    3
    Jul 29, 2007
    Realy Nice;) rsquared
  17. cornelious0_0
    12,783
    Apr 6, 2003
    Agreed...that has always been one of my favorite LiLi cases...but the stickers are bringing it down. :p
  18. Jay_2
    Jay_2 2[H]4U
    3,583
    Mar 20, 2006
    She keeps messing with my seat hight, mouse setting etc becuase she didn't like how I had it set. It was pissing me off so I built her a new PC.
    AMD64 AM2 5000+ X2
    2 GB Corsair Twin2X XMS2 Pro
    Foxcon A78AX-K Motherboard
    RaptorX 150
    HIS HD 3850 Graphics Card
    500W Tagan BZ PSU
    DVD R/W
    Lian-Li V-1100 Plus (Black) - Best case I have ever seen, just pure quality but I suppose for around £200 it should be!
    XSPC X20 Delta V2 CPU Block
    XSPC X20 Compact 750 Pump
    10/8mm Tubing / Barbs
    R120 Radiator
    2 x 120mm Lian-Li fans
    1 x strange exhaust fan (not pictured but covers the graphics card area)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    (Its a bit of a mess at the moment.... clearing out as we should be moving soon, I hope!)
    [​IMG]
    I do look after her!
  19. dC0m
    dC0m [H]ardness Supreme
    5,285
    Aug 21, 2008
    Damnnn, all those Lian-Li looks so sexy.
  20. Sirk1000
    Sirk1000 Limp Gawd
    222
    Nov 8, 2007
    well heres my case that i just finished painting will take more when i get my 2nd 4870.
    shitty camera
    [​IMG]
  21. TooBooKoo
    TooBooKoo Gawd
    902
    Jul 31, 2007
    I like it.
  22. jnex26
    jnex26 2[H]4U
    3,353
    Aug 7, 2001
    Well I Thought I would add to it.
    [​IMG]
    From Left to right.
    PC-A05B (Intel Quad Core Q6600)
    PC-65B (P4 2.8Ghz Northwood)
    PC-A07B (AMD64 3500+)
    Sorry about the not great picture, my digi cam seems to highlight finger prints
  23. pvtdonuts
    pvtdonuts [H]Lite
    94
    Mar 16, 2007
    Finished putting mine together the other day
    [​IMG]
    [​IMG]
    [​IMG]
  24. solaris54
    solaris54 2[H]4U
    2,162
    Jul 14, 2007
    These Lian Li cases are beautiful!!! WHich one is best case for the long video cards like the 8800 or 9800GTX and SLI?
    Someone on here is selling a Lian Li 1200 PlusII wouldl that work?
  25. CLock3
    CLock3 Gawd
    898
    Oct 9, 2007
    yeah, a v1200 would easily fit those cards, with plenty of room to spare.
  26. Ryle
    Ryle [H]ard|Gawd
    1,053
    Jul 16, 2006
    @pvtdonuts... that double accelero setup looks slick. very nice looking case. i see you modded the 5 1/4 bay to hide the optical, you use double sided foam tape? thinking of doing the same.
    Here is my A05, scratched front panel being dumb ~_~ take a sharpie to it i guess heh.
    [​IMG]
    [​IMG]
    This is what i did with the hdds and front fan. the fan blade it taken off for the pic of course.
    [​IMG]
    here is a more clear shot of hdd rack that im so proud of :D
    [​IMG]
  27. pvtdonuts
    pvtdonuts [H]Lite
    94
    Mar 16, 2007
    Thanks Ryle, I used velco on the optical just in case I ever need to reposition it and also it comes off alot easier than double sided tape does. The fan controller is a Zalman modded into a LL panel as well. I like what you did with the HDD's, very clean, i've been contemplating makeing a hole for the front fan, but I just can't bring myself to do it haha, I usually just leave the front off if it gets too hot
  28. solaris54
    solaris54 2[H]4U
    2,162
    Jul 14, 2007
    Are there any other models that would work preferable with no fan on top?
  29. TooBooKoo
    TooBooKoo Gawd
    902
    Jul 31, 2007
    I'm using a V1000B and an 8800 with plenty of leftover room... most of the V Series cases are fine... you'd probably be fine with the A05 as well, I've seen people pack those little boxes with some serious hardware... pvtdonuts' A05B a few posts up is a good example of this. I would even go as far as to say most of the Lian Li mid towers would have room to do what you want... but if the price is right I would go for that V1200 you mentioned... that's a nice case.
  30. TooBooKoo
    TooBooKoo Gawd
    902
    Jul 31, 2007
    Just trying my hand at some night shots...
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  31. brydon10
    brydon10 Limp Gawd
    246
    Aug 29, 2007
    TooBooKoo, I love the setup and I really like the artwork. Nice case btw ;p
  32. Jay_2
    Jay_2 2[H]4U
    3,583
    Mar 20, 2006
    its a bit too much for me that one! lol
  33. TooBooKoo
    TooBooKoo Gawd
    902
    Jul 31, 2007
    Thank you :)
    Yes, sometimes it can be a bit overwhelming :eek: that's when I just turn off most of the lighting. I also just replaced the red Antec Tri-Cool fans with some more conservative SilenX fans... those Antecs are noisy.
  34. 2red
    2red [H]Lite
    87
    Sep 6, 2008
  35. AMD_RULES
    AMD_RULES 2[H]4U
    3,010
    Mar 26, 2007
    :eek: Wow 2red! Awesome wiring job and pc!!! :eek:
  36. Blazestorm
    Blazestorm [H]ardness Supreme
    6,940
    Jan 17, 2007
  37. Darkatom
    Darkatom [H]ard|Gawd
    1,186
    Jun 2, 2006
    That is 110% pure pron. Great Job!
  38. looks
    looks n00b
    21
    Feb 28, 2007
    I'm guessing you misplaced and misspelled those words on the fengshui poster on purpose.
  39. Darkside
    1,249
    Jun 29, 2004
    Looks good to me so far...and there isn't any hardware in it yet..:D
    dont forget to let us see your updates...
  40. kadozer
    kadozer [H]ard|Gawd
    1,881
    Jun 29, 2007
    Looks just like mine right now with the parts inside painted black. Cutting it today for a 120.2 Radiator up top. The case is so delicate I've never been so cautious of screwing up.
