faugusztin
- Mar 9, 2008
heres a couple small pics of my v1000... i'll put my pics of my water rig when its done.
I guess you were dissapointed by color of mounting mechanism of TRUE Black 120 too like i was
Got my PC-V today, to go along with the old faithful PC-65 (~5 years old). I'm dissapointed. In short, I bought the case from directron after viewing their image (no side fan), and even calling to verify that's what I was getting... I don't like the mesh at all!
I called them late this evening so gonna see what they can do for me. I'd settle for just a blank side panel, and I'll cut my own window...
Did as much cable management without modding, I still need to find a suitable controller for the cathodes, I was shipped the wrong combo as well, but can't always get what you want... with some of these guys
thats EXACTLY what happened to me.... i got sent the wrong version mine is actually the Plus version but i couldnt stand the mesh so i got the company (Puget) to send me a plain windowed side panel from performance-pcs.
and to the guy above, i put my fan to exhaust out the rear as ive got my TRUE facing the back of the case.
As i said in the wiring thread...looks very nice considering there haven't been any serious mods to the case.
Can't wait to see it with the TRUE installed, good job man.![]()
I'm going to chime in here...
Also, IF you're in the Toronto area and are THINKING about buying a big ass custom case that costs more money than most budget systems...DON'T...Get a hold of Lanpirate, and for the same (or less) money, he can build one for you.
VERY VERY nice PC-A05 man...the nicest I've seen I think...PM me or post more pics if you can.![]()
Is the heat pipes still a huge problems for the R-atx cases? I got my v1000b Plus 2 and now im sorta panicking about finding a mobo without heat pipes, should I not worry?
I am humbled by your words sir..
And for you gallery fans, her's a pic from this summer of another project. Name that Lian-Li!
Sounds good! Thanks for the info!Its only a problem with extremely cheap motherboards with solid metal pipes, which are not real heat pipes. Which I don't think really exist. Heat pipes work in any direction, due to the wick; rATX orientation will not affect anything negatively - it may help with cooling due to heat from expansion cards (such as graphics cards) being able to move away from the card rather than up towards the card, then up into the CPU HSF (depending on card and venting)
lol, no ram in the pics, and the top i/o door was not on yet. I reversed the fans to blow out the back, works ok with water cooling.
I dont have any work logs in the forums here. I have many pics, as most of us do who mod PC's, in folders on my hdd. I could post some of the Lian-Li pics here. I have Antec and coolermaster builds also. I will start a worklog for sure if VolvoR's client gets me to build his next PC. I think its going to be a Cosmos though.do you have any work logs to see some of your other work..pls post thank you
TooBooKoo..what camera are you using man..the system look hot (RED HOT)
But ya need a little focus so I (we) can see the details...Outstanding custom job tho for Sure !
Thanks man...
I am using a Canon XTi 400D... and I'm still learning how to use all the features on it![]()
I'm still working on the sidepanel / window, and my lights just arrived. Pics will follow =)
But that's how I did the top with 3x 120mm fans. They are covered by LianLi fan covers (the ones Lian Li installed in the back).
toobookoo..was this item hard to install ??
Or is it and easy swap from the the other switch to this one.. thanks
love your box...red red wine![]()
Oh..kool..where did ya purchase it from .??
TooBookoo..why should I get that ?? Are there different version's ???
