Nice! I want one of those 5.25bay fan covers. Wait, I *need* one of those.
Yeah, I agreesee my post. I sold my mesh covers on eBay, though. My increased airflow comes through the 3×120mm-fan radiator mounted to the bottom of the case.But I liked the look of the original "sleek" covers better, so I bought 6 of the original style covers to replace them: .... but I still have the mesh covers if I want to increase airflow
Here are some of my updated rig.
I modded this Lian Li PC-7 plus II for a good friend/customer. The paint style is refered to as "shreds" the paints are House of Kolor. 250mm cooling fan with dragon fan grill
Interesting project. What's the direction?4 Hdd (6 in the total)
almost forgot, the radiator on the top, it is 240, but can be 360
the Psu
the drives
I think another project has 1 like these, sry, the ideia to use these drive was not from that project
I bought one of those for my V1000 and it did not fit.
I can't say it won't fit for other LL cases, but the 1000 has standard screw slots and the 343 bay fan has non-standard looking screw holes that may be special and exclusive to the 343 case only. I couldn't even screw it in, period. I installed it, letting it sit loose, but it wasn't an ideal fit so I ended up sending the part back to PPCs for a refund.
Actually a pretty clever place for the radiator. And while I agree that it looks fine, I think it would be improved by a radgrill over it, on the outside of the case. It'd also keep the radiator fins protected from dings or damage.Apart from the radiator brackets,which i am gonna grind into nicer shapes,it looks fine.
Carholmes-does your case produce a lot of noticeable humming noises with the pump attached directly to the motherboard tray like that?
What cooling gear is that?Insert images here.
Actually, I believe it's the Double Impact. Yes, it's VERY restrictive.Is that the aqua-computer cuplex hd cpu waterblock in your rig? Could you let me know if the flow rate is restrictive or no?
Its Fuzion V1 w/ promount, MCW-60 w/ D-tek Unisink, MCP-655, MCR-320 w/ 25mm "shroud" and 38mm Sanyo Denkis 1011, EK Res 250, and feser one coolant.What cooling gear is that?
