The Lian Li Gallery
Slammer,
3.5 bays and usb at front is used by most computer users, if this was taken away I think there would be a drop in sales.
A removeable Mboard tray with a 120mm fan would mean a much wider case.
Do some modding!
Noni said:
Slammer,
Do some modding!
naaah, a removable mobo tray with 120mm wouldn't be wider at all. if so maybe a tiny bit. but i might have to do some modding though. the problem is though, if say i do put a 120mm where the floppy is, how is it oging to get enough air flow to really be worth it?
I agree with you about the 3.5" bays. No one ever uses those anymore, and if they need to fit a 3.5" device in there they can just get a converter. Cases should be all 5.25" bays IMO.
Or the manufacturer could go as far as to include a converter like the one used in the PC-6077...good call...but in terms of more than one 120mm fan up front...I've got a solution for that, just need to funds to start the project...it'll be a nice one. :D
Well I have to disagree, I have a 13-in1 Card Reader and a fan controller that are both 3.5" devices, and it irks me that most of the newer high-end cases that I'm interested in (V1000, Stacker 810, etc) either don't have the external bay, or they have to use a converter (and they only come with one).
Not to mention all those people with pricey Matrix Orbitals and other LCD screens that fit nicely in the 2x 3.5" external bays.
im having the hardest time fitting my hardware in the v1000 .. its so damn tight .. i have everything in .. but putting the fan back on the ninja is virtually impossible while its in there ..
hard ware is
ocz powerstream sli
sli'd 512mb 7800 gtxs
xfi fatality
bfg ppu .. 3 hds
dvdr
Good call man, I guess there is still a bit of a market for 3.5" drives after all. Personally, I won't be using ANY external 5.25" or 3.5" drives if my project I'm planning gets off the ground...USB cdrom/floppy all the way baby!!! :D
monopixel said:
I like tight installed system like DELL's small desktop , apple's and etc :)
They look nice in their own right...but I also prefer the big open cases with perfect wiring jobs so that all you see is the emptiness. :p
Those lcds don't fit in 3.5" bays, they fit in 5.25" bays. I'm just saying that everything that can fit in a 3.5" bay can either be modified to fit in a 5.25" bay, or is available in 5.25" size, but not the other way around, and it kinda irks me that I have so many things I'd like to put on my front panel but I have no room to, and yet I have these two empty 3.5" bays taking up space. :(
Sorry aldy402...that bright orange fan and the placement of the UV ccfl's just don't do it for me. It's nothing personal, but IMO that's one of the tackiest (sp?) V-series setup's I've seen.
The Fidelity box :D
Side panels come in next week.
More, better, pics to come tomorrow
Thx for the pics, but the utter mess of wires and whatnot in that first pic makes baby jesus (and me) cry... :(
well just got everything into my v1000 .. i wish i would have gotten the 2000 .. there is like no room to hide anything .. ive got wwires EVERYWHERE .. im just not happy at all .. i got TONS of work ahead of me ..
pls video cards are idling pretty high as well ..
I dunno man, a lot of it does have to do with the number of drives etc that you're working with, but I don't think it'd be TOO bad. Just comes down to how creative/resourcefull you're willing to be in terms of cutting up the case to simplify the wiring and keep things generally tidy inside.
I'd like the challenge of wiring a V1000, but I've got my own challenge ahead of me I have to start planning for.
you jsut got to plan it out, it took me 25 mins to install the mobo, cpu, heatsink, ram, vid cards, DVD burner and HDDs, then it took me 2 more hours to wire it, i have a LOT of wires showen jsut look at both sets of pics i posted, what wires are seen, make them look good, i HATE UV lights with a passion, but they make the cables you seec on my mod stream look good so i have them
wireing is the hardest part when your building a comp in any case, let alone a v1000b
HRslammR said:
instead of the floppy drive and those up front usb connectors (who uses those anyways?) put another 120mm fan in there, and make the mobo tray into a removable one? and modify the front panel in a way to allow for more airflow (aka more holes), everything else about the case is just lovely!
why why why why!? it'd be so amazingly awesome if they could just do that. /cry
umm *looks at his USB connecters and sound connecters* hmm, if no one really uses them anymore as you make it sound, why is my headphones and mike pluged in, an y the cable to my digi cam and my xbox conttroler? if anything they need to ditch the firewire shit and give me one more for my thumbdrive
and i like the floppy drive now that i found a use for it, it helps bring air in to my case and offers a spot for my lights's switchs to sit
looks like i'm just going to have to butcher up my case. (again)
edit: can the pc61 readers who read this, take out their floppy cage and tell me the size of the opening that it makes? and if you have a spare 120mm fan will ya put it up there?
i'm gonna make this thing work damnit!
How come now? :p
It's a nice rig.. yes, you have some cleanup to do on the wiring.. but these things are works in progress. :D
Anybody got any pictures of the PC-6070b Plus case? Its the Black Li Lian with the door. I am interested in getting one, but the pictures on the net aren't that brilliant and do not give you an idea of how it will look with pimped out kit.
Here's my V1200-B. the stray grey sata cable will be replaced by a black mad dog sata cable the next time i get to indy. i should've bought 6 of them the last time i was there :(. there are blue cathodes behind the front panel but they're turned on very seldomly.
For shame! My favorite thread pushed back to the second page?? NEVAR!!
I recently improved the cabling and fan control on my PC-7B, and finally fixed all the lighting issues (it now lights up completely, without buzzing sounds, and I finally have a switch on the outside instead of taking off the side panel to turn it off before I go to sleep). Here you go...
As far as the PC61 front goes, it's only tall enough for two 3.5" drives to fit. A Lian Li 3.5" bezel measures 1" wide and 4" long. So that opens up a space 2"x4" You could make a bracket that would either house two 40mm fans or you could cut down from the top of the 3.5" area and filterright the front of the case with a 120mm behind it. I wouldn't attach the fan to the front though; then you couldn't take the front off easy enough. Also be careful to not go low enough you run into the bottom 120mm fan. If you are in need of more ideas to get more air inside your case, let me know what you have and I can send some your way. Hope this helps!
on my pc-7b i have front panel audio and firewire white think cords that are not being used (the usb one is) right now they are just lying along the bottom of the case (looks messy) where have you guys put them that hide them from view? also what about the power/reset buttons/lights cords. those are just out in the open too, where should i try to hide them?
and this is slightly OT, but for the audigy zs 2 platinum the front panel thing has a ribbon type cable, what would be the best way to route this from the sound card to the 5.25" bays? down then up the side?
where are all your cables hidden on the pc-7b's above? i tried putting htem in the 5.25" bay but there sure are alot...any ideas.
sorry for not haveing any pictures posted.
my case isnt special at all compared to the stuff above!
DaReal: I think It's time to get a windowed sidepanel.
Scrawnypaleguy: Looking good, as always. White cathodes for the win.
Thanks Bbq :cool:
Vulcanworlds, try moving the cords to behind the motherboard tray. That's what I did with the unused firewire and audio front panel cords on mine. As for the power/reset switches and leds, I covered them all with the split loom tubing you see behind the hard drive. All those ugly wires are stuffed in there. You can pick it up lots of places, I got mine at staples, but there are others too. Good luck with yours!
Why do you need 3 cd/dvd roms?
guys i need some help .. all u v1000 owners .. are any of u running SLI ..
my temp are out of control .. right now .. just idling .. with the side panels off my 7800 gtx 512mb cards are at 50 / 49 c .. with the panel on .. its like 7C higher .. this is insane .. and my chipset is like 49-50c idling .. is this case really that bad for high end systems ??
cuz im seriously considering selling it
Ok. I don't own a V1000, bu according to the sli guide:
best
40c -> 49c zone = awesome (water cooling or ridiculous air cooling)
50c -> 59c zone = great (high performance air or low end water setup)
60c -> 69c zone = very good (very good air cooling or over-loaded water setup)
70c -> 79c zone = good (typical air cooling)
80c -> 89c = warm (slightly inadequate cooling - some artifacting can occur at mid to upper 80s)
90c -> and up = too hot (artifacting and app crashing can occur at this temp. time to check all fans for dust clogs and/or re-think the cooling scheme).
worst
Also, for the chipset, try swapping out the thermal pad for some as5. You'll get better temperatures.
best
worst
what sli guide ? and are those idle or load temps ??
cuz in my stacker my cards would idle at 44-46c
