The Lian Li Gallery
cornelious0_0 said:
Sorry bro...I hadn't been paying attention to the Case Modding forum for awhile and I must have missed it...but thx for the link...definitely checking it out.
well, you got a LOTTA reading ahead of you! grab a beer (im on ma 3rd) and enjoy!
No beer at work bro...and nobody likes a drunk tech support agent on the phone. :p
Thx though, I checked out the last page for pics and I'll do some reading tomorrow. :)
Hello all, I've decided to lose my [H]ard virginity. How better to do so than with my first Lian Li build. It's not as exciting as some of the amazing work I've seen on here, but it gets the job done for me. It is still not functional as you can tell be the absense of a video card, I haven't decided on whether to go the single 7900gtx route or see whats up with crossfire, I will probably go with a single 7900gtx.
The only real mod i did (cut opening for wires)
System specs:
Koolance PC-725 (modified V1000 with Eos2)
Asus P5WD2-E 975x w/native DDR2 800
P4 3.4 HT (will be clocked)
2G Corsair XMS2
2x 74G WD Raptors in raid 0
1x 400G WD Caviar w/16m
2x Sony DVD burners (Dual Layer)
Hiper Type R 680w
Mitsumi 3.5 card reader combo deal
This was my first water cooled build and i was concerned about the voltage caps and regulators around the cpu socket. They hover over the board and direct a little air flow, I'm sure the rear mount 120 would do just fine, but i thought it was kinda neat.
why not go with a single x1900xt?
yeah.. another reason why i still have no card. that may be the best option, allowing me to go crossfire in the future. hmmm...
sorry to quite a pic, but taht is the number one cut to do to a Vseries
i wish lian-li would do that cut normaly
I just really wish Lan Li would make there more room behind the motherboard so that you
can run more wites behind it. and somthing that will alow us to run our cables easier up
the side of the case, if you know what i mean.
Decent enough setup you've got going spint3.
Unless you're REALLY hardset on HDR+AA I'd recommend going with a single 7900GTX. The 7900GTX and X1900XTX are very "on par" in terms of performance, but the 7900GTX runs MUCH cooler and has a quieter stock cooler then the X1900 by far. If you were going to add the videocard to the h2O loop I'd even more strongly recommend the 7900GTX...as it won't have as much effect on your water/cpu temps. I'm no !!!!!!, I've got just as many reasons to go with the X1900XTX, but they aren't nearly as practicle...I honestly do just think nVidia has the better card this time around.
[H]Opterown said:
Are the little 40mm fans loud? I want to get a couple since to blow on memory and N. S. bridges.
I don't think they are very loud at all, they are far quieter than any 80/90mm fan i've had. They sure can't be heard over the four 120's in the case.
I want to put them over my hot chipset as well on the uncanny a8n32
I got them from xoxide, link:
http://www.xoxide.com/40qublledfan.html
they come with a two pin connector, i snipped that off and soldered them to the pins from a standard 3 pin and snapped them into a super cool blue plug. the fans are light enough to be supported by the fan plug. I used a stainless steel bicycle spoke from work and bent that to aim the fans. A little clear epoxy holds the spoke to the fan and connector.
Some really nice stuff in here. Just wondering how much money one generally needs to get one of these projects going?
Haha...the old saying "If you have to ask how much it costs..." might come into play here. ;) :p
No seriously, different Lian-Li cases come in at many different prices, and in terms of the mods, it depends on the resourcefullness of the modder...how much they can do on their own in terms of painting/cutting without paying someone else to do it, and how many spare parts/toys they need to buy to get things rolling.
There isn't really a straight answer, but the most basic cost would be that of the chassis itself obviously.
Brilliant! I love the simplicity of that idea.
Hey...very nice indeed...beats just laying the fans on the case or proping them up against your video card or cpu hsf. :p
Woohoo! I got my tax return, and that means it's time to accessorize! :D
I was going for kind of a "voodoo pc" look with the white cathodes. I've got one 12 inch at the bottom, and hiding up top is a 4 incher. I'm very pleased with the brightness; they're much better than the cooler master ones I first tried.
Just finished building my new PC-V600 Li Lian rig and it is brill! Very compact and very sleek. I have used Li Lian DVD Covers and a double bay LCD Display. I have also kitted it out with the latest stuff (7900GTX, 4400+ Processor etc and the temps are quite reasonable.
http://homepage.ntlworld.com/david.one/DSC00210.jpg
I will try and post more pictures when I have some better light!
[/FONT]
Yeah, that's very cool. I like the white lights in it. Very clean also. How do you like that Arctic cooling fan? Is it quiet?
[/FONT]
What LCD displat is that? It would go very nicely in my LL case too. :)
Thanks. I like the AC fan, it seems to be extremely quiet, it's only barely audible at full speed. I'm not sure if this is simply because of the special bracket it uses or maybe it's just because it's inside my case and the noise doesn't have an immediate place to escape like my normal front and rear fans.
Also, due to the special mounting bracket, it doesn't have holes for the clips on my SI-120, so I ended up attaching it to the clips with twisty ties. Just fyi in case anyone wants to do the same thing I did with it.
ChinDave, that V600 looks really sweet. the positioning of the psu really made me dislike that case and the new G50 and I thought no one would get it. Could you please post some internal shots so we can see what it's like with a system inside?
^^^^^ That's cool. Did the CD bezel come with it? Did you make it out of one of the empty slot covers? If you did, how do you eject it, only from Windows?
edit: Whoa, apparently, I'm a GAWD now. Bow to me... :D
it was just one of the covers that came with the case....all u need to do is just bend the edges back and forth and they will snap right off...then sand it down so it is all smooth then get some double sided tape and to attach it to the cd tray and also u need to use a piece of double sided tape with a piece of cardboard or something that will hit the button so u can open it
I did my PC-65 the same way. Cut the little tabs off the covers that it comes with. Use double sided foam tape to stick it to the drive. Put tape on the drive plate where the eject button would be but double it up. Make it so that it is only sticky on the plate, not the drive. That way you just have to push on the plate and it opens up. use the button normally to close it. You have to fiddle with the tape to get it the right thickness so that when the drive closes it doesn't open back up again.
Looks nice BTW eab16hatchie.
Nice stuff eab16hatchie...I love the stealth'd drive and blue LED fans...reminds me of my old PC-60 before I went mad modding it. :p
scrawnypaleguy...the white ccfl's look quite good...brightness level is nice, and the setup looks very clean. The AC fan does look pretty cool in there, but those heatpipe HDD coolers aren't really necessary as far as I've seen.
Got any pics from "straight on" looking at the side panel...I just wanna check out your wiring a little more.
eab16hatchie, let's see some internal shots! That looks like a really sweet build, I love the blue.
Cornelious, I'll try to get a better angle and post some other pics soon.
