cornelious0_0
- Apr 6, 2003
Awsome...even though the case isn't for me...I've still been waiting on some pics of the new boxes...I'll be waiting. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
CrAzYsPyDeR said:its that lian li with a mini aquarium http://www.newegg.com/Product/Product.asp?Item=N82E16811112098
TheSandman2236 said:el rolio; what kind of fan controller is that...?
Tman said:First off very nice man. Also.. i really didnt mean to flame you or etc at all. Please pardon me for that.
Here is my rig that I just redid a little while ago:
what do you guys think?
NortHWizarD said:I can't wait for my V1000 so I can slap my peltier system in to it.
~NortH~
CrimandEvil said:I was just about to post that.
http://www.jab-tech.com/Sunbeam-5-1-4-Rheobus-Kit-Silver-pr-2529.html
I take it you like it?Been thinking about picking one up.
aburgard said:I took some model paint and painted the LEDs down to tiny pin prick lights. They stopped lighting up the room then. The black paint looked like it belonged there.
NortHWizarD said:Can you tell me which way you have the coolant flowing in teh last picture there?
It looks to me that you have the outlet of the water pump going to a 'Y' fitting then in to the RBX water block... if so... that is completely wrong... the center single fitting on the RBX is the inlet, the 2 outer ones are the outlets.
If that is actually coming back to the pump... then you are pumping in to the reservoir first? well... definitely not the way I would be putting it together... my reason is... those fill caps on acrylic reservoirs are horribly prone to leaking... and if you are pumping *in* to the reservoir... it will be somewhat under pressure, compared to sucking out of it, and will be completely filled and could push coolant past that seal on the fill cap and start to leak... I, and most people's systems I have ever seen, draw coolant from the reservoir and then pump to either a water block or the rad first - not that it really affects the cooling at all, although a lot of people seem to think it does.
but it is one heck of a nice looking system... great job on it!!! Love the case and looks of everything... and I am sure it is a real powerhouse.
~NortH~
TheSandman2236 said:cornelious lets see your pc; im curious to see what yours looks like! XD Is yours watercooled?
cornelious0_0 said:Very nice wiring job FullMetal...one of the best I've seen with that chassis.
FullMetal said:TY I had to order those long Sata cables tooWhen I made it I realized that .. um, there is no way that the standard cables were going to reach all the way to the bottom of the case....the long cables are cool anyways, they are sleeved black in stead of those red or orange ones
scrawnypaleguy said:Slick man, VERY nice... is that black electrical tape? I love that stuff!
FullMetal said:I got the SATA cables from Voyermods.com
Everything else from New Egg
The cables are wrapped in cable sleeving from the local automotive store. Not tape - it is plastic.
tho...have used tape beforebut this plastic sleeve stuff is cheap and looks good IMO.
EDIT: as far as heat - no issues, this is on 24/7 and I game alot. When not working....but nah those ram sticks are not having any trouble. The new MSI MB is much nicer too, having the heat pipes ect. Only thing to really get hot is the bottom video card, but solved that issue by putting in a fan to blow directly onto the video cards......
phoderpants said:Well that's good to know that the heat pipes work upside down in the LL cases. I was worried about that myself. Care to provide temps?
cornelious0_0 said:And I must say...the 4 sticks of Corsair Pro do look really cool side by side...might increase temps a bit...but I bet it's slick when they all start workin'.![]()
el rolio said:actually its ballistix, which i like better cuz they are FAR less bulky than the corsairs.
NortHWizarD said:then you are definitely using that RBX block WAY wrong then.
you have a 'Y' fitting at teh outlet of the water pump... splitting into 2 lines... and then those 2 lines are flowing *in to* the outlets of the RBX water block... you are supposed to have the coolant flowing in to the center nozzle/inelt - underneath that barbed fitting is a nozzle for directing the coolant flow - and depending on which nozzle you have in there, it can be like the storm... so... you really should switch that and fix it... make it right... I am betting you will see a nice difference in temps... that block was designed specifically to only flow one way... and that is *in through the center fitting and out through the 2 outer fittings*
if the picture is correct, and you say that you are sucking from the res and pushing out to the CPU block... then is is for sure installed 100% wrong.
this is copied right from the pdf on Danger Den's site for installing the Danger Den RBX Water Block...
4. The center fitting is the water inlet. Attach the water inlet tubing to the barb. Use a hose clamp to secure it.
5. The outer fittings are the water outlets. Use an appropriate length of hose (~ 6 inches or 15cm) and attach to the included Y fitting. This Y fitting is used to convert the outlet streams back to one line.
that should clear it up... and I would bet you get better temps with the water flowing the correct way, since they were designed specifically to perform with water coming through the center inlet and spraying directly over top if the CPU die.
~NortH~
Tman said:I thank you for your help. BUT.. at first i did what you have told me. I then swiched it to this way and my pump now flows in the correct direction. Believe me man... it fooled me. I even tested it like this and the water flows the right path.
mine is special :l
cornelious0_0 said:Sorry for not commenting before el rolio, but nice setup...I'm lovin' the Aquaero...got a writeup of your build/watercooling loop anywhere on [H]?
el rolio said:yea homie, its the thread in my SIG!here ya go: http://www.hardforum.com/showthread.php?p=1028188352
and of course the most recent work is on the last page of that thread. dont tell me you have never been to me+rev's worklog before!!?!?!?!? that would be a travesty!
