Star Wars Outlaws
Status
Not open for further replies.
the game just came out on August 30th...25% is actually a bigger than normal discount for a less than 3 month old game...what are you expecting, 75% off?...a 50% discount?
Matter of fact I am expecting that thank you very much.
Will need to wait a bit longer. I have to assume sales will rebound a bit with a Steam release. Though I also think by January you'll probably see this for 35% or so off, maybe more.
STAR WARS OUTLAWS
Title Update 1.4.0
Outlaws,
Our 4th and biggest patch yet has just been deployed for Star Wars Outlaws across all platforms!
This Title Update brings changes to combat and stealth allowing for greater player choice, the ability to now keep pick-up weapons in more situations, visual options to allow for a sharper image and much more to improve your journey across the galaxy. You can find the complete list of changes below.
Also, we have just deployed a temporary hotfix (v1.4.1) for players who were experiencing issues playing on Windows 11 24H2. Please note that you may experience some performance issues while we work on a more permanent fix. As soon as it is ready, we will let you know. Thank you for your patience.
We also want to thank you for all your feedback, especially in our Bug Reporter tool, as it truly helps us to provide you with the best experience possible. You can also use this tool to track the status of previously reported issues. Find details on how to report your bugs using Bug Reporter tool below.
Thank you for your support and see you in the Outer Rim!
PATCH DETAILS (version 7309905):
  • PlayStation®5: 7.44 GB (version 01.004.000)
  • Xbox Series X|S: 10.18 GB (version 1.0.4.0)
  • PC: 8.83 GB (version 1.0.4.0)
NOTABLE CHANGES:
  • Notable updates to stealth and combat that allow players greater choice, including using stealth or reaching for their blaster, even in syndicate territories in cities.
  • Enemy AI and detection improvements, with players being notified when they're being detected and can choose to escalate or change tactics to remain in stealth.
  • Enemy weak points have been added to reward strategic gameplay, which if targeted can trigger explosions or cause enemies to die in spectacular new ways.
  • Re-tuned Kay's blaster and pickup weapons to improve the combat experience, including being able to carry two handed weapons in more situations.
  • Facial expressions and animations in dialogue scenes have been improved, the option to toggle off the cinematic lens during gameplay has been added, and the visibility of distant lights has been improved.
FULL PATCH NOTES:
General Gameplay
  • Fixed an issue where players could get stuck by not being able to take off using the Trailblazer after certain missions
  • Kay now holsters a two-handed weapon in more situations such as when climbing, grappling or using the speeder
  • Improved AI speeder usage
  • Improved enemy detection
  • Improved enemy tactical decision-making in combat to encourage more active management of their positioning
  • Decreased enemy damage per shot while increasing the damage cadence increase over time
  • Improved detection signs and feedback of cameras
  • Player state (crouched, standing) is now kept after traversal actions
  • Fixed an issue where only one NPC would be alerted when whistling
  • Fixed an issue where the player could remain undetected in high grass while performing aggressive actions
  • Enabled the use of combat in parts of syndicate districts
  • Added weak points to various enemies
  • Adjusted weapon aiming (spread, recoil, etc.) to allow for more precision and management
  • Updated weapon damage values for Kay for all weapons
  • Increased headshot damage when hitting enemies
  • Improved blaster module usage (Ion and Power)
  • Removed player blast damage from the Power module
  • Added enemy stagger to explosions
  • Added body part-specific death animations to improve combat satisfaction
  • Improved NPC cover usage during combat
  • Fixed an issue where Kay would put away the holotracker when crouching
  • Fixed an issue where hostile NPCs were sometimes marked as friendly and could not be damaged by blaster fire
  • Adjusted jumping to give more control in the air of where you will land
UI, HUD and Settings
  • Added visual indication of when an NPC starts detecting the player
  • Added text highlighting which blaster module should be used when aiming at heavy guards, droids and cameras
  • Prompt to ping the tracked objective is now more prominent and affected by HUD visibility settings
  • Added icons to environmental objects that require unlockable abilities
  • Improved Nix quick action icon by highlighting button when having an active target
  • Made it clearer whether a takedown could trigger combat
  • Added NPC tags above their heads (works with existing colorblindness settings)
    • White - Neutral
    • Orange - Aware
    • Red - In Combat
  • Adjusted Adrenaline Rush cost based on difficulty
    • Story mode - 100% (unchanged)
    • Normal - 110%
    • Challenging/Hard -150%
  • Improved wanted system messaging and display
  • Fixed an issue where some gear effect icons were not showing correctly
Audio
  • Improved enemy dialogue when they are going in and out of cover
  • Fixed an issue where sound wouldn't play through the DualSense controller on PS5
  • Fixed an issue where arcade games would be missing music after starting a new game
Cinematics
  • Added facial animations to gameplay dialogue scenes and vendors
  • Improved animations and visuals of some dialogue scenes
  • Fixed an issue where ND-5 would be missing from the passenger seat when landing/taking off from Renpalli or Achra stations
Camera
  • Improved camera when shooting, aiming down sights, and moving aim
  • Improved cover camera, including the ability to manually shoulder swap when aiming
  • Improved the camera by showcasing a better view of each shop when interacting with a vendor
Worlds, Fauna and Flora
  • Fixed an issue with destructible flora
  • Fixed an issue where the visual effects created by waterfalls were broken
  • Increased the distance at which lights can be seen in the world
  • Improved the visuals of some grass textures and mud, especially at distance
Photo Mode
  • A new clean lens has been added
Accessibility
  • Added a Custom Controller Preset to allow remapping of individual buttons. You can choose separate sets of button swaps for Kay, the speeder, and the Trailblazer.
  • Added a new 'strong' aim assist setting
  • Added a new auto-transfer option for climbing, which lets you automatically hop between climbable objects by moving towards them instead of having to press a button
  • Added setting to change how large and clear the effect showing the security camera detection area is
  • Sound effects slider split into two separate sliders, for gameplay sounds and background sounds
  • Faster menu narration, settings now go up to 400% speed.
  • Menu narration now reads lockpicking and slicing minigames, objective hints, and which Sabacc card is currently highlighted in your hand and while drawing/discarding
  • Option added to toggle the Cinematic Lens (distortion, fringing, and vignetting effects) off for gameplay
  • 'Fill screen' is now the default screen ratio, meaning larger text size for the initial menus before you reach the ratio setting screen
  • 'Remove all' hold input for map markers added to 'change holds to presses' setting
  • Descriptions of accessibility settings reworded for improved clarity
Miscellaneous
  • Fixed an issue where destroying a ship by ramming it would not count towards the 'Never tell me the odds' trophy/achievement
  • Fixed an issue where the 'Shoot First' achievement/trophy and 'The Better' ability could not be unlocked at the same time
  • Fixed an issue where defeating Death Troopers during certain missions would not count towards the 'Defying Death' Ubisoft Connect Challenge
MAIN & SIDE QUESTS(beware of spoilers)
Toshara
  • Rejected
    • Fixed an issue where Kay can't listen at the bar to progress the intel quest
Tatooine
  • The Veteran
    • Fixed an issue where the quest line would not start if travelling to Akiva before the dialogue finishes
  • Partners
    • Fixed an issue where the cinematic would not trigger if using Adrenaline Rush as the Rancor hits the hangar doors
Akiva
  • Revelator
    • Fixed an issue where ND-5 could spot Kay when going from crouched to standing while on a steam vent
Bug Reporter
We're pleased to announce that reporting issues will now be easier- introducing the Star Wars™ Outlaws Bug Reporter. This website functions the same way as on other Ubisoft titles; it's your direct channel to view issues reported by other players and to directly report any issues you encounter to our team. We will actively update this board so you will be aware when issues are being investigated, and when fixes and improvements will be rolled out in an upcoming update.
To report a bug:
  • Go to the Bug Reporter website
  • First, browse through the issues to see if your issue has already been reported.
  • If your issue is already reported, simply upvote it.
  • If you are facing a new issue, select "Report an issue" at the top of the page.
  • Choose a title that best reflects your issue.
  • Fill out the form that follows and provide as much information as possible to help our teams identify the bug.
  • Select "Confirm" to save the report.
Our team will then receive your report, and we'll contact you for further information if required.
You can check the progress of your submitted bugs from the "My Reported Issues" tab.
The game is basically being completed post release and it's already in a better state now then when it was rushed out too early.
Not exactly breaking records on Steam.
Last night there were more people on Battlefront 2 than Outlaws. The game will obviously pick up some momentum on Steam but this isn't a good sign. This is a game that didn't sell well for a number of reasons and Steam ultimately won't move the needle a whole lot on that front. I believe Ubisoft is ultimately wasting money trying to make the game better. It never should have been launched the way it was and it is a good thing they are fixing it. If nothing else, it helps improve their dismal reputation if only slightly.
Wonder if this game would run at all on my Dell G5 SE 5505 15.6" FHD IPS High Performance Gaming Laptop, AMD 4th Gen Ryzen 5 4600H 6-core, 16GB RAM, 256GB PCIe SSD + 2TB PCIe, AMD Radeon RX 5600M? If it can, I'll wait until the price drops more where I can pick it up for less than $30.
You’ve just described No Man’s Sky and Cyberpunk.
Both developers received widespread praise for fixing their unfinished, broken games.
In the case of the former, it took many years, and in the case of the latter, it was arguably 2 years.
Goes to show that Steam releases aren't quite as important as people think. Of course it would have sold more had it been on Steam day 1, the poor reception at release can't be erased so any uptick from Steam sales will be minimal. I may play the DLC soon. A quick google search shows nothing about reviews, which shows you how unanticipated it was. Even reviewers aren't running to get clicks and from what I can find, this is around 3 hours long.
I've been saying it from the start...the gameplay itself is the main cause of the disappointing sales numbers...people don't want to play as a scoundrel...they want to play as a Jedi with a light saber...the first thing people think of when you say Star Wars is Luke Skywalker or Darth Vader, not Han Solo...the $70 price at launch also didn't help...but PC gamers are a notoriously cheap bunch when it comes to buying games and Steam sales will inevitably help...PC games drop in price at a faster rate than consoles
I give Massive credit for trying something different...still sounds like a good game at the right price
Reactions: Q-BZ
Plenty of successful Star Wars games without Jedis, or without a major gameplay focus on them. Star Wars Republic Commando, Battlefront 1/2 (originals), even Battlefront 1 remake, the many space ship based games are examples. The problem with Outlaws is the gameplay, and well, odd looking character. You play as a supposed outlaw that can't really do outlaw things. You play in large open areas that give the appearance of open ended gameplay, but are so restrained and limited in what you can do. If you played the game you'd understand.
I would like to play a Star Wars shooter game. The Respawn FPS seemed nice. Modern, decent paced FPS gameplay where we can hopefully play as the Empire? That would have been fun. Instead we get an outlaw game where the main character is a goody two shoes.
It should. It plays on my 6550m on low settings. Still looks pretty good though.
And you were wrong when you said it the first time. Republic Commando, the original Battlefront 1 & 2, etc. were all successful. The Mandalorian TV show doesn't feature characters with lightsabers and its far more popular than the other shit Disney has crapped out over the last few years. You are as out of touch as mainstream game journalists when it comes to your opinions on the subject.
have you even watched Mandalorian?...the lead character wields the Darksaber
What about these games?
I also liked the sequel to Starfighter, Jedi Starfighter. In that, in most of the campaign, you do play as a Jedi but the "powers" may as well be regular ship weapons. But technically it has a Jedi so I will leave that off the list.
As for Wild Card DLC, it is more of the same. Made me do the sabacc side quest. I think they made it easier because I finished the last one in a single try. I have not got to the main Sabacc game, but more of the same aside from that. Best thing is you can now climb and get on your speeder with a captured weapon. Once you run out of ammo you drop it though, like before. But at least you can carry it around. There was one fight sequence so far, and then spent 45 minutes walking around in a lame detective style quest. The other annoying things like odd control layout and crappy map are still annoying. Lots of things with this game a small but just poorly implemented. Small, basic things that just make simple functions aggravating.
Will finish it tonight. Seems like it is around 3-4 hours at the most.
I'm not debating these topics until the end of time...everyone is entitled to their own opinions...most people don't care about 'ugly' characters...I for one don't want to play as some gorgeous sexpot female character...that takes me out of the game...gameplay is king, ugly main characters don't matter- Geralt from Witcher, Emperor Palpatine from the Star Wars movies (who wouldn't want to play as a badass Sith Lord?) etc
Correct, I read somewhere recently that only the folks playing the game can have an informed opinion on it... :)
A recent Capcom survey disproves this:
"Unique and attractive characters" came in second only to gameplay. I'm sure someone will say that everyone who voted for that option was only concerned about the uniqueness aspect (which I agree is important, no one wants to play the same protagonist over and over) but they would be lying to themselves. Main character attractiveness is not the top priority, and again I agree that it shouldn't be (or at least isn't to me) but to say that it doesn't matter at all is to deny reality.
Exactly, you for one.
And for the record, I don't either, in every game of course...but lots of great or fun games happen to have had attractive protags, whether they be male or female. They don't NEED to, but it doesn't hurt is all I'm saying. If it didn't matter at all, or if it took most players out of the game, why wouldn't developers just make their protags ugly AF so that everyone would just focus on the gameplay? Because generally, people don't like to play as ugly characters (with exceptions of course; I suppose Outlaws and Gollum did sell some copies based on the hugely successful IPs they were based on...some people will consume Star Wars or LOTR anything because they somehow never tire of the content even when it's poorly made).
Furthermore, just because someone thinks Kay looks a bit weird or off (i.e. a lot of people in this case) in this particular game doesn't mean that they want every character to look like the chick from Stellar Blade.
See above...
I'd argue that Geralt is usually depicted as strong, masculine, and even handsome which are attractive qualities for many gamers. For every image I found of him looking ugly and scarred up, there is one making him look "sexy" and/or handsome, even if just by virtue of the fact that he is almost always depicted as a warrior with great hair and thus traditionally attractive in that sense.
Then why do you keep repeating the same points when proven wrong? You can always admit you were wrong.
Anyways, finished Wild Card. I am not sure if the surrender mechanic is working now, but it was hard to activate before regardless. I had some new ability and throughout the whole DLC was unable to use it because every time I walked up to an enemy they would just shoot me on sight. Detection is still kind of wonky. Now they're more quick to start shooting but that seemingly makes it harder to use the surrender mechanic (which has a quick shoot blaster option). At the same time I got quite close to them before they detected me. Not too far off from other games, but still a bit less realistic in terms of NPC perception. There is a new blaster configuration but I didn't even bother with it. Generally I keep Rapid Fire, Stun/electric, and Explosive (might be called something else in game). Rest of the options are just less optimal and I'll pick up other weapons.
Still some more small activities to do, so maybe I'll do some more of them but they're annoying to find and the map is just shitty. Especially on the last planet, Akiva. The overhead map seemingly shows paths that don't exist, or is too hard to see. It is a very a linear level but the map for navigation makes it very hard to figure out where to go. Which means it incorporates the worst of both linear (not quick, not simple to figure out) and open/expansive design (there is a illusion of paths).
I'm not the only one who hates Akiva's design.
To me Akiva's level design seems like it was quite rushed in development.
Will wait for the final DLC. I don't dislike the game that much to not play it. Though apparently the super premium edition I have doesn't include all of the cosmetic DLC. You can buy outfits, speeder and space ship skins for $20. I know these small cosmetic DLCs are always over priced but Ubisoft is really stretching there. Doubt they'll find many buyers considering the character is ugly and your ship is essentially an ugly flying box. Thankfully, I paid very little for this game. For $20 or so with all story DLC it isn't awful. I'd have a hard time recommending it for more than $30-35.
The irony. :ROFLMAO:
I forgot about the flying box. Between Kay's hideous appearance and the boring look of the ship, skins aren't likely to be all that appealing as they won't fix the hideous base design. Also, Ubisoft's pricing of the game was ridiculous in the first place and charging for skins on top of that and other cosmetic bullshit is just stupid. It's predatory and further shows how out of touch Ubisoft is with gamers. There are certainly games that do this well and offer some perceived value for the money but this isn't one of them.
Exactly. The pricing is just too high, even for most AAA games. Usually the stupid cosmetic DLCs are $5-10. They're asking up to $20. And there are multiple packs, so I would need to spend $25 more to get all of the content and that is not including any future paid cosmetic DLC. Not that I do this for any game, but they're stretching it a bit much here. And it is a shorter game which is not inherently bad, but even if the character/ship design was nice you'll be done with the main game in around 24-26 hours. 30 hours if you stretch it out. Not like you'd have time to enjoy them regardless.
Screen shot from my DLC page:
The ultimate pack is not included in the season pass. I suppose the version I own technically does not have the season pass apparently, but it comes with the story DLC and that is all I care about.
Here is what the $20 Ultimate Pack comes with:
I would like to mention I already have some paid cosmetic DLC in whatever version I own. The Ubisoft launcher does not do a good job of telling me what version I have. I can't find the info on the exact version. Regardless, they're asking $110 for the game + season pass/story DLC, and then another $25+ on top of that for a total of $135+. That is... quite an ask. Well at least no one buys these types of DLC in general but it isn't a good look, especially with the very confusing editions Ubisoft has for all of their games.
I did find a red color scheme for my ship, so now I have a red box. :p
Microsoft has blocked the latest Windows 11 update on PCs with Star Wars Outlaws and other Ubisoft games installed​
https://www.pcgamer.com/games/actio...rs-outlaws-and-other-ubisoft-games-installed/
First reported by Bleeping Computer, Microsoft is now preventing Windows 11's 24H2 update from being sent out to machines that have a selection of recent Ubisoft games installed on them. A number of users have reported persistent, unworkable crashing, sometimes on startup, when trying to play the affected games.
"After installing Windows 11, version 24H2, you might encounter issues with some Ubisoft games. These games might become unresponsive while starting, loading or during active gameplay,"
Glad I am still on Win 10 but will probably upgrade soon.
One thing I forgot to mention is the performance improvements. Recent patch helped a lot. I gradually turned up some of the ray tracing settings. I had settled on a mix of medium high during the main game for consistent high performance. Now I have put most of those up to high and the performance decrease is minimal. I am getting 100-130 or so frame rates in the outdoor areas. Much smoother as well. I still have ray tracing global illumination disabled though. Previously with these settings I recall the frame rates to be closer to around 80 or so.
Worth mentioning, the pirated versions of these games still run fine on 24H2. Possibly an issue with Ubisoft's implementation of VMProtect/Denvuo, however there are other non-Ubisoft games suffering as well
Should’ve stopped this crap earlier. I am on 24H2 and can’t go back. I have yet to play more but thus far post patch didn’t crash.
A few years back they didn't work with Intel's new CPUs. Though Outlaws and Avatar (two of the games listed in the article) have not yet been cracked, so if people are having issues with those games they are running legit copies. Also worth mentioning that most Denuvo cracks don't remove it they just bypass it.
Though if it is related to Denuvo, it is just another reason to dislike it.
I was about to say. Out laws hasn't been cracked yet. Newer Denuvo games have been very hard to crack.
It's a true shame that this didn't release in the form it's in now post patch 1.4. Management at these companies needs to finally learn not to rush game out too early.
I’m not joking here: you, personally, will probably love Veilguard.
In so many ways it reminds me of Assassin’s Creed Odyssey. The combat is terrific, and the game is just so… smooth. The game was clearly held back and held back until it was absolutely ready. Not enough people are praising EA and BioWare for this.
Don’t worry about the DEI nonsense because it’s just not there. Someone complained that the combat is ‘repetitive’. All combat is repetitive. The Witcher 3’s combat is repetitive. Odyssey’s combat is repetitive. In an RPG of this kind you want to feel your character growing in strength, and you want the combat to be touch and go, right up until the end of the fight, and when you win the fight you want to feel that surge of adrenaline - you’ll experience all of that in Veilguard… if you bump up the difficulty by one notch.
You’ll like this game too. Watch out for sales and keep both games in mind.
Bolded is a flat out lie. Overall, the whole game may not feature it, but it's there.
EA and BioWare shouldn't get specific praise simply because they shipped a finished and polished product. This is the minimum gamers should expect from AAA studios.
This is absolutely not true. Combat in a game can be quite varied and interesting if done right. Games that give you options allow the player to have a lot more agency over how they take on enemies leading to much less repetitive combat. The last two Ghost Recon games are good examples of this. You can do stealth takedowns, melee, shoot enemies, or gun them down with an attack helicopter. Go stealth or drive in with a dune buggy and come out blasting. Your choice.
I don't think that would have made that much of a difference in this case. This game is failing for a number of reasons beyond it simply being a buggy and unpolished release. It's absurd price, hideous character design, predatory microtransactions, season pass model, Ubisoft's reputation, and just generally uninspired gameplay that comes across as a knock off of older Ubisoft titles that did everything better than Outlaws does.
And just because a game’s combat is ‘repetitive’, it doesn’t mean the gameplay is terrible.
Many people were critical of The Witcher 3’s combat, saying they were surprised at how boring and repetitive it was. But we’re talking about one of the greatest RPGs of all time here.
Also, you’re doing what you always do: stating an opinion as though it’s a fact. It’s highly subjective to say that any game’s combat is ‘boring and repetitive’. I personally don’t find Veilguard’s combat boring and repetitive. Far from it, for me it’s terrific. For me it’s exactly as you stated above: varied and interesting. It’s not for you to tell me that I’m wrong. It’s subjective.
Linking me to cherry-picked reviews in which some reviewer claims that the combat is boring and repetitive doesn’t mean that the combat is boring and repetitive… it just means that one person thinks that.
Just because someone has a YouTube channel doesn’t mean their opinion is the final say.
But you’ve said this maybe 12 times now.
Dead horse = completely flogged.
"second screen is asking for pronouns" - Hershy
its there.. but why are you pushing feilguard in the outlaws thread?!
oof, hasnt even cracked 2500 players...
Umm excuse me if you look at the daily peak, you can see it's going up every day.
At this rate Outlaws will pass 100k daily players in about 3 months.
I'm waiting for a sale price and some lore friendly mods. I might take a shot at it when all that comes together. Gaming plate is fairly full at present.
Yes, the DEI stuff is there. If I can work around it then that would be ideal. Not crossing that bridge at present.
Status
