- Jun 12, 2004
NUDE MOD NOT WORKING!!!!
Anyway, yeah, using the DL manager, the nude female mod is not working. Can't figure it out. Is there a console command or something that I need to do in game? I install and enable it in the manager. Other mods work fine. Just not this one.
Help me see the naughty bits please! So lonely.
Oh yeah, there is a nude MALE mod too btw. It comes in hairy too! yay...
Most are just replacers, not plugins, which mean all you'd need to do is ensure the textures/meshes are in the correct folder within your data folder. The file path for the female texture is, IIRC, skyrim\data\textures\actors\character\female. Probably the same for meshes, just substitute "meshes" where you see "textures."
Skyrim automatically uses whatever meshes/textures are in these paths over those in the archives, so you have to make sure you placed the meshes and textures in the exact location, otherwise it wont use them in your game.
