I like those colored solid fronts. Way better than that meshy thing.
Sorry about the delay on this project, we've been trying to hit the price target that we quoted during Computex. Had this case been released back in 2009 with the material cost then, we probably would have done it by now. For those of you still waiting, if SG13 is now a $35 ~ $40 case, would you still get it?
Like this?
Found here: http://akiba-pc.watch.impress.co.jp/docs/news/news/20141010_670947.html
Now the side vents on the front panel make more sense.
The AR06 will be 58mm tall with the fan.
Like the FT03-MINI, SG13 shares the same internal base structure with SG05 so they are offset the same. In the SG13, we made it easier for user to fit even a 140mm AIO too (with some sacrifices to room for graphics card and drive space).
I agree, we are definitely studying the state of GPU coolers and see how we can contribute to the market in SilverStone's unique ways.
The SG13 will likely see general availability in Q4 timeframe.
Like this?
I've got a Sugo 13 running with the following ...
It's not even released yet!
You meant to post in a thread about the SG08 mentioned in your sig?
The 140mm fan holes look strange. If the topmost two holes on the front are for the 140mm fans, the bottom left hole is missing and the fan is dangling there.
You don't need all four screws to hold a fan in place. I just have two for each fan on my h60 with no problems. But in regards to the strange shape, I'm guessing it's offset to the side so a 120mm radiator can be mounted horizontally and not interfere with the GPU or drive bays.
Still, it's not for me. Make an SFX version with a cleaner front panel and then it might be worth another look.
They have the cleaner front panel version (detailed in the post a couple of posts above yours), but the only real interesting thing to me is they basically did what many others (or anyone who wanted to fit a normal 10.5" GPU in there) has been doing for a while - cut a hole in the front metal structure.
In all, this looks like a clean update and modernization of both the SG05 and SG06 (since the "solid front panel" version still exists), with an expansion of options. I'll definitely pick it up when it hits the US market. My FT03-mini has been rather disappointing in acoustics (SFX 600W) and GPU support (especially for such a tall case - I also have a regular FT03, which I quite like, not to be confused with the FT03mini).
Damn. Looking around, just about any good PSU is 160mm depth (in addition to any decent fanless ones).
150mm max in this case, if you want to use the SSD/HDD tray (there is a 2.5" mount on the floor of the case, though - where the old front media panel was planned, though never released as a module).
This really seems like the metal chassis is merely a more holey version of the old one.I'm still picking it up, probably with a Seasonic fanless unit, anyways.
Silverstone has several supplies of their own that fit in this case, jeremy. The ST65F-G, the whole "PB" line (including the 700W) and a few others.
Maximum depth for a standard PS/2 (ATX) power supply is 150mm. Models with modular cables may or may not fit depending on connector locations.
If upper drive cage is removed, there is nearly no limit to power supply depth, pending the thickness of the fan or radiator used on the front panel.
