- Mar 19, 2003
No stock meaning I tuned it to run undervolt that matched my out of box performance. So my card runs 2850-2900 without any undervolt but I do the same with a .95 @ 2950 curve which nets about 2800-2900 MHz. Also I forgot my memory was at +1000 for daily.I assume that "Stock" GPU, as in absolutely no V/F modifications either? If I run the benchmark with the same settings, default GPU (out of the box), not even loading MSI AB, I get around 64.50 FPS.
If I run an actual overclock it would hit maybe about 70 or higher. I can run it tomorrow as it is 1 32 AM right now.
Edit: it is 69.38 with a decent overclock on the card and not touching the processor.
