cornelious0_0
- Apr 6, 2003
sdk said:My plans for my case.
Replace the two rear exhausts with Aluminum Fans
Either put a blue rocker switch next to the pci slots on the back of the mobo tray or a micro switch in the usb door.
New fan grills,
Custom cut a second exhaust, and dremel of a stock fan grill.
Stuff I order'd
2 x Alu 80MM fans
Blue LED"d Rocker
AS5
Blade Fan Grill
2 Wire Grills
LL Slot Bay Cover.
That's nice.....but pics would be better.
carlos seo, try what was recommended about the PCI bracket leads.....but those rounded cables have to go. Not only do they look VERY out of place.....they're MUCH harder to hide then ribbon cables. The ribbons you'd very easily be able to tuck behind the 3.5" cage for the floppy and hard drives.....and along side the mobo at the very least for the optic drives.
Unless someone has all their wires sleeved the same color and they can make them visible while still making it look clean rounded cables just dont look right.....they're marketed as allowing better airflow, but ribbons are SOOO much easier to hide and route that it isnt even funny.
