- Dec 5, 2018
Got my little PS120SE.. great cooler. About as strong as FC140.. I have a 3 pack of T30s on the way..
>.>About to upgrade my sons PC… where to start…View attachment 566943
start by blowing it outAbout to upgrade my sons PC… where to start…View attachment 566943
Get a cable management kit off Amazon, having velcro tape and the like makes all the difference.>.>
My Fractal case definitely does not look like that behind the solid panel.
Definitely not. Nope.
This one is the Lian Li Lancool II, cable management is o-k-a-y… but when he has 8 corsair fans controlled by their hubs it’s annoying. I’d go with the Lian Li Uni fans if they weren’t so bloody expensive.>.>
I did last week, although in fairness really on the front, bottom, and inside. I vacuum out what i can and blow out what I can, but even still it’s been running 24/7 for 3 years now so it’s hard to get it spotless now.start by blowing it out![]()
see above, dont do that!! ive seen at least 6 machines killed by little old ladies vacuuming it out.I vacuum out what i can
i still wouldnt risk it. thats my re-join date, after the crash.I only vacuum the PSU, the front rad (from the outside) and the inside bottom of the case. Also hey, you beat my join date by a few days![]()
i call cases with wiring like that mullets; business in the front(all clean, almost no visible wires) and party in the back("messy", its fine really). mines like that too...
Ah, yes...phantom Gannon strikes again!Deployed pic, with a helper of course: (His name is Gannon, and he never holds still).
Pretty sure he's the Forest Temple Shadow Gannon, for real. Continuously jumping from window to window... always on the hunt to kill that next moving object he sees outside...Ah, yes...phantom Gannon strikes again!
Almost finished with my white fishtank build, may end up grabbing a blocked GPU in the end, but for now the painted shroud installed on the 3070 works until I can move my 3080ti:
Thanks it was a huge jenga puzzle to get that thing in there tight with a good seal, thankfully the evo has the sliding fan trays, thats what made it possible to use the single straight tube in front.I love how clean and professional that looks. The simplicity of your double rad loop is impressive. I'm curious if you have signal issues with the video card, having such a long PCIe cable run.
looks like youve got the length so id flip that rad around do the hoses are on the bottom.Got her all cleaned up now, everything works as it should
Kind of weird not seeing a big air cooler though..
But... But the YouTubers said that it's illegal and will cause the extinction of unicorns if you do that...looks like youve got the length so id flip that rad around do the hoses are on the bottom.
No, hoses on the bottom of your pump is bad. On the bottom of the radiator? Psh, dunno what they're smoking. Edit: I mean, it could make getting bubbles away from the pump more difficult, but not enough to warrant doing it in every situation.But... But the YouTubers said that it's illegal and will cause the extinction of unicorns if you do that...![]()
well, when you start hearing gurgling noises, flip it around. it will work the way it is now, just will pull air through the block every now and then.I am not too concerned. I figure I will probably have to use the warranty once or twice, depending on which CPU I run the most with it. Its current position is fine, the pump is hella strong![]()
youre just confused.But... But the YouTubers said that it's illegal and will cause the extinction of unicorns if you do that...![]()
no, hoses under pump doesnt matter either. if the rad is below the pump is what matters. some part of the rad has to be higher than the pump. the tube thing i mentioned is to stop the occasional gurgling from the air in the rad getting sucked down and through the pump(most have a bit).No, hoses on the bottom of your pump is bad. On the bottom of the radiator? Psh, dunno what they're smoking. Edit: I mean, it could make getting bubbles away from the pump more difficult, but not enough to warrant doing it in every situation.
