- Apr 26, 2009
although I can bench at +125 core, to be able to run heaven for more than 20 minutes, I had to drop down to +100. This is with the power target at 132% of course and a ramped up fan profile so the temp stays under 70 degrees. The final gpu clock at these settings under full load is 1185mhz. Haven't started testing memory yet.
Why are you running heaven for 20 minutes?
Play a game for an hour or two and that will give you a better idea of stability.
I can run Heaven at 1300Mhz but I can't pass 1270Mhz in BF3.
