Network pics thread
MadHatter
What are you using for out of band management?
I'm using 2x Avocent CPS1610's (one as a spare). I decided to adapt from RS232 on each machine to RJ45 though so I only had to run one type of cable for all machines. Each machine has console redirection to serial for me to control it remotely. Hopefully after this weekend I'll have it working so it operates through my secondary ISP connection (on my PIX501 - separated from my main routing equipment).
As it's a home network it's not really crucial to have this setup but I wanted to research it more and it was pretty inexpensive to setup.
dashpuppy
new addition to the soon to be rack.!
Modifications will be coming tomorrow, the blower fan is FUCKING ANNOYING! im changing it to a different type of fan, probably a 2.5" cpu fan and will creatively attach it to the low profile copper heat sinks, i will post before and after pictures.
I did add another 512mb ram to the unit, i might see if i can scrounge 2 x 1gig chips to throw into the unit to see if it will run properly.
Cant remember what a i686 processor is tho.
Hallis
Yah i hate high RPM blower fans. that's why i got rid of that SuperMicro 1U. The RSA boxes i've got aren't even as loud as my Dell PowerConnect switch.
Celestix boxes are a little louder too.
djBon2112
i686 is just Pentium II and newer, so everything that's not x86_64 basically. Upgrade of the i386 (i.e. based on the Intel 386).
calvinj
That's a nice looking box. Makes me wish I would have pushed a little harder to get one for my office.
OmegaAvenger
I though that was i586, because I remember seeing i686 after x64 came out, but then again I was still new with computers back then
Berg0
The P6 microarchitecture is the sixth generation Intel x86 microarchitecture, implemented by the Pentium Pro microprocessor that was introduced in November 1995. It is sometimes referred to as i686. It was succeeded by the NetBurst microarchitecture in 2000, but eventually revived in the Pentium M line of microprocessors. The successor to the Pentium M variant of the P6 microarchitecture is the Core microarchitecture.
Google FTW
Lightworker
Skeletek C series, 20U.
It's still not "good" cable management, but its good enough for how often I'm moving stuff around. I'm going to get some cable management pieces eventually, usually this stuff just sits on a shelf until I got the rack last week.
dashpuppy
Whats up guys,
I just found this forum...had this pic on my phone. I will post some better shots soon!!
what happens, if i pull that yellow cable over there out ?
WOAH thats nice setup! lol is that were all our porn is stored ?
dashpuppy
Got the lcd working & functions of the front of the Astaro ASG with 8.002.
moded the cpu fan to a top mount, instead of the blower * aka LOUD* fan.
NTAuthourity
Issue i have with that AMD fan, is if the old one pulled its air in or pushed out from the side slot on the fan itself, how is this going to have enough clearance once you get the case on, to pull from the top?...did you check the height? (obviously i'm sure you have lol but just a thought)
dashpuppy
There is abou 1/4" the cpu, doesn't even get the slightest bit warm. I will be on the look out for another type of fan, but this one will work for now, the blower fan was driving me nuts, way to loud, i hated it. The equipment is in my laundry room.
here is a shot of all the equipment together for now.
The astaro unit is working perfectly right now, i haven't gotten any thing connected because im still working on stuff right now, i will migrate everything over soon.
Have to setup the vpn, and all my rules for email and other things.
RiDDLeRThC
ciscotacrtp - keep it up, i'm loving all the images!
Something tells me no one else will be able to compete with what ciscotacrtp posts lol
Kaiga
Whats up guys,
oh... my... god.
he even has signs, that are numbered in his data center, like it was a grocery store or something.
QHalo
It's cool to see how the actual vendor does their support pods and so forth. I just wouldn't want to be in charge of asset management lol.
calvinj
I think I would go bald in the fact most of that stuff is ever changing.
Brak710
still not quite sure what "TAC" stands for
RTP = Research Triangle Park correct?
Technical Assistance Center, I believe.
They're the people who figure something out/explain it when you call support with a serious question.
dle1232003
serious questions? instead of, please can i have some of your unused offcast hardware, as I can't actualy afford to buy any of your nice pretty nexus stuff (well i can't anyway)
loving all the pics recently specially the green untangle box
