Warm air only rises ever so gently in a case, the slightest airflow will disrupt it.
Yes, this can be done, you can push the modular PCB further back into the housing. At least, I have done this with the ST45SF-G. There is a plastic divider behind the PCB, so there's no chance to short-circuit something. I can't tell you exactly how many millimeters you will win. At least 2mm, maybe as much as 5mm. You will need washers and longer countersunk M3 screws.
However, opening the PSU voids the warranty.
While we're on the topic of voiding warranties... how much of that 10mm connector is really necessary to house the pins, isolate the wires effectively, and provide grip and structural integrity, versus how much you could get away with by de-pinning, shaving the housing, and re-wiring?
Edit: I feel like I've seen someone do this somewhere else, but I couldn't find it.
MiniFitJr pins run almost the whole depth of the housing. You could maybe shave 1mm off. I have some spare male and female connectors if you need me to try it?
is it possible to mount two140mm radiators in the case when you mounted the mainboard that you only have two slots for graphics card? [Emphasis added]
In theory, yes. The rads are a bit wider than the side opening, but they'll fit once inside. The latches that hold the side/top panels extend about 10mm into the case, so they could be a problem. The side bracket obviously doesn't work with 140mm fans - you'd need to figure something out for that.
The new one won't have a handle, I guess, right?
I was just curious if that was a popular suggestion or not. I think a detachable one would be pretty cool.
Thanks. It's a bit barebones, but it gets the job done. W360 wanted to open preorders a week ago, but I insisted we get something presentable up. Spent the last week doing the one-man band thing - banging out code, renders, writing copy. Fun stuff.Fantastic website, really well done !!
It's a very clean and professional looking website. Pretty cool that you got Malik to do a build and photos, don't think I'd seen that before.
Certainly quite the effort! But I think you made the right call. Particularly for people who only just now find out about the M1, and see the opportunity to order... Having a well-put-together website as a first impression will probably encourage orders far better than a static page with a Paypal button and not much else.
In my defense, the previous version, set to launch 1 week earlier, was not a static page with a PayPal button![]()
@AFD
I think that he used Asus Z87 Impact and Phanteks PH-TC14CS.
Phanteks only has one top down cooler, so it has to be the the PH-TC14CS. The 120mm fan is necessary - the default 140's it ships with won't fit due to how they mount on with the clips.
The (tentative) final change list for M1 v2:
- Enlarged CPU cutout upward on motherboard tray
- Additional cutouts at bottom of motherboard tray
- Move rear 92mm fan and tubing holes down 2mm
- Additional 3.5" HDD mounting location at forward bottom of chassis
- Cable tie holes on chassis bottom reduced from 10 to 5
- SSD stacking brackets modified to allow stacked 7mm thick SDDs closer
- ATX PSU bracket moved back to allow more clearance behind chassis front
- 3.5" HDD cage fixed to work in upper fan bracket position
- ODD bracket screw holes reduced for better M2 screw fit
- No top panel screw
- More SSD mounting screws
- Extra side panel clips
- Dome head M5 screws changed to flat head M5
- Shortened internal AC cable
- Threaded inserts at side bracket mounting points
We've talked about the possibility of offering parts for sale through the site, including screws and cables. We might be able to get a left-angle version of the power cable for those people who were unable to use the included cable with certain ATX PSUs. W360 also has a bunch of extra 2.5" HDD mounting screws he ordered a while back; you could email him if you want to order some.Question for you Necere: Did you thought about or would it even be possible about doing an upgrade kit for the owners of V1? Like the extra screws, the shortened cable, etc? Just a tought.
It depends how many total orders we receive. We'd only want to order maybe 100 extra cables, but that's well under the MOQ if that's all we were ordering. But if we piggyback it to our main order for the right-angle cables, the supplier may be game for it.Hmmm.. how strong is this might?![]()
Don't know yet how much they'll be. Again, depends how many we order.How much would each cable be? If it was under $10 each, I'd probably consider ordering one of each left and right handed shortened versions just for the flexibility and futureproofing.
Did the new silver version include black feets?
And I just saw a news for your 2nd run on a well known german forum called hardwareluxx.
http://www.hardwareluxx.de/index.ph...age-des-ncase-m1-kann-vorbestellt-werden.html
I could not remember, thats why my second question is if it would be possible to anodize the outer panels?
That's the plan.Did the new silver version include black feets?
The outer panels are either Anodized black or Anodized silver. The insides are painted black on either.
Thats right, but perhaps they where anodized before mounting the pins on the panels. But when the pins are not soldered or welded on the panels a new anodizing should be possible.
Best would be if somebody knows that the pins are only pressed-in. So anodizing is 100% possible
