- Apr 20, 2014
I didn't shift it at all. That's the H220 rad in the model with 25mm thick fans. The thing is it already just barely fits in the case.
There's really no way you could swing it out. There's also an additional complicating factor I neglected to mention: the dual-position mounting of the radiator bracket.
So in the end, yeah, it might be nice. But there's really no way to do it without giving up one thing or another, or making the case larger.
Yeah, agreed. It's a nice-to-have, for sure, but the compromises needed keep it out of scope for what we're trying to do here.
On the one hand, that's a bummer - even if an expected bummer. On the other, though, I didn't know you could move the bracket up! Was that how it has always been, or is that a recent revision?
That alone will make WC jobs, especially those including GPU, much easier - it's no swinging door for easier component access, but it makes the routing of tubing (which you live with every day, rather than just during installation) significantly more comfortable.
I reiterate my appreciation for your input and exploration of this, Necere! If anything, this thread is simply reinforcing how well designed the M1 is already. That we are discussing features like hinged radiator brackets, or modifications to add/remove small ledges, is only possible given the great balance of features and compromises struck by most everything else. I struggle to think of other cases where that is also true. And for SFF it's unmatched, really.
