Yeah i know. But if the pins are welded, anodizing could looks bad on that area. Thats why i had that question
I think you do not understand which pins i mean. I mean the pins on the sidepanels. When you are anodizing the sidepanels, the whole panel have to be put in the fluid. If you pull it out you will see different colors in the welded area of the pins. Thats why you could see it on the outside of the panel all the time the case stands on you table.
Hopefully you understand what i mean. After your last post I suggest you thing i mean the pinholder in the frame or so?!
RAID 5 isn't really recommended by anyone these days.
the hope is future technology (500-1000 years) may still able to retrieve data from the Magnetic disks or SSDs.
I still think a handle would be the neatest 'improvement/suggestion.' I read that it would be too much trouble but what about the Lian Li TU-200? I read reviews on that case and the handle was not one of the issues. In fact, it was very popular with owners/buyers.
I noticed on one site, someone putting a handle on a SG05, I think? Can't recall which case but I think the M1 is light enough to have one. But, I guess if custom water coolers and other complex parts are going into it? I dunno... just seemed like a good practical bonus but it must create more problems. It just seemed like the TU-200 was a similar size/foot print.
The TU-200 has a reinforced unibody chassis. It's designed from the ground up to be carried from the top, and to be stronger in general for transporting.I still think a handle would be the neatest 'improvement/suggestion.' I read that it would be too much trouble but what about the Lian Li TU-200? I read reviews on that case and the handle was not one of the issues. In fact, it was very popular with owners/buyers.
http://www.frozencpu.com/han-08.html
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=26829
$ 14,99, no need to completely redesign the Ncase for that.
In contrast, every exterior panel on the M1 is removable without tools. This makes it easier to work in, but at the cost of not having the same structural rigidity of a closed unibody design. That's not to say it doesn't feel rigid in the hands - it does, it just isn't designed to survive a lot of abuse (but why would you be doing that to your nice brushed aluminum case in the first place?).
Since the top panel is removable and the top support beams aren't intended for load bearing, there's no place for a handle to go.
I was not talking about having the top support beams (and/or top panel) bearing the entire weight of the system. Do you even understand what I was talking about?
You don't need to get defensive but your own words are misleading:I certainly did read Necere's post before.
Looks like you can put on the strap before mounting the side panels for a nice "integrated" look. Anyone want to try that and post results?
Although I'd worry about the top frame support beams bowing in from the pressure exerted by the strap combined with the weight of the system.
I'm fine with being told that I'm not being clear, but when you accused me of not reading the post right above the one that I originally quoted, that's something else completely.You don't need to get defensive but your own words are misleading:
Either way, the straps would not fit without cutting the panels. I can just barely put my fingernail in between them and those straps are atleast 2mm thick. Since the panels would push the straps inward, exerting force on the handle would pop off the panels because the straps would be stretched.
Yes, the V1 top and V2 front are compatible. The incompatibility noted on the site is the only one between all the different panel combinations.So.......... $90 for silver panels + shipping to spain. I suggest you write
IN SUPER HUGE VERY BIG LETTERS
How the things work together.
For instance, does the V1 top panel work with V2 front panel?
Won't this prohibit the use of the Silverstone SFX PSU's ? It's not clear from your post that both are included when I read that first part.
yea that's a big change. i really hope this doesn't mess up the silverstone sfx and wouldn't this make the ac cable management untidy for the sfx user? i think we need some pic
Changing to left-angle is better for the ST45SF-G with fan-inward and an ODD mounted, since it won't push against the ODD. OTOH, the older ST45SF will have pretty much the same issue, except when fan-outward.I plan on picking up one of SilverStone's new SFX PSUs (the one w/ the 120mm fan). I hope this change in internal AC cable doesn't make cable management more difficult w/ regards to that internal AC cable...
Depends on where the 24-pin ATX connector is on your motherboard, doesn't it?
We have confirmation now, the 600W will have the same plug orientation:As far as the upcoming units, if this pic is any indication, the 600W will be the same as the ST45SF-G so left-angle is also preferable. But then again all they've shown so far is what appears to be a ST45SF-G with the sticker for the 600W, so it's hard to say.
