Just a heads up: preorders were up briefly, but w360 tells me the shipping calculator isn't working correctly, resulting in free shipping for those who managed to order. If that was you, you may have your order canceled and will have to reorder when it's fixed.
If you paid for shipping, you're fine and your order will be kept.Will I be alerted to that?
EDIT: My receipt says I paid shipping.
I still have a Silver V1 brand new in the box with both top panel options that I was ready to use for a new Ryzen build later this year but now that V6 is tempting me...
The U9S has similar weight to the heatsink, and the fans are pretty good. You could also ask Noctua for updated mounting hardware and stick the new a12x25 on your existing coolerJust wondering...I have the old noctua C12 cooler in my M1, but wondering...if I were to update the guts, would any of the other Noctua models offer roughly equivalent cooling/noise profiles? I usually run things stock, no overclocking.
Should be okay cutting just one, but will the blades spin with that inside the fan? Or, if it will spin, why do you need to cut anything — can't get the side cover on?Not sure if there's somewhere better to ask this.
I'm in the process of replacing the fans / shroud of my GPU with 120mm fans at the bottom of my ncase:
One minor snag is the GPU heatsink has some small clips that stick out and get in the way on one of support arms on a fan, so it doesn't quite fit in fully:
My thoughts are either bending the metal part of the heatsink away or cutting though the support arm on the fan to get it to fit.
I don't think the fans can be repositioned here and the clip isn't big enough to interfere with the fan blades so bending isn't essential.
I would rather make any change to the fan rather than the GPU but wondered this might fundamentally compromise it?
Any advice welcome.
Any advice welcome.
The GPU is being stopped about 50mm short of the PCIE slot, being blocked by this metal bit hitting the fan support.
The metal bit is not tall enough to interfere with the fans when as intake, but does stop them being used for exhaust unfortunately.
Hi,
can someone confirm me that the asus rtx 2080 rog strix a8g gaming fit inside the ncase?
with the super out, there is a tempting price on this card...
Many thanks if anyone can confirm me.
I saw the remnants of that fan bracket on reddit but I’m not sure I’ve seen performance results. How does it fare compared to your 1080ti/accelero setup?Here is what a 2080 ti strix with the fan shroud and bracket ripped off looks like. Also hacked up the gigantic support bracket that said RTX on it.
With the stock silent fan profile I can't get it to go past 64C @ 2040mhz. But I would hardly call it silent. With a much more conservative fan profile I am doing 70C @ 2025mhz. I imagine I'll end up tuning it more and settling in around 75C @ 2000.
The stock strix sink is doing just as well as an Accelero considering this is a higher TDP card and I'm able to push it a lot further than my dud 1080ti.
7/10 would hack apart again.
by the way, are you running on a 750 Corsair psu or 600w one?
Yes.Hello
Maybe this was already answered somewhere but could I use the v3 top panel with the odd part on the v6 so that i still can mount my odd
Greetings Chris
It's been neglected for a long time. Looks like a lot of the old information is gone.Hi!
Has the google spreadsheet changed? Where are the graphic cards and heatsinks compatibilities list?
thank you.
It's too long for the thickness and too tall for the length.well kind of the same question, any hope that the MSI GeForce RTX 2080 Ti GAMING X TRIO fit?
It seems very masssive : 327 * 140 * 55.6 mm
Seaching my future 2080ti![]()
Nah it be too big, I am not even sure if there is an SFF case out there that can support that card, maybe the Sliger 580 if you mod it but you are pushing it as maximum GPU length support is 325mm while the length of the Gaming X Trio is 327mm.
Thanks for the answer regarding the trio.
are they any 2080ti that you recommand for the Ncase? that fit without any mod and that perform ok temp and noise wise?
thanks a lot.
been trying to m1 local but people keep trying to get me to ship but im a bit worried it will get damaged in shipping.
how safe is it shipping it built? (will use the black box that the case came in)
If you insist on shipping it assembled please have the courtesy to share the aftermath pictures when it arrives completely destroyed. Tall, heavy heatsinks do not ship well. That is a _LOT_ of force being applied when it bounces around.
