LG L246W
Discussion in 'Displays' started by ascarytiger, Mar 10, 2007.
  1. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    I am using the same lead aswell.
    What i have found after i nuke the pc with updates turned off is that windows or something installs something, in turn pulls the screen to the left, what i think is it's 100% fault of this monitor or rather LG and nothing to do with Nvidia/AMD anyway.
    I cannot wait to throw this monitor away after i put a huge hole in the middle of the screen when i can afford a new monitor.
    I am now looking at the BenQ XL2410T 23.6" Widescreen 120HZ LED 3D Ready LCD, just because it's priced right.
  2. dark_reign
    dark_reign 2[H]4U
    2,179
    Nov 15, 2005
    The newest NVIDIA drivers (270.61) seemed to have fixed the shifting issue for me. By accident I forgot to edit the nv_disp.inf file.
    The only problem now is that the scaling setting gets locked at using the display's built-in scaling, so I had to go back to using the nv_disp.inf hack to get it to work again. If you don't play games below 1920x1200 then this shouldn't be a problem. The problem with the built-in scaling is that it doesn't set 4:3 aspect ratios correctly.
    BTW, the registry hack only stays in place if you don't do a clean install.
    I've had this monitor for 4 years and it's still going strong. It's just too bad that it has these annoying issues.
  3. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    I have also learned from peoples comments that the screen works perfectly using GPU's GTX 460 and above?. I am using GTX 275 in SLi. Can anyone enlighten us on this?.
  4. dark_reign
    dark_reign 2[H]4U
    2,179
    Nov 15, 2005
    I did upgrade from a GTX 260 to a GTX 460, so maybe it's not the drivers.
  5. techie81
    techie81 [H]ard for [H]ardware
    4,951
    Jan 12, 2005
    The screen is still shifting to the left while hooked up to two of my AMD cards with HDMI.
    Edit:
    PC 1. has a 6950. When hooked up via HDMI the screen shifts. When hooked up using the DVI - HDMI cable the screen is fine.
    PC 2. has a on-board 4250. When hooked up via HDMI the screen shifts. When hooked up using the DVI - HDMI cable the screen is fine.
    PC 3. GT240. When hooked up via HDMI the screen shifts. When hooked up using the DVI - HDMI cable the screen is fine.
    So it seems as the implementation of HDMI is screwy with this monitor. Do other monitors have this problem?
  6. dark_reign
    dark_reign 2[H]4U
    2,179
    Nov 15, 2005
    I've always had mine hooked up via DVI - HDMI and the screen shift occurred going as far back to my 8800 GTS. When I upgraded to a Radeon 4850 everything was fine. When I got a GTX 260 the problem was back, but it seems to be fixed with my current GTX 460.
  7. techie81
    4,951
    Jan 12, 2005
    I want to know why hooking the monitor up via DVI-HDMI cable works fine but when you hook it up via HDMI it goes back to shifting to the left.
  8. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    Thnx for the info, so atleast i have learned from this is that i need to buy a new GTX 560Ti or better, or atleast 2 GTX 460 1GB in SLi to have this problem fixed.
  9. powruser
    powruser Limp Gawd
    435
    Mar 6, 2011
    i had a 9800gtx and never saw any problems when using my L246WP
  10. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    That is a surprise to me!!
  11. Corvette
    Corvette [H]ard|Gawd
    1,270
    Sep 12, 2002
    I bought a 460GTX-768MB and hooked mine up via DVI-HDMI and it shifted to the left and had a horrible glow around white things. I tried to edit the .inf, but those instructions seemd to be written for Vista/7 and I'm still on XP. I manually added a registry value and fixed the problem.
  12. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    Your still on XP, WTF?:eek:
  13. Corvette
    1,270
    Sep 12, 2002
    I have had a 7 disk since the student deal, but I haven't had a reason to install it what with a DX9 video card and a C2Duo era computer. I think I'll be buying an SSD in a bit and reformating to 7 since this XP install is showing its age.
    OTOH, XP EDID problems can be fixed by adding the same registry file!
  14. AlexTheGreat
    AlexTheGreat n00b
    28
    Jun 16, 2005
    I'm having the HDMI display shift problem with my new e350 & this monitor. Unfortunately the EDID fixes don't seem to be working. Anyone have any ideas?
  15. Corvette
    1,270
    Sep 12, 2002
  16. AlexTheGreat
    AlexTheGreat n00b
    28
    Jun 16, 2005
    Windows 7 Ultimate 32bit. I did add those flags directly to the registry and to all the folders. I think maybe that method doesn't work for AMD chips?
  17. cocheese256
    cocheese256 Gawd
    784
    Apr 23, 2005
    I just recently took this monitor to work. I would have kept it if I could have purchased two more new just like it for surround gaming. I feel the picture quality was better than the three HP ZR24s that I purchased to replace it.
  18. UtopiA
    UtopiA 2[H]4U
    3,509
    Oct 13, 2007
    My monitor has completely lost it, I have to run in 1920x1080 to make the panel even usable.
    If I run at 1920x1200, artifacting everywhere, screen flickers black constantly. Only a matter of time before it dies entirely.
  19. powruser
    powruser Limp Gawd
    435
    Mar 6, 2011
    hearing all these reports of long term reliability problems, im rather glad that I sold mine. if i had kept it, it was liable to just die after awhile anyway.
  20. Corvette
    1,270
    Sep 12, 2002
    It's a pretty old monitor and you're more likely to see people posting failures rather than, "May 27th, 2011 and it still works," posts.
  21. Wibla
    Wibla Limp Gawd
    315
    Jul 9, 2007
    May 27th, 2011 and it still works (after swapping two capacitors - cost $10)
  22. shurcooL
    shurcooL [H]ard|Gawd
    1,125
    Oct 12, 2007
    May 27th, 2011 and mine still works. :)
  23. techie81
    4,951
    Jan 12, 2005
    Mine still works but I kind of want it to die to I can get something else. :)
  24. fender
    fender Limp Gawd
    417
    Mar 2, 2003
    Does anyone have some tips for disassembly? The bezel seems to be a pain to get off.
  25. Wibla
    Wibla Limp Gawd
    315
    Jul 9, 2007
    It is a right pain, especially without the manual. I can send you the repair manual (djvu file) if you want, just pm me your email.
  26. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    Did i miss a thread on this, has someone given a detailed post on this and how to do it?
  27. dd0512
    dd0512 Limp Gawd
    145
    Jun 14, 2009
    were they obviously blown or were you DMMing?
  28. Wibla
    Wibla Limp Gawd
    315
    Jul 9, 2007
    here's the image from when I fixed it, the caps were obviously bulging, and they were in the right circuit to explain the problems I had before they outright failed.
    Symptoms: Have to push power button repeatedly to get the monitor to turn on, gradually getting worse over a few days/weeks to the point where it will not turn on.
    Edit: I quoted my previous post so you can go back in the thread to read about the problem and solution without having to search :)
  29. calikool
    calikool [H]ard|Gawd
    1,158
    Aug 9, 2006
    Where is the link describing the problem? I saw the picture but it looks like you already replaced the capacitors.
  30. Lodrin
    Lodrin [H]Lite
    73
    Jan 3, 2008
    I had the exact same issue. It starts mainly because the monitor goes into permanent sleep, which requires you to power cycle daily. 3 years later, I noticed that the monitor would take longer to start up, and soon I had the on/off problem where the monitor would have to warm up for 10 minutes(auto-cycling) before it could be used. Damp air made this problem worse.
    After about 1 month, it refused to turn on. I popped my LG246WP open, saw both caps bulging. Replaced with Rubycon 3300uf 25v caps (10 pack $10 at Amazon). Monitor turns on nearly instantly now and w/o any issue.
  31. tthom
    tthom n00b
    15
    Jun 10, 2011
    Hi all,
    I read this forum long time ago, because I had this display shifted issue with HDMI, too..
    Used Nvidia card, there was driver hack, OK.
    Used Ati card, there was CCC solution, OK.
    But a few months ago I use integrated Intel GMA4500 and with that all reg hack were useless..
    So.. I did it, changed the monitor EDID info IN the monitor and fixed the problem. Forever.
    No more driver mod, no more registry hack. It is working. :)
    Of, course, if this solution was here earlier, then, sorry... :)
  32. AlexTheGreat
    AlexTheGreat n00b
    28
    Jun 16, 2005
    How did you change the EDID in the monitor?
  33. techie81
    4,951
    Jan 12, 2005
    Can you please explain how you did that?
  34. tthom
    tthom n00b
    15
    Jun 10, 2011
    Yes, of course, but do it carefully and make backup!
    Solution for L245WP/L246WP:
    1. Export existing EDID -> in Raylar EDID DAT format (Phoenix, monInfo, SoftMCSS)
    2. Modify EDID -> extension blocks = 0, don't mod other data! (create backup, open with Phoenix EDID editor, than save)
    3. Monitor service menu -> Aging mode = ON (service mode: turn monitor Off, press menu while turn On)
    4. Full version of Powerstrip - Monitor properties, Update EDID (should be only HDMI-DVI connected, it's simpler to select the right EEPROM), choose the modded file
    5. Restart
    This extension blocks data were overwritten with registry hacks, so, that is software solution and this is the hardware version. :)
    Good luck!
  35. tthom
    tthom n00b
    15
    Jun 10, 2011
    One more addon.. There is of course two EDID in the monitor as in the registry. One for the analogue and one for the digital input. So, you have to choose the right one for export, edit and import.
  36. AlexTheGreat
    AlexTheGreat n00b
    28
    Jun 16, 2005
    Is there any other program besides powerstrip that will do the EDID update? Powerstrip crashes on startup on my zacate.
  37. tthom
    tthom n00b
    15
    Jun 10, 2011
    Dunno.. I didn't find any.
    Try another version.. Or get somehow another PC/laptop and try with that..
  38. AlexTheGreat
    AlexTheGreat n00b
    28
    Jun 16, 2005
    Will the edid updater work through a DVI->HDMI cable? I only have the one pc with hdmi...
  39. tthom
    tthom n00b
    15
    Jun 10, 2011
    Of course, I used that, too.
  40. calikool
    1,158
    Aug 9, 2006
    Do you have the LG Service repair manual? I think my monitor my have the same capacitors messed up. I haven't disassembled the LG before. What's the best way to go about identifying if it is the capacitors? How bad of a bulge was it?
