- Jul 5, 2012
Looks like I can finally play Control at 4k with all RT features turned on at high fps with Ampere
You do?We know for a fact a 3080 Ti with 20GB will eventually come.
They didn't omit its performance -- they omitted the whole product SKU entirely. As of right now, the 3080Ti doesn't exist.Pretty sure they omitted it's performance because of how close it is to the 3080. Estimates of only 15-20% on top of the 3080 are probably true and would look horrible on a PR chart.
I'm pretty sure he's talking about the 3090 thoughThey didn't omit its performance -- they omitted the whole product SKU entirely. As of right now, the 3080Ti doesn't exist.
I'd want to know right quick if they're both HDMI 2.1...2x HDMI connections
Curious about what you guys want to use the dual HDMI for? Is it a VR rig + CX?
Do it once Do it right? go big or go home.I've decided I'm going to get the 3080 first, and if it isn't enough for the CX 55 4k120, I'll sell it and grab a 3090.
As much as I want to say yes to this, $700 -> $1500 is a BIG leap in funds for what is expected to be a minimal performance gain.Do it once Do it right? go big or go home.
Looks like GAINWARD branded 3090s and 3080s were posted to their website too early, and subsequently removed. Screengrabs were captured however. Confirmed HDMI 2.1 on both. Interestingly enough though is that the listing for the 3080 states 2 8-pin connectors for the power requirement.
https://www.tweaktown.com/news/7485...rce-rtx-3090-3080-phoenix-official/index.html
If anyone's interested, I've created a new version of my ColorControl-app and it's available on GitHub now: https://github.com/Maassoft/ColorControl
This 1.1.0.0 version adds:
- Automatically power on/off functionality for LG TV's
- Extended NVIDIA controller context menu to allow setting color settings manually. Includes bit depth, format, dynamic range and color space. Note that not all combinations are allowed and will result in an error message. Some may also result in a purple screen (RGB format with YUV color space and vice versa)
- Checkbox to fix blurry/rainbow fonts in Chrome. This is only necessary if you want to use ClearType in Windows, but grayscale anti-aliasing in Chrome. If you have ClearType disabled, just leave this checkbox unchecked.
- Option to set a shortcut to the blank screen saver
My brain tells me 3090 but my wallet says 3080. If only there was something in between.
I just fired this up to try out and it isn't able to find my TV. I have quite a bit going on network-wise, but the TV and computer are on the same subnet and can talk (I can ping it and I could control calibration stuff on it over the network via CalMan). I have a feeling it's a network binding issue, is there some way to bind the app to a specific NIC?
EDIT: Cancel this, I figured it out based on the Github issues and how it finds the TV based on the DLNA device existing. I added it and it's detecting now!
There likely will be if you’re willing to wait on the 3080Ti/Super...but yeah, I feel yah. The 3090 isn’t a good value, but it’s the one that will push the most frames at 4K which matters more for the CX. I’m still leaning toward the 3080 since even that will be a huge upgrade from my 1080Ti but we will see after the reviews come out.
This is a community service announcement for LG OLED C9 owners. Turn ... OFF ... automatic firmware updates NOW.
With 3xxx series launching within a few short weeks, I'm seeing some speculation on various forums that LG may nerf, disrupt, change, impliment "fixes" to these 2019 sets with their full 48gb HDMI 2.1 performance in some as of yet, unknown ways. It's absolutely better to be safe than sorry.
This logic of course stems from the fact that LG could have added in 4K@120hz 4.2.2 support along with Freesync support to the 2019 C9, etc but for "market" focused reasons, did not. This is of course, at the end of the day, an unfair game LG has chosen to play with it's 2019 sets / owners. Simply unacceptable.
It's being suggested that now that HDMI 2.1 is launching, with both nVidia and AMD, they may pull off a "firmware" update to make their newer 2020 sets have clear performance and feature advantages over the 2019 sets.
It's generally understood and accepted now within the community of large format display users that the C9 has some advantages over the CX series.
I not only turned off automatic firmware updates but I have also blocked my LG C9 at the router level. No data for you!
This seems like weird conspiracy theories to me. The LG C9 series afaik is already discontinued so people are buying whatever is left. LG claimed in CES interviews that 4K 120 Hz 4:2:0 was not possible on C9 due to a hardware issue. It is well known that they use a very different setup for HDMI 2.1 compared to CX. Even now the performance difference between C9 and CX is completely negligible and you won't see a difference unless you have them side by side and calibrated. I own both and can't tell any real difference.
Lack of Freesync support is a bummer but overall it is a use case that only concerns Xbox One X and AMD GPU users. For Xbox Series X, PS5 and PCs running Nvidia GPUs it's not an issue.
The hardware is nearly identical from what I've read. This claim is just market BS. Someone did an in-depth specification / feature set deep dive and found out / determined that the 2019 sets could actually very easily do the 4K@120hz 4.2.2 after looking at the numbers. This lie was enacted and perpetrated to sell 2020 sets to uneducated consumers which is very often the case. It's no secret manufactures want you buying all their new stuff year in and year out.
And, a conspiracy theory? Really?
I guess you missed the whole settlement Apple agreed to after it was discovered they "nerfed" the batteries in an entire series of phones which resulted in millions of people buying Apples new phones a lot sooner than they should have. that settlement was in hundreds of millions of dollars.
You sound like the very trusting type ..... I admire that in you. When you get to my age, the world becomes ... very clear, your eyes pop open and you grow to become jaded and cynical as you realizes the entirity of humanity want's to fuck you from behind while at the same time reaching into your pockets to take all your money.
What Apple does has no bearing on LG. Apple's "throttling the phone to maximize battery life" was a clear technical implementation that was most likely not intended to be a malicious feature. I have a hard time assuming malicious intent over just pure incompetence. There are no "uneducated" consumers who will be even aware of the 4K 120 Hz 4:2:0 thing. It is not a feature that concerns anyone using these TVs in their living room as you know, TVs.
We don't know what actually goes inside the LG TVs. Also the CX series is not capable of 4:2:2 at 120 Hz without HDMI 2.1 source. Only 8-bit, 4:2:0 without HDR. That this is not achievable on C9 could be a number of reasons and just looking at bandwidth numbers and specs does not tell the whole tale. As a software developer I know these things can be far more complicated than they seem. For developers of these things maybe it was considered the feature was so niche that putting in the man hours to implement it to work on the C9 was not worth the cost. This happens all the time in modern software development with bug fixes, new features and newer model developmetn getting preference from management when allocating how developers should spend their time.
Again, without over complicating my initial posting ( and please don't take it where it doesn't belong ) to safe guard against any unexpected "feature downgrades" I would disable automatic firmware updates in high-end LG 2019 sets. Samsung was caught red handed purposely breaking a handful of features in 2015 or 2016 series via firmware updates. This, you can Google. Apple was recently caught doing this with their battery management back end on some of their phones that resulted in very substantial settlements.
With HDMI 2.1, the CX having only 40 vs the C9 having 48, I would dare not take a chance with LG pushing any updates. If LG did push an update in the next 2 or 3 weeks, I would be very very suspicious of ... why.
Haha, I love your passion.R
The RTX 3090 isn't a good value? LUL WHAT? It's the fastest GPU on the planet. Do some of you really want this for free, or cheap? I really really really hate to see this logic within our HardOCP community where, it's expected that we reside within a community of "Hard" advanced users who chase performance. We do it hard or we go home.
Every generation of GPU I have to see, hear and witness this attitude here on these forums. You people have had 2 years to tuck away $20 here and $40 there. You have old hardware, older electronics, buying habits you could have sold and or changed to make this a reality.
Value is a very personal perception that is going to differ from one person to the next. Please, speak for yourself.
I challenge all of you to start selling the crap you have laying around to make this 3090 happen. 2 weeks is a long time to clear out $1,000 worth of stuff. Wife has an old juicer she isn't using or going to use, that's $50 right there, old bar stools in the garage, that's $30 or $40, random memory? That's $10 or $20 right there. Old 1tb or 2tb hard drives, people pay $30 or $40 for these all day long. Old CPU, Video Card, Motherboards? $100 ... $200? etc etc etc. A PS4 or Xbox that you really don't use? That's another thing, get rid of your old PS4 and Xbox shit now. This is def the time to do that. It's estimated that the average house hold has $2,000 to $3.000 in unwanted items laying around that have current market value. Yes, I've read that before and it's probably true.
Getting back to this "value" comment. They are giving us a TITAN class GPU with 24GB's of DDR6, not @ $2400 dollars but at the incredible value of $1500. That's $900 off. And this is still not a good value to some of you? ... Jesus.
Anyways, good luck.
And seriously, use these next 2 weeks to sell off your unwanted crap. Tech hording is lame and a year from now, all that random shit you have laying around will be almost worthless.
See you guys at Microcenter at 4AM the morning of the 24th. And, have your damn money together. I've dreamed ... dreamed of owning a Titan class GPU. Who is going to join me?
I spent probably the equivalent of $1800 on SLI dual 1080 cards in 2016. The 3090 is my next upgrade, let's do it HARD!
(But I won't be queing at Microcenter, I'll probably just be boring and wait for reviews of quiet fan AIB models so I can pick one that's nice and silent).
So I went into the menus and turned V-Sync on, and low and behold I was running at 120hz! Great, I thought. Then I realised I was only in 1080p. I went to change the res, and 4k was not an option! I think the max is 1440p. I run on SLI Pascal Titans...so it's not the video card. Does anyone have any ideas why this is happening? Is it my crappy HDMI cable?
Yes, you need a HDMI capable of transmitting 4k120, which old ones can not do. I personally hate HDMI's cable branding; I think 2.1 cables are branded as "Ultra High Speed", but it's really impossible to keep track anymore.
As far as the price vs value title goes that will go to the 3070 the reviewers are speculating. Won't know for sure until they do the actual bench marks however. That's not to say the 3080 and 3090 are bad in any way. They just wont take the price vs value crown is all. That's the early speculation at this time.
