- Jul 5, 2012
I have been using a non certified cable for a while without any issues. Cable length could also be a factor in signal stability too. Mine is a 2m cable from Club3D.
It is most likely the cable. It might be worth trying a lower bandwidth for a while, like using 8 bit and see if it fixes it.
Ya, I also have the cable as the possible culprit as its most likely. As I have not heard any widespread issues regarding this and the RTX 30-series neither the OLED.The packaging for that cable lacks the HDMI authentication label, which is required for the use of the Ultra High Speed designation on cables. Use this to look for good cables in the future:
https://hdmi.org/spec21sub/ultrahighspeedcable
Yeah, my Mediabridge HDMI 2.0 cable that I was using previously ended up working just fine at 4K 120Hz RGB. So it appears that I didn't need to purchase an HDMI 2.1 cable after all. Haven't had any dropouts or anything. So, I guess it doesn't hurt to try your existing cable and see if it works. If not, can always pick up one of the recommended cables in this thread.I have been using a non certified cable for a while without any issues. Cable length could also be a factor in signal stability too. Mine is a 2m cable from Club3D.
Plenty of 2.0 cables work fine with 2.1. Give it a shot and see for sure. If you want to pay 2X or 3X for a "certified cable," more power to you. Plenty of the "certified cables" are cheap trash as well.FWIW, my Mediabridge HDMI 2.0 cable that I was using previously ended up working just fine at 4K 120Hz RGB. So it appears that I didn't need to purchase an HDMI 2.1 cable after all. Haven't had any dropouts or anything. So, I guess it doesn't hurt to try your existing cable and see if it works. If not, can always pick up one of the recommended cables in this thread.
Use only NVCP to initially setup the cloned displays. Windows Display settings can result in software cloning with a performance hit. Once you've setup cloning with NVCP, you can use Win + P to toggle it without losing hardware cloning. You also need to match the refresh rates exactly down to the last 3 decimal places by tweaking the timings. Otherwise you'll have stuttering on the desktop.For people battling phantom display headaches around audio devices...I finally figured out a good solution as long as you have a receiver/other HDMI audio device that supports 120hz OR another monitor that you run at 60hz. The answer is DSR in NVCP. If the TV is your only display and your receiver supports 1080p 120hz, use CRU to edit the EDID for your receiver to disable everything above 1080p (like if it support 4k/60 but not 4k/120), enable a DSR scaling factor that puts your 1080p receiver at 4k (1.78x I believe), set the resolution on the phantom display of your receiver to your newly available 4k/120hz, then in the Windows display settings duplicate your TV and receiver display. Ta-da, no more phantom display. Same thing if you have another monitor. I have the TV and a 1440p monitor (which has HDMI) hooked up, and an HDMI DAC that supports video passthru...but doesn't work at 1440p. No problem, I set it to 720p, DSR'ed it up to 1440p, and mirrored it to my 1440p monitor. Done!
Can anyone recommend a good productivity monitor to pair with this? Either 27" or 32". Mostly for viewing text during the day, no gaming - sharper the text the better. Is 4k@27 overkill?
edit: Gez everything is sold out! Only thing I found in stock is a Dell P2721Q which seems decent.
Its possible that many of the 2.0 could pass the ceritfication, even club 3d hdmi 2.1 cable is selling for more than 2 years but certification started only on the end of previous year after that they changed the package to show certification but older purchases should be the same quality.Plenty of 2.0 cables work fine with 2.1. Give it a shot and see for sure. If you want to pay 2X or 3X for a "certified cable," more power to you. Plenty of the "certified cables" are cheap trash as well.
Just use whatever you already have. Nothing really "pairs" with it. You're not going to match the colors, black level, or anything like that. Best you could do is sort of match the size and resolution by having 2 24" 1080p screens stacked on the side.
I notice you have the same setup as me (though I also have SVP Pro, which I disable when watching HDR movies). Does your 4K HDR movies colors "pop" more when NOT fullscreen, but gets less intense and darker when in fullscreen? I don't mean washed out because it's not washed out for sure (I can tell the difference), but for some reason non-fullscreen mpc-hc colors pop out more, as well as brightness/contrast are more intense. The TV does changes to HDR mode when mpc-hc is non-fullscreen or fullscreen, so I know it's not the TV.yeah what I posted is not deep at all.. it's mainly just setting it up to pass through HDR using madVR when playing on mpc-hc.
MPC-HC menus:
..Set the output to MADVR
..Set the video accel type to turn it on or off (to use gpu accel or just cpu)
MadVR menu:
..set it to pass through HDR to the display.
.. don't need to adjust anything else since it's passthrough.
I use a 43" 4k on each side in portrait mode. I sit far enough that the PPD looks good for text on those. In fact I'm so far away in order to be at an optimal distance on the 48" OLED (scaled at 100% 1:1) that I decided to scale the 43" screens to 125%.I meant what complements it. I had a 27 1440p LG IPS but had to give it to my family member. So looking at buying a dedicated screen just for work during the day time. Since I'm buying it just for office work, text clarity beats everything else. But maybe it's too off topic for this thread.
32" 1440p or 24" 1080p are the same PPI so scaling is uniform. That's the most "complementing" in my opinion.I meant what complements it. I had a 27 1440p LG IPS but had to give it to my family member. So looking at buying a dedicated screen just for work during the day time. Since I'm buying it just for office work, text clarity beats everything else. But maybe it's too off topic for this thread.
Just have your main desktop monitor arm mounted and then bring it to the front of the CX whenever you need it then swing it away once you don't.
I actually had a LG 32GK850G, sold it to help fund the LG CXThis. I keep my 32" 1440p VA on an arm and swivel it around as necessary. The black background is of course not comparable to the OLED it sits next to, but it is about as dark as LCD's will get. I don't find it distracting, and it serves its purpose well.
I had an old 27" 1440p TN panel display next to my LG CX 48" for some time but without mounting it on a monitor arm it wasn't that great to use. Image quality aside, as far as pixel density goes I felt it was a decent enough combination to pair with the CX as the much closer viewing distance for the 27" ended up looking somewhat similar to the CX at 1m away.
I use my CX with 125% scaling. I use 120% on MacOS, which I find is ideal, just does not work as well on Windows as some UI is scaled at 100% with a custom 120% scale. Anyway, I find that 1m distance with 100% scaling is just uncomfortable small for me to view plus the DPI scaling of course improves text rendering a bit. I really wish Microsoft made their system work at other than these 25% increases which work fine for small 4K displays but are plain awful for anything else. 110%, 120% would be good additions to the low end of the scale.
You should RMA your card, there's no solution currently available without compromises.I have an issue with my setup. Short story is - my 3090 graphics card single HDMI port appears to have fried, along with one of the HDMI ports on the TV. I've tried changing the cable and connecting a different source to the TV too, and definitely confirmed that the HDMI port is fried along with the graphics card HDMI port.
I have no idea how this happened - I had upgraded the motherboard but was very careful in moving the card to the new case & motherboard.
The 3 x DisplayPort connectors are working on the graphics card, and I still have one spare HDMI port on the TV to use.
I think have two options:
1) RMA the graphics card in the hope they will repair it
2) Try using a DisplayPort to HDMI adapter
Are there any good DIsplayPort to HDMI adapters, and are there any limitations e.g. can no longer use Gsync?
I do all my work on Linux, which works great with scaling in my opinion. Anyways, I preordered a Asus Tuf VG289Q, should arrive in a couple weeks. Seems to tick all my boxes - 28" 4k (I think 32 would be too large), IPS, not too expensive (350), and a great stand. I'll just put it on my desk in front of the CX then move it when not working. I have a spare ergotron LX but the CX is just too big, there is no where for me to mount it on my desk without being annoying. I'll have to think about it...
Thank you all that chimed in on the black outs.. Also the ones not quoted. Will try to lower it to 8 bit for a while an see how things go. Will also look for the certified ULTRA speed HDMI logo. Thanks.
What GPU? I never had this issue with a 2080Ti or 3090. What length Zeskit cable? I'm not convinced certification tells the whole story on these, or there's some variation in manufacturing that make some on the edge/out of spec.been using the cx for a few weeks now with my 3090 and the colors/features are amazing! (when they work that is)
recently though, I realize that if the TV turns off while my PC stays on (for example, if I have to go afk for a hr, I would want to turn off my TV to limit burn in, but won't necessarily turn off my PC if stuff is running), turning on my TV again will never let me get the awesome 4K @ 120hz again (in NVCP, the max setting under "PC" is 2560x1440 @ 120, or 4K@60 under HDTV) until I reboot my PC.
I'm assuming this is a software/Windows 10 bug, what do you guys think? I have yet to try a new cable because I have one of those certified Ultra High Speed HDMI 2.1 cables from zeskit, so I would assume that cabling isn't the issue here(?)
I also have a 3090, and using with a 2m Zeskit cable. I can't quite remember the exact issues w/ my old 1080Ti, but there were similar issues present for sure (though I got them a lot less frequently for whatever reason).What GPU? I never had this issue with a 2080Ti or 3090. What length Zeskit cable? I'm not convinced certification tells the whole story on these, or there's some variation in manufacturing that make some on the edge/out of spec.
This is usually due to a defective cable renegotiating at a lower speed.I also have a 3090, and using with a 2m Zeskit cable. I can't quite remember the exact issues w/ my old 1080Ti, but there were similar issues present for sure (though I got them a lot less frequently for whatever reason).
If you disabled your TV/let the TV screen go to sleep while leaving your PC on, are you able to still retain 4K@120 when you wake up your computer?
For example, if my TV screen turns off due to inactivity (due to Windows 10's power and sleep config), when I wake it the TV either crashes my entire computer (in that it's clearly receiving signal since I get the "Instant Game Response is on" text on my TV, but just displays a black screen on all screens, and I have to force shut down the PC), or it's stuck at 4K@60 with no 4K@120 resolution present in NVCP. My other monitors (via displayport) don't have this issue, but they also aren't 4K@120hz haha
thanks so much! I was confident in that it was a software issue, but this would also make a lot of sense. will send out an email to zeskit and see if I can RMA my current cable.This is usually due to a defective cable renegotiating at a lower speed.
okay, I have a similar setup as you (3090, TV + 2 extra DP monitors). I am using the newest drivers, but I'll try and do a new installation of W10 sometime and see if that fixes it. I think Monstieur might be right in that it's a cable failing the HDMI handshake when booting again, but I hope to god it isn't my 3090 or my PSU (EVGA 850w G2). thanks for confirming!Yeah mine stays at 120hz when it turns back on. I have a 3090 with 2 other screens connected with displayport and then 2 more screens connected to a GTX 650. I've never hda any crashes or anything like that.
It sounds like it's probably a problem with your PC if it crashes your computer. Are you using the newest drivers? It's possible it's a hardware problem too. Cable, GPU, or PSU.
Yeah I've had occasional weirdness when starting my computer from off/rebooting, but never from turning the TV back on when the computer is already on. And the weirdness I've had is never unavailable display modes. The next time it happens mash the green button on the remote 8x and tell us what the bottom line says, that will confirm if it's negotiating a lower link speed or not.thanks so much! I was confident in that it was a software issue, but this would also make a lot of sense. will send out an email to zeskit and see if I can RMA my current cable.
thanks for the tip!Yeah I've had occasional weirdness when starting my computer from off/rebooting, but never from turning the TV back on when the computer is already on. And the weirdness I've had is never unavailable display modes. The next time it happens mash the green button on the remote 8x and tell us what the bottom line says, that will confirm if it's negotiating a lower link speed or not.
I'm also using the Zeskit 2m cable.
I've been using my CX as my primary monitor for the past few weeks (think like 8+ hours a day) w/ desktop icons (although I'm never just idling w/ my desktop on the screen) and haven't experienced any issues with burn-in (though to be fair I don't have a ton of hours on compared to RTing's/HDTVTest's burn in tests). I think you should be fine if you're only using it for 2-4 hours a day.I've been doing a lot of reading and can't get a straight answer.
Would you be OK using the CX 48 as a PC monitor for a dining room computer where you will use for 50% web browsing, mostly youtube, and 50% netflix movie watching? Computer will be used for 2-4 hours a day max.
Will leaving the desktop icons up in the background be an issue?
I get people who say it won't be an issue, then people who say it will be an issue.
Yes and it's a bit shit. It applies globally to all monitors and some apps won't understand it the way they do the 25% steps normally available. Often you end up with a weird mix where part of the UI is scaled and some of it isn't. Or text is scaled but icons etc are not. Likewise you also cannot change the scaling on the fly without logging out and back in first. I am not sure exactly what it does differently but it definitely does not work as nicely as the regular options. Having the 125% minimum step is annoying as I liked 110% on 1440p displays and 120% on my CX 48".There's an option for just entering a custom scaling value between 100-500
That sounds like incredible overkill for an occasional use display. I'd just pick a decent LCD and not worry about image quality in that situation.I've been doing a lot of reading and can't get a straight answer.
So apparently, the non-fullscreen video colors, brightness, and contrast are not true HDR (sometimes I get a washed out version, sometimes I get a super vivid version lol). I tested this by playing the movie directly on the TV USB port and comparing it to PC mpcHC+madVR in fullscreen and got somewhat similar colors, brightness, contrast, etc.I'll have to check it out. I've mostly been using the OLED to play jedi-fallen order in exlusive fullscreen mode for HDR lately.
I set mpc-hc to automatically open in full screen on that screen # in the array no matter where it is launched from so I only watch them full screen. I will say that a lot of things on displays in general look tighter when smaller because it is like supersampling a greater rez down (like watching 4k rez content on a 1080p screen or window). I don't know if that applies to what you feel you are seeing but I thought it might be worth mentioning.
edit:
-- also make sure dynamic tone mapping is turned off on the tv and in madvr
-- ensure that HDR is still switching into full HDR metadata mode. Try shutting the video player off, then toggling the windows HDR slider back and forth (or use the tray app that can do it), then re-launch the video full screen. You can set it to launch full screen (and on which monitor # of the windows array) in player settings, at least for mpc-hc.
Mine was being buggy with HDR switching at a few points in my ownership, even from lowered HDR color brightness with HDR always on in windows to full HDR metadata failing to kick in on a fullscreen game or movie. Seems clunky at times. I haven't noticed it lately though and I have a new firmware so fingers crossed.
