With the translucent taskbar app, I still have the line from the search bar. Is there a way to remove that, or do you have to turn off the search function from the taskbar?you can also use the taskbarhider app and put the recycle bin on the taskbar itself, toggling the taskbar to show/hide with a hotkey.
taskbarhider
http://www.itsamples.com/taskbar-hider.html
translucent taskbar
https://github.com/TranslucentTB/TranslucentTB
https://www.microsoft.com/en-us/p/translucenttb/9pf4kz2vn4w9?activetab=pivot:overviewtab
How to Pin Fully Functional Recycle Bin to the Taskbar in Windows 10
https://www.tenforums.com/tutorials/29497-pin-recycle-bin-taskbar-windows-10-a.html
or
https://technastic.com/pin-recycle-bin-to-taskbar-in-windows/
And here's a simple guide for your reference.
- Right-click on any blank area on the taskbar and go to Search on the menu, and there you will have the option to hide it.
- You can also choose to show search icon only, thus a magnifying glass icon will appear next to Start button.
Pretty old message, but could you go into details on how you did this? I tried using CRU to delete that 4096x2160 resolution, but I don't see that option anywhere in CRU.I tried using CRU to delete the 4096x2160 resolutions from the EDID and that also did not do anything. I have had it several times drop to 4:2:0 in 4K 60 Hz and somehow managing to make that really blurry.
Thanks! I'll try it once I get home from work tonight.I didn't know either but I found it: edit extension blocks, then double click on TV resolutions.
Also don't get a lot of the other features. But thats why its cheaper.And that is why I wouldn't buy that cheap Vizio OLED. You wouldn't get firmware support like this.
I have the Vizio too. It's amazing as a $900 (Best Buy black friday deal) bedroom TV. It has multiple showstopping issues/"features" that would make it unusable as a PC monitor.And that is why I wouldn't buy that cheap Vizio OLED. You wouldn't get firmware support like this.
Thanks man, swapping to icon only is the perfect fix for me.Personally I set up a hotkey in the taskbarhider app to hide/show the whole bar with a toggle (ctrl+SHIFT+Z in my case). But before that I just hid the field and left it as the Magnifying glass search icon instead.
https://www.myofficetricks.com/how-to-hide-search-box-from-taskbar-on-windows-10/
Now I instead just hit the windows key on the keyboard plus the S key. When you do that hotkey the focus is already on the popup so you aren't really saving any steps by typing on the taskbar where you'd have to move your mouse there and click on the field first anyway. Winkey+S no matter where your mouse or focus is and you can start typing your search term immediately.
winkey + S (or Q) = search menu popup (start typing after it pops up)
some other ones I find the most useful:
... the alt tab functions remove the need to using a taskbar for switching (though not launching)
Alt + TAB = switch between open apps with popup
ctrl + Alt + TAB = persistent popup to select between open apps
winkey + D = desktop show/minimize everything toggle
winkey + A = action center/notifications
winkey + E = open file explorer
winkey + R = run command
winkey + TAB = open task view
Now I rarely even toggle my taskbar to show at all since I don't need it. I have side monitors with displayfusion taskbars on them for the windows system tray when I need that though. I use my streamdeck to launch apps but if I ever need one I don't have mapped there I can just hit winkey+S and start typing the name of the app , then hit enter to launch it. That's the easy way. The long way would be to hit the windows key alone and scroll through the start menu if I forgot the name of the app
One other thing I do is I dump all of my desktop icons into a desktop icon folder in my documents and I pin that folder/favorite it in my file explorer. Then I set that folder to show the icons at a size I like which it remembers for whenever I open that folder.
Thanks again. It works.I didn't know either but I found it: edit extension blocks, then double click on TV resolutions.
Here is a detailed instruction for anyone wanting to remove the 4096x2160 resolutions in NVCP and ingame:
1. Download and run CRU.exe.
2. Click "Export" on the bottom to backup the default profile.
3. Select LG TV SSCR (active)* on top.
4. Under "Extension blocks", double click "CTA-861: 1 detailed resolution, ..." to edit it.
5. Under "Data blocks", double click "TV resolutions" to edit it and delete all "4096x2160". Click ok afterward.
6. Repeat for "HDMI support".
7. Click ok several times to apply changes.
8. Run "restart64.exe" to restart the graphic card.
9. Restart the PC.
10. Go into Nvidia Control Panel-> Change resolution and make sure it's still using 10bpc. Sometimes it resets to default 8bbpc color settings.
Done! Now there should not be any 4096x2160 resolutions in Nvidia Control Panel or ingame.
I bought this and it works well for me, though it was missing a part upon arrival and I had to get them to ship out a replacement part, which they did promptly.Been using this for around 3 months now, and I have to say when playing a game with a controller where you can sit back in your desk, its amazing. Playing mouse/keyboard it is very rough however. Its just too close to my eyes (I have a 30" desk).
is there a common monitor arm or TV stand people recommend? I have heard the Ergotron HX is a good monitor arm for this, but I have also heard that because of the way its designed you can only really gain ~3"-4" inches of clearance as the arm does not allow you to go beyond 180 degrees. I thought about buying a TV stand that I can put behind my desk, but I use a adjustable desk and that would render that moot.
Really love the monitor, but if I cannot figure this out I'll have to sell it to get a more manageable sized monitor.
This is the highest quality stand:Been using this for around 3 months now, and I have to say when playing a game with a controller where you can sit back in your desk, its amazing. Playing mouse/keyboard it is very rough however. Its just too close to my eyes (I have a 30" desk).
I think I like this one! Its pretty minimalistic and the rear pole part is very near the back, meaning I can have the stand very close to the desk and have very little hanging out the back. Thanks!This is the highest quality stand:
https://www.monoprice.com/product?p_id=39657
If you get this one, make sure all parts have been included before you set it up. The X brace you see in the pic was missing a part in mine.I'd recommend using a flat footed or heavy caster wheeled stand that has good reviews rather than using a monitor arm, like some of the ones people have replied with. Then you could put the monitor behind your desk. The stands that don't articulate much are cheaper. If you need one with full portrait mode spin and a lot of tilt they can be a little more pricey. Still in the range of the heavier ergotron arms though price wise.
These are a little more expensive but have full articulation on the first one and the second one is super heavy-duty up to 100 lb. They all appear to have quality caster wheels for more ease of positioning control and movement (but whose install is usually optional if you need the clearance).
https://www.displays2go.com/P-16610/Black-Cheap-LCD-TV-Stands-Economy-Design-32-47-Monitors
https://www.amazon.com/gp/product/B00681HGB6/
Try All Settings > Connections > Mobile Connections Management > Sound Share (Delete).third time posting this, maybe I should get the hint and stop asking:
Anyone know how to disable the Soundshare prompt screen? I get it everytime the monitor wakes up or turns on and it takes two clicks on the remote to close it. I'd rather this prompt not appear.
Thanks.
hey all, I installed one of the desktop clearing apps as recommended in this epic thread, so that my desktop is pure black. I am not finding the trashcan via searching in Windows and I need to empty it. I am used to doing so from the desktop icon.
Can anyone explain how I can access it now? Thanks.
Shift+DeleteYou can also empty the recycle bin as part of a monthly disk cleanup run with the new version of it in settings. Windows 10 puts a ton of crap everywhere these days, I usually clean out like 10-20 GB. I don’t use the recycle bin anymore and don’t miss desktop icons. I just pin things to the right side of the start menu.
Guys, what settings do you use when you play games?
HDR mode on TV or Windows?
When HDR, is OLE light set to 100?
So I've had my 77" LG CX for 4 months now and my GTX 3090 for 2 months. What a fantastic TV, and was worth selling my 65" LG C7 for. I was happy with 4k/60Hz for the few years I had the C7 - it made it difficult to enjoy my 144Hz 1440P monitor on my other gaming rig. But the G-Sync and 120Hz really ties it all together to make the CX a fantastic gaming TV. There are other improvements as well - the HDR and the color uniformity, particularly on gray-content, has massively improved. I was not super lucky with the uniformity on my C7, but it would only reveal itself in certain content so I was able to over look it. These screens are game changers - most people don't know what they're missing out on, and they probably wouldn't want to know if they couldn't afford it in the first place.
Thanks, that seems to have done itTry All Settings > Connections > Mobile Connections Management > Sound Share (Delete).
Where is SDR brightness slider in windows and how do you know it will do x nits?HDR toggled ON in Windows which then triggers HDR mode on the TV itself. OLED light set to 100 but SDR brightness slider in windows adjusted to a value that outputs 120 nits.
I posted the formula for it earlier. 0 is 80 nits and 10 is 120 nits. These are absolute values and are constant for any display that is calibrated correctly.Where is SDR brightness slider in windows and how do you know it will do x nits?
