Yeah, I’m sure it’s not as nice as an OLED, but it has no burn-in issues and it is 1/3 the price of the 48CX.The LG non-OLED TV's in larger sizes are hot garbage. It's possible the smaller ones are better...but I doubt it.
GTFO, lol. The 48CX is in another class completely.Has anybody tried the 49” LG NANO85? It has HDMI 2.1 for 4K@120Hz, an IPS panel (like most gaming monitors) with no burn-in problem, and it’s only $499 at Best Buy.
That same guy has a video comparing an LG NANOCELL to an LG OLED that goes over the pluses and minuses of both (and, yes, there are a few minuses to OLED).Yeah, I’m sure it’s not as nice as an OLED, but it has no burn-in issues and it is 1/3 the price.
Lol seriously? Nano IPS has a tough time just competing with VA panels, it's not even a contest against an OLED. Only people with serious delusions will believe that a Nano IPS can compete against OLEDI
I rather use pure black wallpaper, with some combination of dark broser mode. Less hours on OLED pixels = better lifetime.To prevent burn in, I'm using Steam Wallpaper Engine a LOT, hiding task bar, no icons and turning off when I'm not using.... is this good enough from a maintenance perspective? Is turning off a bad thing? Thanks!
Ah ok I was under the impression you wanted the pixels moving, not static, thanks. I'll see if I can find some good wallpaper.I rather use pure black wallpaper, with some combination of dark broser mode. Less hours on OLED pixels = better lifetime.
What's considered a reasonable OLED setting? Mine is at 75 right now.Yea if you want to make oled last longer black (aka pixels turned off) is the actual way to go. That and a reasonable OLED light setting, of course.
Huge help thanks!I use all black wallpaper so the oled is pretty much off on a blank screen like kalston said.
I use transluscent taskbar app (from github or microsoft store) to make the taskbar clear. I also use taskbarhider app which allows me to assign a hotkey to show/hide the taskbar rather than using mouseovers. Using displayfusion taskbars on my other monitors which include windows startmenu/button, system tray, animated mouseover thumbnails of apps on the taskbar etc. I don't need to use a taskbar on the primary LG CX gaming/media monitor anymore. So I use my taskbarhider app's hotkey to just lock the regular windows taskbar away on the primary monitor 99% of the time. Displayfusion also lets you keep the ALT-TAB or CTRL-ALT-TAB (persistent popup) thumbnails isolated to whatever apps are open on that particular monitor which makes it easy to swap between what app is focused on that way instead of using taskbars. It also allows you to customize the size of the thumbnails that pop up while tabbing if you want to.
The main things that still pop up on the LG CX are the master volume overlay and the system notifications - but I went into the system notifications menu (Win + A , then click "manage notifications" to open the notifications config window) and turned most of the notifications off. I might look for a 3rd part app for that if there are any to see if I can make them visible on my other screen(s).
I tried an app to hide the windows 10 volume overlay when I change the master volume but I haven't found a reliable way to get rid of that yet.
Other than that, some installers and updates and such pop onto the primary but I can drag them off of it to another monitor. I wouldn't walk away from my screen for too long counting on the black wallpaper or even a screensaver because crashed apps and update windows and such take top level and would be sitting there static on the primary monitor.
I leave HDR on/active at 100 on the primary (LG CX OLED) and just use the windows HDR slider to bring it down until right click menus and general text and backgrounds look normal/SDR again. The LG OLEDs already have to tone map HDR10 (1000nit) content down to 800 or whatever their peak is. HDR should be left at it's max for movies and games and then just use the windows HDR brightness slider to bring it down a lot (to what looks like SDR levels) for desktop when outside of launched HDR games and UHD HDR movies etc (where the HDR overlay flag shows up on launch/start).
Huge help thanks!
75 is pretty high if you are not using HDR mode. I use mine at around 30-40 which is somewhere in the 120-130 nits ballpark if I remember correctly.Ah ok I was under the impression you wanted the pixels moving, not static, thanks. I'll see if I can find some good wallpaper.
Normally you DO want the pixels moving within a reasonable timeframe. Hence the suggestions for either a fluid/moving desktop background like Vista had, or just set your desktop background to black (what most people do). That's built into Windows 10 and you don't need to download anything for it.Ah ok I was under the impression you wanted the pixels moving, not static, thanks. I'll see if I can find some good wallpaper.
Anyway, I’ve got 3 LG OLED TVs (various generations) so you don’t need to tell me about their merits. The problem is that I don’t want to use one for my PC because it will have burn-in issues, so I thought I’d mention a much cheaper alternative for PC users that want a cheap 4K@120Hz option (with full 48Gbps HDMI bandwidth) for their new RTX and RX video cards. I’ve moved that to another thread, so you all can go back to talking about workarounds for the CX issues.![]()
Decent contrast ratio. IPS panels like the one on this TV aren't known to have good native contrast, but this is better than most IPS TVs, and it's similar to the higher-end LG SM9500. Still, blacks appear closer to gray when viewed in the dark, and the local dimming feature only slightly darkens blacks.
If you want a TV with a higher contrast ratio, check out the Samsung RU9000.
Bad local dimming. It isn't very effective and makes dark scenes look worse. When there's a bright object that moves across the screen, the dimming zones around the object light up and it's noticeable even during real scenes. Setting the local dimming to 'Medium' helps with this issue, but overall, it gets very distracting. If you want a similar TV with a full-array local dimming feature, check out the LG NANO90.
Poor black uniformity. There's visible clouding throughout with backlight bleed in the corners. The local dimming feature only makes it look worse as the entire screen is less uniform as there's clouding at the center where the cross is.
Yep, you can check that via hdmi diagnostics menu. Settings / Programmes/ Hover over Programme Tuning and pres 5times 1 (1,1,1,1,1) . Right arrow to highlight and select HDMI Mode and you can check some stuff.Is there a connection information screen I can access via the display? I'd like to know what the display sees in terms of resolution, refresh rate, color depth, etc. as a sanity check against what Windows tells me (old habit) and every display I've ever owned had some way to display this. I haven't been able to find it in the Settings function of the CX48.
yep, every lcd looks like a smeary gray washed out mess now.GTFO, lol. The 48CX is in another class completely.
hell I use 10-15 for windows, 50 for games and movies, 100 for hdrAh ok I was under the impression you wanted the pixels moving, not static, thanks. I'll see if I can find some good wallpaper.
Yup. I use 0 for work with light coming in a window, no issues. Then HDR with the Windows slider at 7% for non-work (equivalent of ~35 OLED light on SDR content). You'll think it looks dim right after you change it, but I guarantee after 10 minutes you won't even notice, and if you turn it back up to 75+ you'll squint.hell I use 10-15 for windows, 50 for games and movies, 100 for hdr
Thats been my experience. Besides.. I don't need notpad++ and solidworks to be vibrant. I'd rather not stress the oleds for desktop tasks.Yup. I use 0 for work with light coming in a window, no issues. Then HDR with the Windows slider at 7% for non-work (equivalent of ~35 OLED light on SDR content). You'll think it looks dim right after you change it, but I guarantee after 10 minutes you won't even notice, and if you turn it back up to 75+ you'll squint.
Thank you. This has confirmed a problem I am having. When in the nVidia Control Panel I select (under PC resolutions) the 3840x2160 option and 120Hz (8bpp, 32bit, full/rgb) the PC is sending out a 4096x2160 active signal that the display is scaling. Hence I am getting some narrow black vertical bars on the sides. I am now running a high quality cable (signaling issues have disappeared) so I'm not sure what's going on. Under the Ultra HD/HD/SD section, selecting the 3840x2160 (native) option @ 60Hz sends the proper signal.Yep, you can check that via hdmi diagnostics menu. Settings / Programmes/ Hover over Programme Tuning and pres 5times 1 (1,1,1,1,1) . Right arrow to highlight and select HDMI Mode and you can check some stuff.
I noticed some games doing this, they're defaulting to the max resolution supported by your display because they think that's what you'd obviously want. I used Custom Resolution Utility to delete 4096x2160 out of the EDID, problem solved.Thank you. This has confirmed a problem I am having. When in the nVidia Control Panel I select (under PC resolutions) the 3840x2160 option and 120Hz (8bpp, 32bit, full/rgb) the PC is sending out a 4096x2160 active signal that the display is scaling. Hence I am getting some narrow black vertical bars on the sides. I am now running a high quality cable (signaling issues have disappeared) so I'm not sure what's going on. Under the Ultra HD/HD/SD section, selecting the 3840x2160 (native) option @ 60Hz sends the proper signal.
In either case I am not seeing the display detected as GSync compatible. GPU is a RTX 3080. Any ideas?
Thank you - that did the trick! That is a tricky one I may not have caught - appreciate the tip. Now to figure out why GSync doesn't show as active...Set nvidia scaling options to "display" and not "GPU", this is some recent nvidia bug I've noticed with Ampere (but not with my Pascal card). I don't know why LG insists on having that fake 4096x2160 res in their EDID though.
for gsync you can also check if its enabled for display via another secret menu, just repately press green button and VRR info menu will apear. If there is VRR gsync is enable if fixed its not.Thank you - that did the trick! That is a tricky one I may not have caught - appreciate the tip. Now to figure out why GSync doesn't show as active...
HDMI diagnostic screen can be accessed by going to Programmes -> highlight Programme Tuning & Settings -> Hit 1,1,1,1,1,1 on your remote. Then press right to highlight HDMI mode and click that to open the info you are looking for.Is there a connection information screen I can access via the display? I'd like to know what the display sees in terms of resolution, refresh rate, color depth, etc. as a sanity check against what Windows tells me (old habit) and every display I've ever owned had some way to display this. I haven't been able to find it in the Settings function of the CX48.
Latest Nvidia 457 based drivers seem to have some problems with color space when 120 Hz is in use. I have to use an older 456.71 driver to get working DSC support on my Club3D adapter. If I use a newer one it will only support 4K 120 Hz 4:2:0 as if I was using a HDMI 2.0 cable.Is there any bug with PC resolution? no mather what PC resolution I choose desktop change but TV is still reporting 3840x2160p RGB 10b, if I choose some TV resolution it change correctly. Scaling set to "display".
My understanding is that HDMI 2.0 does not support DSC at least in its spec. It is a HDMI 2.1 feature. I suppose in theory it could be backported but it would require the TV to support it and I don't think Nvidia or LG has any interest in supporting out of spec features. At best DSC could allow 4K 120 Hz 12 bit color for CX series but that is also a pretty pointless endeavour to implement when the panel is 10-bit.According to LTT's video, LG is planning an update with DSC for the 8K OLEDs. Those models have two 48 Gbps ports as well. Maybe the 4K models will get the DSC update too. I wonder if HDMI 2.0 GPUs can use DSC since they have the capability for DisplayPort, though it's only part of the HDMI 2.1 specification. If so, it would allow 4K 120 Hz at higher than 8-bit 4:2:0 on HDMI 2.0.
Seems to be a TV or NVIDIA bug since it occurs in the UEFI as well. It happens once in a while on my RTX 3090. It did not happen with a direct connection from my RTX 2080 Ti to the CX with older firmware.I'm having a minor issue where when I boot PC, tv won't recognize PC HDMI input, says no signal. Most times I have to turn TV off then on again and windows login screen will appear. Am I not giving ti enough time or is there a TV/Windows/Bios setting I need to adjust?
Hmmm, so just need to be patient with a driver/firmware update? I have a 3090 as well, Asus Strix OC.Seems to be a TV or NVIDIA bug since it occurs in the UEFI as well. It happens once in a while on my RTX 3090. It did not happen with a direct connection from my RTX 2080 Ti to the CX with older firmware.
