elvn
- May 5, 2006
I suspect AMD cards will work just fine as there are no bad reports on XSX or PS5. I really hope I'm not wrong here..
You'd have to make sure the console was outputting full 4k 4:4:4 chroma and be running rates at 100fpsHz to 120fps Hz the whole time to make an apples to apples comparison. Consoles typically use dynamic resolution ~ downscaling and checkboarding tricks to fake 4k, especially when the action and FX are firing or during long view distances where the frame rate would otherwise drop considerably. While the new generation has 120hz capability it will almost certainly continue to rely on these tricks. Even during periods where the games aren't dynamically lowering the resolution the more demanding games still might not be hitting 100fpsHz to 120fpsHz 444 4k which is where the LG CX's VRR stutters on the nvidia 3000 series (and perhaps from all 120hz 4k 10bit 444 hdmi 2.1 output sources at those rates as far as we know currently since the 3000 series is the only one capable of outputting it atm).
