0ptional
Don't Trust Your Friends with Your Decanter
- Feb 22, 2003
Ran 3 hard mode raids today... so worn out...
But if we use 343 we might get a more than half baked game like broken saves and zero working multiplayer!![]()
At least we know 343 will actually fix the problems. They have to otherwise its tarnishing the franchise. Bungie can simply throw its own shit around with little care , they've got a locked contract for a decade.
I think 343 will iron out Halo : MCC and it will be put on sale and people will jump right in. Meanwhile Destiny will have its new 3 missions for SP and a raid and one instance for dungeon runs to hold it over until Fall of next year (rumored).
I am inclined to give 343 a pass on the whole MCC thing as they only developed one of the games yet are charged with making all 4 play nicely. I don't know enough of the technical details to being to judge just how much of a challenge that is.
on topic, anyone know what todays update will be about, there is nothing on their webpage about it, other than it will be happening
1.1 : The one about Exotics. And the Raid!
Today's patch includes the long-awaited arrival of Exotics weapon buffs, additional acquisition paths for destination upgrade materials, along with additional changes to exotic gear node upgrading in preparation for the soon-to-be-released expansion, The Dark Below. We're also correcting issues induced by our more recent update to the Raid.
Weapons
Exotics
Exotic Weapons are designed to look, feel, and sound overpowered. At the same time, they are not supposed to break the balance of the game. We hope these weapons challenge the way players think about their loadouts. Exotics will be a constant work in-progress!
General
In preparation for the Dark Below, Exotic Armor and Weapons no longer require Ascendant Materials to upgrade
The final upgrade node of all Exotic Gear will require an Exotic Shard
Exotic Shards can be obtained by one of the following means:
Dismantling unwanted Exotics
Purchased from Xur for 7 Strange Coins
Exotics now start at a higher base Attack value and have a narrowed upgrade range to compensate
Thorn
Projectiles now briefly highlight targets on impact
Mark of the Devourer DoT (damage-over-time) upgrade increased against PvE enemy targets
Reload Speed increased
Magazine Size increased
Ammo inventory size increased
Stability and Weapon Handling increased
Bad Juju
Magazine Size increased to 8 bursts (was 5)
String of Curses now also decreases the cooldown of your Super on kill
Adjusted effects to not block first person reticle
Hard Light
Stability increased
Perfect Balance upgrade replaced by Fitted Stock (increases maximum possible weapon Stability)
Suros Regime
Lowered total damage at the end of the mag on SUROS Regime upgrade to be more in line with the Glass Half Full perk on Legendary Auto Rifles
Monte Carlo
Stability increased
Range slightly decreased
Monte Carlo Method upgrade now also has a chance to fully charge melee ability on kill
MIDA Multi-Tool
MIDA rounds now have increased knockback against targets in both PvE and PvP
Hawkmoon
Send It upgrade (which was redundant) replaced by Speed Reload
Red Death
Rate of Fire increased slightly, but Burst Damage reduced to compensate
Plan C
Weapon Handling speed increased
Player Speed increased while Plan C is in hand
Pocket Infinity
Speed Reload upgrade replaced by Extended Clip which allows the option to increase magazine size (5 bursts)
Vex Mythoclast
Attack Power increased to 323 (from 300)
Base Damage increased, fixing bug we introduced in previous patch
Enhanced Battery upgrade by Extended Mag (this change still allows for a significant upgrade to Magazine Size, but less than before)
Invective
Reload Speed increased significantly, auto fires slightly slower
Ice Breaker
Send It upgrade replaced by Lightweight (which was redundant as Icebreaker already had maximum range)
New effects for enemies killed by Ice Breaker upgrade
Patience and Time
Snapshot upgrade replaced by Custom Optics (provides a lower zoom option)
Super Good Advice
Stability increased
Truth
Magazine Size increased to 3 (was 1)
Activities
Raid
Fixed an issue we introduced in a previous patch, in which Atheon did not correctly send 3 players through the time gates
Fixed an exploit where the Templar could be forced off its platform
Daily Heroic Story
Destination Materials now drop from completing the Daily Heroic
Bounties
Removed the ‘Relic Hunter’ Bounty
Destination Materials now drop from completing the Daily Patrol Bounty
Vendors
Reduced Cryptarch reputation gain from Engrams, but reputation reward packages now have an increased chance for Legendary Engrams
Players will now be able to use Vanguard Marks and Crucible Marks to purchase Spinmetal, Relic Iron, Spirit Bloom, and Helium Filaments from the Vanguard and Crucible Quartermasters in the Tower
Xur now sells a new material, Exotic Shards, to upgrade the final node of Exotics for 7 Strange Coins
Faction Class Items (ex: FWC Cloak, Dead Orbit Mark, etc.) are now replaced by Faction Emblems in the rank-up reward packages from Faction Vendors
Technical
Networking fixes, which should reduce the instance of the Bee family of KTOs
Fixed an issue in which using Xbox One party chat induced a slower frame rate
What is pissing you off exactly? Trading up exotics so they scale with you, a more fleshed out storyline, and more content to raid? How is that a bad thing?
People I know still say Halo MCC is broken. At least Bungie can do multiplayer right. I've lost all faith in 343 for such a lackluster launch and glad I got a refund. The same with drive club developers, just dead in the water. Not going to give a developer a free pass if the game is more known for its multiplayer and its broken.
It is still in grave need of patching but I was able to play SP without issues.
343 and the Driveclub developer couldn't be farther apart in their approaches to fixing their games though. Driveclub will forever be broken as they will have to move along to whatever is next. 343 has the "stain" of their launch until its brought into proper form because its a headlining franchise unlike Driveclub.
Destiny in my mind is even worse than broke because Bungie refuses to see how its lacking in content and in greater need of a stronger story line are serious issues. Bungie had to be "told" that chat functionality was important for team work based gaming as well which is just straight up lame. Destiny won't ever be "fixed" frankly since its an MMO (well a poor mans version) and they are prone to being treated poorly. At least Halo : MCC will eventually be fixed into the state it should have launched.
Both are ultimately excuses though , neither should have been launched in their broken states. A game doesn't have to be broken in terms of its access to be considered "broken" to begin with. I had little to no connection issues with Destiny but I do feel regret for buying the $89 version with DLC that I won't ever play. Something I won't do again even for such a well respected developer.
on the verge of getting this. Worth the full price? as a pc gamer, will i be disappointed? I usually buy console games when they have no pc counterpart, but i tend to go for fps games on pc. Recently got a ps4 with the gta5/last of us bundle and they are both good games (i had them on ps3 already but dont mind re-playing them on ps4 with the better resolution).
I really need to find some PS4 friends to do strikes with. I dont know anyone really on PS4. Anyone that wants to run with a 36 year old professional/family guy to help level up from 25 to thirty PM me or add me on PSN, nickname is 'ftard'
hell I thought they had done a decent job of extending love out to those who hadn't bought the dlc. everyone is getting the updated exotics for example.
Also... since I'm not home to check it out myself.. only the new level 26 strike playlist provides engrams for completion. What the hell? (Again, I own the expansion pass). That's just plain stupid.
By them increasing levels of difficulty for dailies and weeklies/nightfalls to level 30 from 28 and not increasing bonus rewards.. this is just another way for Bungie to limit progress.
That is just plain dumb, IMO.
When I discovered this (and after hundreds of hours of playing on a daily basis) Destiny finally clicked for me. It has all the trappings of the most abusive, microtransaction laden mobile game: time gated content, infuriatingly random drops, and multiple currencies that change in importance on a whim. No matter how enjoyable the shooting and jetpack-fueled bouncing, it's that slow drip of gear and the promise of a new level I'll probably never reach that's kept me addicted this long. The only difference is, instead of microtransactions, Destiny has The Dark Below—a $20 promise of a new level 30 that I'll probably never reach.
Has anybody with the game on Xbox one had it refuse to launch and had to reinstall it? Had to do this on my sons Xbox one twice in a week now thank god I have 100mb internet and no cap. Haven't had this happen on my Xbox one. Ever other game no issues.
