You guys probably have already done it but any time you see quirks like that? Re-verify your files. It's the first, easiest debug step.
I've put in a solid 3-4 hours over the weekend and have had no crashes after swapping things to FXAA and HDAO. Could just be pure luck (or even the newest Nvidia driver) but I'm gonna stick with this just in case SMAA and or 3D SSAO = what's causing the issue.
I copied my destiny 2 folder to my laptop and I managed to play on that for 1.5-2 hours without crashing so the files seem to be ok (also I did do the verify thing, and the run as admin someone else suggested, none of that helped)
It's a pain to play an FPS shooter on a laptop though.
I don't have nearly enough time to play to keep turning in crap for the random drop. But this gun is just retarded, .4 second ttk and all you have to do is hit the target not even try for the head.
It’s a bug acknowledged by Bungie. There will be a hotfix on Tuesday. Instead of letting the weekend ride out with a select few players having a major advantage, Bungie made the gun available to everyone through xur. The bug should have never made it through their QC but at least they leveled the playing field for the weekend. I like the way they handled it.
It works.
I barely go to Crucible but I did today just to prove the point to myself:
Many if not most players were using it including myself and guess what? It still came back to skill. I still sucked, for example.
There's a negation effect. I went away from that far less concerned vs going into it.
Do you know what the hotfix is supposed to do exactly?
Fix whatever is causing that gun to have a 0.4 second ttk.
they are slamming the hell out of destiny 2 and the DLC model....
I divorced this game a month ago good looking game just no staying power. I mean you like shooting the crap out of stuff on a screen it's ok then it gets old fast. Matchmaking is less than ideal for whatever I just don't care about it anymore.
I'm not sure why the "new material" in this could not simply have been released as a deluxe expansion to the first game with the fanfare of a soft reboot because the "full game" would be brought out on the PC as we know it.
I got my warlock and hunter to 20 and I just kind of stopped playing, I have the season pass but I have zero motivation to actually login and play the game.
Wasn't there some noise about Bungie being contracted to make a total of 4 Destiny games for Activision? If so they definitely wouldn't want to keep expanding the first one any longer than necessary.
I never played D1, so this expansion was my first indication of just how Bungie intend to develop the game. And my impression is that they're going to do the minimum they can get away with (including testing, apparently).
We won't have to wait too long for Destiny 3... because it will be known as Anthem.(Yeah, I went there.)
is Anthem a looter shooter type of game?
To be fair: No one knows for sure yet but the way the concept has been outlined and that mock CGI footage that was shown at E3 suggested something somewhat similar.
Looks like some D2 update just came through. I bet that's adios to Prometheus Lens.![]()
Whatever clan the game defaulted me with hasn't been online in weeks (if ever), so I just signed up for the [H] clan. Hopefully we can help one another out.
What is this [H] Clan you speak of? Can I find it on Bungie.net? I did find one clan called Hard - but it's a PSN clan.
Also, I'm now power/gear lvl 309 on my Titan - is that good enough to raid with?
That leaves 3D SSAO as a possibility. I swapped back to HDAO to see if that helps.
Welp, it isn't MSAA causing the crashing. After several hours of no issues I had 2 almost back to back crashes today, both using FXAA. Both were triggered by the public events. The first was the glimmer drill one where the drill has an area-of-effect damage phase with a dome. The second was the Taken blight which (again) has an area of effect you have to enter in order to damage enemies.
In both instances, there's a ton of crap going on and a dome you have to enter/exit. Thinking about my other crashes, those events were going on for several of them. Nightstalker grenades seem to be another.
I'm somewhat confident this might be your issue if my reading on it is correct: That 3D setting is for people that have 3DTVs. (Again, someone feel free to correct me if I'm wrong. That's the best data gathering I was able to do on it. )
I hope this is it.![]()
no it's just a higher quality SSAO. see here: https://www.geforce.com/whats-new/g...uide#destiny-2-screen-space-ambient-occlusion
