Chiller's Hybrid Level 10
Discussion in 'Worklogs' started by Chillernr1, Aug 31, 2010.
  1. Rossi~
    Rossi~ 2[H]4U
    3,479
    Dec 8, 2008
    It is indeed.
    Now hurry up and get it up and running and post the overclocks and temperatures :D
  2. Chillernr1
    Chillernr1 Limp Gawd
    165
    Dec 6, 2009
    Total overview of the case how he's now.
    Most of the cables are on/in it : audio, usb, powerswitch, hdd led, power led, reset, reset led, debug lcd, 2 sata, all atx and pci kabels.
    Evga PSU is also on his place together with the dual bay psu in front :
    [​IMG]
    overview of mobo with all cables on it :
    [​IMG]
    Also i have made a cable for the EVbot connection in the mobo IO-Shield, so the connection will be in the front plate, where it's easier to acces to hook up the EVbot :
    [​IMG]
    [​IMG]
    Total overview of the current cables in the case lols,
    but they are not all the cables yet, and need also some controllers to put there
    (coolit, koolance, poweruse) :
    [​IMG]
  3. Chillernr1
    165
    Dec 6, 2009
    New Armaflex lasercutted is in, and fits the SR-2 with waterblock perfectly :
    [​IMG]
    [​IMG]
  4. Chillernr1
    165
    Dec 6, 2009
    Here are some pics with all coolers on there place, now you see also why i make the 90° connectors on the mobo :
    [​IMG]
    [​IMG]
    Here you see, with fittings and all, i calculated just enough space for cpu block etc :
    [​IMG]
    and this is why i made those 90° connectors, so maximum on cable management :
    [​IMG]
  5. Chillernr1
    165
    Dec 6, 2009
    next layer of armaflex :
    [​IMG]
    Cut-out for the waterblock :
    [​IMG]
    [​IMG]
    And also soldering some SMD-led's for in the case,
    when you solder these smd-led's be shure you use Kynar whire, THE wire for working with SMD's :
    [​IMG]
    And putting the smd-led's on place with double component epoxy :
    [​IMG]
    Just like i put 320 smd-led's in previous casemod : Chiller's Evga Monsta :
    [​IMG]
    [​IMG]
  6. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
    Nice case, awful monitor
    Just kidding :D Build looks great so far. Some serious details that you've covered.
  7. Chillernr1
    165
    Dec 6, 2009
    that's a real old monitor, now i have here a 28" full HD and a 25" samsung
  8. Chillernr1
    165
    Dec 6, 2009
  9. Chillernr1
    165
    Dec 6, 2009
  10. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
    That is freaking awesome.
  11. Chillernr1
    165
    Dec 6, 2009
    I cut up an Evga ECP Panel for building it in the front of my case.
    little soldering, and i will have a EVbot connecting in front, a DEBUG lcd, Clear CMOS switch and switches for disable PciE and cpu's.
    This will be build in a Lian-Li slim-drive Bracket where together with a slot-in dvd drive also can go two SSD harddrives in it :
    i cut the ECP Panel up because you see always mods with just the ECP Panel screwed in the case, now i change this to my own taste.
    [​IMG]
    Here is the Lain-Li slim dvd drive bracket,
    (bought in usa)
    Here you see how i build in all the different switches, lcd en connectors, these will come behind a grey smoke acryl plate :
    [​IMG]
    Clear CMOS with his tiny hole :
    [​IMG]
    Total overview of the case :
    [​IMG]
    [​IMG]
    [​IMG]
    In the case it's still dark, but also on the graphics cards will come nice mods etc......:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  12. psychowes
    psychowes [H]Lite
    83
    May 10, 2007
  13. Chillernr1
    165
    Dec 6, 2009
    thanks, more pics will come this weekend, when i work on the lian-li bracket
  14. Nickbaldwin86
    Nickbaldwin86 2[H]4U
    2,135
    Nov 8, 2009
  15. Chillernr1
    165
    Dec 6, 2009
    thanks, busy on the front plate now
  16. wra18th
    wra18th [H]ardness Supreme
    7,776
    Nov 11, 2009
    OMFG!! That's turning into an insane work of art!!!
  17. Chillernr1
    165
    Dec 6, 2009
    little update for tonight,
    the Evga ECP Panel of Classified mobo's, i cut it in pieces,
    [​IMG]
    And this is what i did with those pieces, i only whanted to use the Clear CMOS button and the debug lcd,
    also i enlarged the connectors in the IO-Shield of the Evga EVbot to the front plate for easy acces.
    There still needs to come a slim dvd drive slot-in and a grey smoke front plate :
    [​IMG]
    [​IMG]
  18. Chillernr1
    165
    Dec 6, 2009
    habe taken the front panel connector of my old intel skulltrail mobo (dremel in mobo)
    [​IMG]
    And used this connector in my slim drive bay of lian-li, together with the ECP panel i cutted up,
    so that i can hoop up the ECP panel cable of mobo in my dvd drive,and from here everything will be splitted to debug lcd, power and reset switches and cpu/PciE disabled switches
    [​IMG]
    and hhere you see it, connector for ECP panel connector that comes from mobo, and connector for power and reset switches :
    [​IMG]
    also the halve of the cables is managed, have some more cables to do and connectors to solder.
    Have also the Koolanc TMS-200 controller build-in the case and hooked up the first cables and sensors
  19. vsboxerboy
    vsboxerboy 2[H]4U
    3,662
    Oct 17, 2005
    In terms of pics vs real life, is it easier to see through the plexi cause it's a shame to cover up so much of that detail work by having it so hard to see through!
  20. Chillernr1
    165
    Dec 6, 2009
    when there is coming smd-led light in it, it will be visible very good.
    off course the two coolers inside will cover up some sight.
    for modding contest i just put open the mobo cover and take pics
  21. fullvietFX
    fullvietFX [H]ard|Gawd
    1,788
    Sep 1, 2004
    WOW. Awesome computer, crappy camera! Loving it though!
    EDIT: How loud is this thing going to be?
  22. Chillernr1
    165
    Dec 6, 2009
    loud ? absolutly not loud lol
    got a new camera 12MP, hope to shoot better pics with this one
  23. Chillernr1
    165
    Dec 6, 2009
    little update :
    i'm still waiting on some small packages to arrive:
    Sata slim line dvd RW drive :
    [​IMG]
    Sata slim drive adapter to normal sata :
    [​IMG]
    adapter on it screwed :
    [​IMG]
    red smd-led strips for some light inside the case :
    [​IMG]
    3x Nexus air-beamers for 80/92mm fans, also here comes a nice mod with in the case,
    also some 3mm led's , 1 for the freezone V1 cooler, the other one is for in SB of Mobo full cover block instead of the stock blue led's :
    [​IMG]
  24. Chillernr1
    165
    Dec 6, 2009
    As you can see in 1 drive bay in my rig can hold more then 1 item , is multi functional :
    Debug lcd
    clear cmos
    EVbot connector
    disable cpu's/PciE's
    HDD for extra space
    and dvd drive itself
    [​IMG]
  25. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
    Brilliant idea.
  26. Rossi~
    Rossi~ 2[H]4U
    3,479
    Dec 8, 2008
    I concur
  27. Chillernr1
    165
    Dec 6, 2009
  28. Almighty ODST
    Almighty ODST Gawd
    644
    Sep 24, 2010
    Everything looks great so far. My only comment would be to maybe look in to light diffusers for the LEDs. I think it would look much better to have the entirety of the red strips glowing, instead of having a mild glow and readily apparent LEDs under the red plastic.
  29. Chillernr1
    165
    Dec 6, 2009
  30. Chillernr1
    165
    Dec 6, 2009
    little update, received my prize today, pics will say enough :
    [​IMG]
    [​IMG]
  31. Chillernr1
    165
    Dec 6, 2009
    got new bolts in red alu, and switchen for disable pciE and cpu's
    [​IMG]
  32. Chillernr1
    165
    Dec 6, 2009
    2 new cpu-blocks are on their way :
    [​IMG]
    [​IMG]
  33. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
    Those are some sexy waterblocks.
  34. Chillernr1
    165
    Dec 6, 2009
    indeed, EK supreme cools as the best, and then also with an Classified look on it. some Red led's in the block and there's show and shine
  35. danmoody
    danmoody Limp Gawd
    330
    Sep 21, 2004
    looking good. all of ek's water cooling stuff looks awsome
  36. fullvietFX
    1,788
    Sep 1, 2004
    How does the Vantage compare to say a H70?
  37. Chillernr1
    165
    Dec 6, 2009
    with google you find reviews they test the ALC against the H70.
    i don't use this cooler, but it seems that it doesn't cool so bad.
  38. Chillernr1
    165
    Dec 6, 2009
    little update :
    i still needed a fan grill, but stock grills i didn't like :
    [​IMG]
    so i did this with an airguard grill :
    [​IMG]
    [​IMG]
    [​IMG]
  39. Chillernr1
    165
    Dec 6, 2009
    i whanted first the disable PciE and cpu switchen what are jumpers on the evga ECP Panel in the front panel.
    But i changed my mind, so nobody can fidle with them, i put them on the back of the dvd drive next to the connector of it.
    [​IMG]
