Chiller's Hybrid Level 10
Discussion in 'Worklogs' started by Chillernr1, Aug 31, 2010.
  1. Chillernr1
    Chillernr1 Limp Gawd
    165
    Dec 6, 2009
    drive bay is ready, now with the PciE and Cpu switchen on it.
    ready to build in and make the front plate of grey smoke :
    [​IMG]
  2. Chillernr1
    165
    Dec 6, 2009
    drive bay is finished, now only makinjg the front plate, grey smoke acryl,
    here you see the connectors for power power led reset and reset switch
    cpu and pciE disable, ecp connector to mobo,
    and in front the Evga EVbot connector, debug lcd and clear Cmos switch :
    [​IMG]
    [​IMG]
  3. Chillernr1
    165
    Dec 6, 2009
    Busy on the clean front plate of grey smoke acryl.
    Now made the EVbot connector in place,
    only the dvd cut-out and clear CMos and offcourse the drive bay PSU needs some fresh air to.
    The outside needs to be finished at the end :
    [​IMG]
    [​IMG]
  4. Chillernr1
    165
    Dec 6, 2009
    little update, pics say enough i think :
    [​IMG]
    [​IMG]
  5. Burticus
    Burticus [H]ardness Supreme
    4,122
    Nov 7, 2005
    Looks sweet. Reeks of effort.
  6. Chillernr1
    165
    Dec 6, 2009
  7. Chillernr1
    165
    Dec 6, 2009
  8. Burticus
    4,122
    Nov 7, 2005
  9. Crispy002
    Crispy002 [H]ard|Gawd
    1,352
    Sep 3, 2008
    I have as well. Something this good deserves commendation.
  10. computergeek485
    computergeek485 2[H]4U
    2,158
    Jun 20, 2008
  11. Chillernr1
    165
    Dec 6, 2009
    thanks guys, tell it to your friends , the more votes i get, the more points i will have in total
  12. wra18th
    wra18th [H]ardness Supreme
    7,776
    Nov 11, 2009
  13. Chillernr1
    165
    Dec 6, 2009
  14. Chillernr1
    165
    Dec 6, 2009
    here a little update of my front plate, only need to find a nice grid to put in there so it comes nice untill the front :
    [​IMG]
  15. Chillernr1
    165
    Dec 6, 2009
    second pump is added and on his place, thirth pump will come under the new bodem in the case :
    [​IMG]
    [​IMG]
  16. Chillernr1
    165
    Dec 6, 2009
    i made my eject button for the dvd drive in red acryl with a red SMD-Led 0805 behind it.
    I can switch easy between hdd activity led or Power led :
    [​IMG]
    [​IMG]
    [​IMG]
    Kynar wire for SMD, small wire with a very small hole under the drive :
    [​IMG]
  17. Chillernr1
    165
    Dec 6, 2009
  18. Chillernr1
    165
    Dec 6, 2009
    Little update,
    tomorrow big works on rig :
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  19. computergeek485
    2,158
    Jun 20, 2008
    how many hours do you think you've put into this so far?
  20. Chillernr1
    165
    Dec 6, 2009
    a lot of time, didn't keep it up how much...............
  21. Chillernr1
    165
    Dec 6, 2009
    little update :
    Coolingpaste is used : Liquid Ultra,
    temp sensor by every cpu,
    Adjust the mounting with red smoke acryl voor more pressure on armaflex and for visual effects,
    start to cut also some tubing Norprene on size,
    only waiting for next orders to arrive of tube clamps, 3mm red led's, and some more stuff.
    The first triple kit memory is also ordered : Corsair Dominator GT 12Gb triple kit 2000Mhz CL9,
    where there will come 4 kits on the mobo of these.
    enjoy the pics :
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  22. Chillernr1
    165
    Dec 6, 2009
    here some show pics,the effect of the custom mounting is now nice visible,
    while i'm busy with all the cable management :
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  23. DarkStarr
    DarkStarr Limp Gawd
    267
    Oct 25, 2010
    Wow, that looks so SICK. Awesome job!
  24. Chillernr1
    165
    Dec 6, 2009
    small update:
    tubing is almost ready just need 3th pump, a koolance PMP-400 with acetal top,
    and building a drainvavle beneath.
    then it's all ready just need memory dom GT 2000Mhz 12gb Triple kits.
    enjoy the pics because it's closing up this build, just few mods and it's ready :
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  25. mofo2136
    mofo2136 [H]Lite
    73
    Nov 25, 2009
    Beautiful mod, great video too!
  26. H@RD5
    H@RD5 Gawd
    689
    Sep 12, 2010
  27. Chillernr1
    165
    Dec 6, 2009
    thanks guys, more updating will come
  28. H@RD5
    H@RD5 Gawd
    689
    Sep 12, 2010
    Thanks keep up the great work.
  29. Chillernr1
    165
    Dec 6, 2009
    little teaser, what am i planning to do ?
    [​IMG]
  30. wra18th
    7,776
    Nov 11, 2009
    I don't know but you better tell us soon before we loose our minds trying to imagine what it is.
  31. Chillernr1
    165
    Dec 6, 2009
    an extra bodem for put under it :
    inline temp sensor,
    flow sensor,
    pump,
    drain valve,
    koolanc TMS-200 controller
    all hidden also for the PciE cables for the vga's
  32. BodoBaas
    BodoBaas n00b
    29
    Jan 5, 2007
    Inlets to suck all of the awesome sauce from other computers near it?
  33. Chillernr1
    165
    Dec 6, 2009
    that's a good one lol
  34. dclprojekt
    dclprojekt Limp Gawd
    252
    Dec 25, 2008
    Great work I love the red acrylic.
  35. Chillernr1
    165
    Dec 6, 2009
    the bottom is as good as finished,
    just need to order a flat pump with top...
    if a Koolanc PMP-400 pump with top is maximum 40mm heigh.
    I can take the bottom out any time it's a tight fit and is on 2 alu plates, nice and steady.
    The usb internal, sata and ECP connector on the mobo is nice clean now.
    This is no metal plate but 4mm not shiny black acryl plate PMMA15
    only needs to get connectors for the PciE powercables for the GPU's :
    [​IMG]
    [​IMG]
    [​IMG]
  36. H@RD5
    H@RD5 Gawd
    689
    Sep 12, 2010
    My god I can't wait to see this finished.
  37. Chillernr1
    165
    Dec 6, 2009
    after the drain valve needs also a exit for the liquid :
    [​IMG]
  38. Namesis
    Namesis [H]Lite
    88
    Jan 12, 2011
    simply staggering
