Chiller's Hybrid Level 10
Discussion in 'Worklogs' started by Chillernr1, Aug 31, 2010.
  1. juanP
    juanP Limp Gawd
    137
    Dec 4, 2010
    amazing as usual
  2. infin@
    infin@ Gawd
    805
    Oct 18, 2006
    Amazing work thus far. Can't wait for the finished product.
  3. Chillernr1
    Chillernr1 Limp Gawd
    165
    Dec 6, 2009
    little update :
    Make the led's for the full cover block on size to the fan connector on mobo what normally the fan is for the NB cooling.
    Next i'm modding the powercables for the vga's :
    [​IMG]
    [​IMG]
  4. ChocoFish
    ChocoFish Limp Gawd
    190
    Oct 21, 2010
  5. Chillernr1
    165
    Dec 6, 2009
    i'm busy on a little mod for the memory, lasered alu, and some handwork, need base and color paint :
    [​IMG]
    [​IMG]
  6. Nickbaldwin86
    Nickbaldwin86 2[H]4U
    2,135
    Nov 8, 2009
  7. ekuest
    ekuest [H]ardness Supreme
    6,091
    Feb 23, 2009
    never seen anyone do that before, fuckin tight!
  8. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
    I assume you're painting those flames the matching red? Pretty cool, can't say I've seen this done before.
  9. Chillernr1
    165
    Dec 6, 2009
  10. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
    That answers my question :D
  11. Zink
    Zink Gawd
    693
    Feb 9, 2010
  12. Caliche
    Caliche Limp Gawd
    356
    Jun 1, 2004
    Very nice modding work! The colors are pretty awesome!
  13. Chillernr1
    165
    Dec 6, 2009
    today had some fun to make some more Dominator GT flames for my memory :
    [​IMG]
  14. Chillernr1
    165
    Dec 6, 2009
  15. badb0y
    badb0y Limp Gawd
    295
    Jan 19, 2011
    Damn that's awesome.
  16. Chillernr1
    165
    Dec 6, 2009
  17. Chillernr1
    165
    Dec 6, 2009
    small update, got at last the snake connector in, so the 3th pump can be fitted and the loop closed,
    ready to fill it up.
    left of the pump you see all kind of cables , that's for the Koolanc TMS-200 controller, all kinds of temp sensors all around the mobo and cpu's.
    [​IMG]
  18. Chillernr1
    165
    Dec 6, 2009
    i'm going to fill up the loop now the 3th pump is installed, own mixture : 25% Ethylene Glycol and 75% PURE water, no demi.
    what you see in the measure cup is the Glycol no color pure 100% glycol :
    [​IMG]
    here my koolanc poor in cup on the ZERN res with a snake connector to make it a little bit eassier to fill :
    [​IMG]
    on the drain valve i putted also a tube in a bus filled with my mixture, where the pump can draw it's liquid from when i put the valve open, to make it a little bit eassier to lol :
    [​IMG]
    [​IMG]
    and here comes the first liquid lol, pumps are now running to get the last micro bubbles out the loop, for now, no leaks found :
    [​IMG]
  19. xDezor
    xDezor Limp Gawd
    441
    Sep 19, 2010
  20. Chillernr1
    165
    Dec 6, 2009
    It's a miracle !!!!
    i get it closed hahahahaha, +200m cable in limited room of 3,5cm lol :
    [​IMG]
    here you see that the plate is a little round, but i put the cable fast fast in to look if i get it closed,
    later on the cable will be nice routed and strapped so that the plate doesn't look round :
    [​IMG]
  21. juanP
    juanP Limp Gawd
    137
    Dec 4, 2010
  22. Chillernr1
    165
    Dec 6, 2009
    last minute adjustment for the vga's :
    [​IMG]
    [​IMG]
  23. Chillernr1
    165
    Dec 6, 2009
  24. Chillernr1
    165
    Dec 6, 2009
    here an update of my temps with OC :
    [​IMG]
  25. Rossi~
    Rossi~ 2[H]4U
    3,479
    Dec 8, 2008
  26. E^vol
    E^vol Limp Gawd
    335
    Feb 2, 2007
    Personally, I don't like the design of the Level 10 case. But this..... OMG!!!! You have my respect sir !!!!
    Simply amazing !!! No other words can describe the effort and attention to detail, not to mention fitting all that hardware into that case. WOW!!!
    Keep up the great work.
  27. Blahman
    Blahman [H]ard|Gawd
    1,323
    Jul 8, 2005
    This build is 100% certified Bats[H]it Insane™.
  28. Chillernr1
    165
    Dec 6, 2009
    thanks, more pics will follow when vga mod is ready
  29. Chillernr1
    165
    Dec 6, 2009
    here are the load temps, cpu temp in Coolit software is not correct, cpu isn't supported by the coolit software.
    As you see idle the coolers run lower power, when stressed the coolers will raise there cooling power, and keep the liquid temp low, under Ambient,
    cpu temp raises a 5 a 6°C from idle to load thanks to temp controlled coolers.
    Temp of liquid is set @ 22°C max, min power of coolers @ 60%, max power @ 100%, real nice settings on these coolers,
    and the coolers don't even run at 100% to keep the temp, for me that's good for lower noise level :
    [​IMG]
  30. Chillernr1
    165
    Dec 6, 2009
    little sneakpeak what i'm doing now :
    Most of the time, people put there powercable for vga like the RED arrows.
    I whant it as clean as possible in this case, en i will do my powercables like the GREEN arrow, straight horizontal with the vga's.
    Vga's seems like they are floating in the air lol, strange sight.
    On later time i can mod also the plastic cap on the vga, make it wider, little bit bigger, so the powercables are IN the plastic cap of the vga cooler, totally NOT visible.
    [​IMG]
    And this is the beginning of this little vga mod :
    [​IMG]
  31. Blahman
    Blahman [H]ard|Gawd
    1,323
    Jul 8, 2005
    Interesting idea, seems it would just move the clutter to the rear of the case though. Also how do you plan on getting the cables to lay flat on the video cards especially near where they protrude out of the connectors on the cards? I actually found some 6-pin right angle extensions on eBay that did the trick for me. They aren't exactly right angle but they do make them a lot easier to work with than normal straight connectors.
    [​IMG]
    Of course you would want them angled the opposite way for going towards the rear of the case. Looking at it again it's probably just a matter of cutting a bit of plastic off the connector and bending the wires sharply.
  32. Chillernr1
    165
    Dec 6, 2009
    Am working now on the last mem flames, did the cables in the backpanel better now, so the back-panel is not round anymore,
    and made some led's for give light to the mem modules :
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  33. Chillernr1
    165
    Dec 6, 2009
    Killer2100 eifinally in the house,
    original cover removed for modding it,
    and here a pic of the killer2100 in operation with two red led's, what fits very good in the theme :
    [​IMG]
  34. Wylee
    Wylee Limp Gawd
    130
    Apr 7, 2011
    Hahahaha, this is damned epic. Keep up the good work.
  35. Chillernr1
    165
    Dec 6, 2009
    soon i hope to give new updates as the new mem, vga's and hdd are in the house.
  36. Chillernr1
    165
    Dec 6, 2009
    Got a new sponsor, he send me already a nice package ;D
    Thanks to Eddy of IT-Service
    [​IMG]
    Nice and good packed, and a triple sli connector also ?
    There is already 1 can of Dr Pepper gone, girlfriend grabbed it !!! :eek:
    [​IMG]
    There was no Triple SLI connector in that box, but nice GOODY's !!!! :p
    [​IMG]
    Directly also cleaned the Pc room, and make the desk clear of any garbage and screws :
    [​IMG]
    The second mem kit of 12Gb 2000Mhz GT's got already new cooling fins of my own creation,
    there are more happy now with the new ones ;) .
    [​IMG]
    the lowest modules have a red led on them for in the dark, but gives by day a different color,
    but you can be shure, they have the same red, also the flashlight extra on it.......
    [​IMG]
  37. mannyman
    mannyman 2[H]4U
    2,854
    Jan 12, 2011
    You have some great ideas. Can't wait till it's done.
  38. Chillernr1
    165
    Dec 6, 2009
    Got a new toy in the house, and tried to make nice pics of that 960Gb monsta and some nice pics in my case :
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  39. computergeek485
    computergeek485 2[H]4U
    2,134
    Jun 20, 2008
    960gb of pure speed, that is sexy
