Chiller's Hybrid Level 10
Chillernr1
This build is made possible by and thanks to
Evga Taiwan
Thermaltake Taiwan
Angelbird Austria
Aquatuning Germany
Xtreme Case Mods Australia
IT-Service Belgium
Cooler Master Benelux
Zetix Belgium
so i will tell something about myself
i'm from belgium, and like to bench, but done a hole year nothing, last year in december i was 49th of the world on hwbot, now
with the big update i dropped to 240th place or so.
so now is it time to get the cpu pot and dewar for ln² out of the dust and get some more points back
first here are some pic of my rig at the moment that needs to be finished first :
and here are some pics like the case is now in progress,
also needs some red led's in it :
Drivebay with a sata cable with red neon :
Boreas chiller :
the Coolit Boreas is finished, now the dual bay psu and the rest of coolers :
De thermaltake dual bay psu is also finished, pianted outside black, and inside silver for putting the light nice out,
only the psu front i need to put back :
painted because it looked like this in gold :
video with how it looks all now
http://www.youtube.com/watch?v=VThbPrN9UPI
psu with the front plate ready :
Koolance TMS-200 with expansion board with connectors from UK :
Koolance TMS-200 with expansion board modding :
I got some connector to short, need to order more
today i customized the 3D fangrill so it fits on my Coolit Boreas Chiller :
This was how it looks standard :
And after the adjustment, who see the difference ???? lol :tong:
And this is how it going to fit in black and red on the Chiller :
MAt Black acryl bended with a heatgun, for detail for the Boreas chiller on the HDD bays.
now waiting to receive the mobo hopefully this week, or at last beginning next week.
Also a nice toy for OC, the Evga EVbot.
The motherboard (hopefully this week)
Mobo SR-2 link info
Nice toy for OC on the mobo :
EVbot link info
Only problem is that the case needs a big adjustment for fitting the mobo in the case,
but it will work how i whant it.
i can also use a backplate likes this, but i will keep the original backplate of mobo, but adjust it :
If you look at the sizes of the Classified ATX mobo (30.5 x 26.4cm) against a SR-2 E-ATX (34.6 x 38cm) :
the case will need some adjustments lol.
looking good so far. pretty different from what i have seen.
How is that Coolit for temps? VS traditional watercooling
much better, there are some pic with testing a Freezone Elite on cpu OC, and the temps are very good
Chiller, wow! Liking the direction you're going with this "Classified" Level 10 build. Seems you are a fan of EVGA as well. That Red EVBot thing looks like a nice toy indeed.
Evga is material what is in the top list on hwbot, world records.
En with the good service Evga supplies, i never change to another.
EVbot is on the fly OC, so during a benchmark you can get higher lol.
Mounting for the Boreas Chiller made, was first the HDD trays.
Now made mat black acryl with behind the mounting plates for the boreas chiller.
And still need to finish it nice off and put holes for the cables of the boreas :
first package is in :
the box :
what's inside ?
(the cd is only for flashing the EVbot to new firmware)
Thanks to :
everu part will be shown when it's used in something :
Let's start with the ZERN res, with will get black screws, smd-led's for lightning, and UV red fittings in it, also a Phobya Overpressure valve :
because i am waiting today for the motherboard arrive,
i am doing a little sleeving, soldering,
because i changed the connectors on the koolanc controller, i also need to change them on everything what will be connected on it.
now i have 1 koolanc flowsensor, atx power and the internal usb done :
I'm not a big fan of the level 10 but it definitely becomes cooler when you add all those modifications to it. How does that EVbot thing work exactly? I'm kinda skeptical that a plug in usb device can help your overclocks? :confused:
The Boreas cooler looks very interesting. What are you using to protect your components from sub-ambient temps and condensation? Also do you think that it will outperform phase change tech?
The temp/fan controller with the daughterboard looks mighty interesting. I'm not sure I have enough power plugs for what I want to do in my system, at least not without resorting to the ugly 3 pin to molex adapters. Maybe I'll add one of those things in addition to my NZXT sentry. Hmmm, something to consider, just where to put it. LOL.
I was considering that very same look fan grill, but I had no idea they were that thick and had the weird corners. They definitely should have already come the way you modded them to be. Nice job on those.
the Evbot for overclocking doesn't use USB but a serperatly connector on your motherboard special for the EVbot.
It speaks directly to where it needs to be to change everything, on vga's it speaks with the volterra chip.
http://kingpincooling.com/forum/showthread.php?t=176
The info of evga you can read here, and also you can see on each mobo where the connectors are, some mobo's is the place different
http://www.evga.com/articles/00521/
The Coolit TEC cooling you can change and control the temps in a software windows, and you can set the liquid temp you whant, and it will run like that.
for benching i will go lower on temps, and for condensation i will isolate everything what is needed.
It will not perform phase-change , but this cooling i am building together is power use vs cooling power , more effecient.
My 3 coolers together use 300w and can cool around 1000w.
More info about the software control :
http://www.hardwarecanucks.com/foru...731-coolit-boreas-mtec-chassis-review-14.html
Mobo is in ta house. And it's big and heavy.
Now fitting in the Thermaltake Level 10 case.
And adjusting the case to the motherboard.
also ordered a 10 PciE IO-Shield of Dangerden :
Enjoy the pics :
very small update, making little adjustments on the fan for a little more airflow.
this is how it looked after i changed the outside :
a first little piece is changed, tomorrow will be more :
and this is what we going to change :
Very neat and interesting setup. Should turn out really nice when you are finished. Keep up the good work!!!
Here's the 3d fan grill in primer with the adjustments for a little more airflow, ready to sand again :
Looking amazing, always enjoy the updates, I hope you have no intentions of moving this PC anywhere as the case alone weighs in the area of 60'ish pounds.
Keep up the great work!
the mounting for the Boreas chiller is ready exept for the holes to put the wires and tubing tru :
fan grill got it first paint job , is get dry now :
and the front plate for the drive bays has a primer :
and first paint job in mat black (just fresh, needs to dry) :
Looking better every day, can't wait to see it when it's done, but even more I can't wait to see the numbers it puts up!
cpu are in ta house !
Sorry, for this but I have to!
it would be in "da" or in "teh" house
that aside +10 for scoring a matched pair! That doesn't even happen at work where we sometimes order 20 CPU's at a time.
Keep up the amazing work!
Also please send me some of that amazing beer you guys horde over there! I will accept any of the following Chimay (I <3 triple & blue label) or for that matter any Trapist brews, I will also take a Saison!
Little update,
Coolit Freezone Elite is ready to and cpu's are on the mobo ,
And here are some pics of the total view :
today i sleeved the cables for the Evga EVP OC Panel V3,
Also the flat ide cable etc
And made a cable to extend the Connector from the motherboard EVbot in the IO-Shield to the front of the pc :
enjoy the pics :
Here you see the difference between the Classified ECP Panel, and the SR-2 ECP Panel V3 :
Extending cable for the EVbot :
Also did some cables of the coolit coolers and the Psu for it, the thermaltake Dual bay 650w psu :
Enough MDPC-X sleeving (few hondred meters) ?
What paint did you use for the fan grill? I am looking at painting my laptop and that color looks great
first primer i couple of layers and sanding bewteen each layer,
after that just a spray-can mat black
