That's a good sign- I'll do a BF4 survey tonight and see how empty the servers are.
DX12 was/is always bad in BF1 as well. Was always a stutter fest on both nvidia/amd from what I recall. Don't know how they haven't fixed it yet.
Still early. My old ass 3770 and 980 rig runs it fine at 1080p. I know it ain't H at 1080p but w/e. I still own. This game at least trys to lean towards gameplay and skill.
No SLI support go figure. Yes running latest drivers that came out today. Complete bs. Frostbite can do sli just fine but obviously it wasn't a priority for Dice.
same here. there's a link to 'upgrade' the game (based on Premier, i believe) but it just gives me an error when i click it. Did you preorder the game in addition to signing up for Access Premier? I did, and i wonder if somehow my Deluxe preorder is superseding my Premier account and that's why it says it's not available until the 14th.
Runs fine in DX11 as expected. DX12 runs just as shitty as every other modern frostbite engine game which makes no sense.
when is this game offocially out?
I running on a different monitor now (1080p @ 144Hz, beta was in a 3440x1440 @ 100Hz) so I can't make a direct comparison.hows fps compared to the beta? how much more or less? playing rotterdam would be ideal.
For anyone still experiencing this issue, the suggested fix in this link worked for me: https://answers.ea.com/t5/Origin-Access/ref-vault-entitlement-failed/td-p/6780991
“Can you clear your origin cache and then try again:
- Completely log out and close down Origin
- Hold down the Windows key and R
- Type in "%ProgramData%" (without quotes) and click OK
- Now open the Origin folder.
- Delete all the files and folders in the Origin folder, except for LocalContent (do not delete this one)
- Type in "%AppData%" (without quotes) and click OK
- This will take you to a Roaming folder, which is located inside of AppData. Delete the Origin folder
- Click on the word "AppData" at the top of your window
- Open the Local folder here
- Delete the Origin folder listed here
- Restart your PC and log back into Origin”
Set the video settings to Custom and make sure that Future Frame Rendering is turned on.Anyone having trouble with the game today?
I played for an hour or two last night and it was flawless. Playing on a Vega 64 at 3840x1600, high settings. Was getting framerates around 55-60, which was perfectly playable with freesync and everything was nice and smooth, I didn't have a single issue. This morning, the game is basically unplayable. Game is studdery from the moment it loads, and once I got into a game I was getting extremely choppy performance, stuttering audio, etc. I also didn't seem to be able to stay connected to a server for more than about 10 minutes. After getting disconnected from several games, I gave up.
The only difference between now and last night was that last night I played in the infantry focused servers to try and get a better feel for the game in smaller matches. This morning I was playing conquest.
I bought a $15 premier for one month to try out BFV. At the very least I wanted to see the new Frostbite engine.
Nope, I did the same thing.I bought the version that unlocks 11/14.
I want to play today.
If I buy premier for $15 for one month just to play early, will EA fuck my shit up and I lose all my games I own already after the month is over?
Does anyone know if there is any need to tweak control panel settings. For example, bumping ansioptropic filter to 16x, turning on Transparency AA, ect? Or is all of that basically baked into the game’s graphics settings amd this at this point?
How does it compared to Battlefield 1
