- Dec 19, 2005
Sucks.
Without knowing what was there, or having a second board as a reference, you can't be sure what component values to put back in those positions. Most of them are caps, but I'm not sure what "FBx" is, possibly fuses?
You can risk going by what caps are nearby for values. You may get lucky and have it work. The worst I've ever had happen was on a video card where the GPU went thermonuclear with the wrong value cap. It was a weird dual head Rage 128 (not a Fury MAXX), one of the SMD caps had broken off from being tossed in a box. I found what I thought was an equivalent cap and soldered it on, the second it was powered up the GPU it was in circuit with got cherry red hot and started boiling with fire and smoke. I shut it off quick and removed the cap, but it was done. Strangely the second Rage 128 still worked and I just used it as normal single chip card.
Looking back now, I think what may have happened is the replacement cap may have been shorted, multi-layer ceramic SMD capacitors are extremely fragile and any minor insult can cause them to fail. If you look at the pics of your board, you can see fragments left of some of the capacitors. You'd have to get new ones for replacing those, putting the old ones back on would probably cause things to blow up.
definitely not going to risk the 6000 in a dodgy motherboard
