Pjalchemist
- Nov 12, 2008
Throttle stop by Uncle Web, but I've heard it doesn't work with this board... or was it the Asrock? You could give it a shot and see.
Doesn't work, have already tried it!
So with the new bios, are there still any major issues with the Zotec Z68? Turbo boost works as expected? Can overclock properly?
Nope, BIOS is very very very limited, speedtest/eist/c1/ce is always active so will alwys drop to 1.6ghz!
that's so garbage.
Does anyone have a good idea of the power draw of this motherboard (Z68ITX-B-E), including the onboard GPU? I'm wondering how much of a power supply it's going to need. I checked the manual for the board, but I couldn't find a recommended minimum power supply.
Ouch. That's not what I wanted to hear.Well the GT 430 has a minimum recomended of 300w (it only uses 49w), which is also what the PSUcalc shows for an i7, 1 HDD and a GT 430 (275w for an i5). If you are overclocking then i'd got for a 400w.
Correct, you'll be cutting it way too close with a 65-watt chip. The 35 would be fine, I suspect your total consumption would be around 120 watts DC in that case.Ouch. That's not what I wanted to hear.
I am looking to build a lower-power setup: something powered by a 150W supply at most; ideally 120W. I won't be overclocking. I was hoping to use this board with a 65W CPU, a mSATA SSD, and a slim ODD. But it sounds like that would be pushing things really close. It might be workable with a 35W CPU.
It will be 3.4ghz any time you use the CPU. It lowers to 1.6 when idle only what's the problem with that?
