that's what i did, gene-z and tj08-e... like you i come from this shitty zotac motherboardI am thinking that i should go to mATX. MAXIMUS-IV-GENE-Z and Arc Mini or define.
Well...this post at the very least
new bios, this time for the a-e version of the board!!
http://www.zotac.com/index.php?option=com_docman&task=doc_download&gid=1347&Itemid=100032
Version 2K110809 (Beta)
Code:.Added intel XMP memory support .Added CPU Vcore control .Added deep S3 control .Modified Turbo Boost mode - CPU Core Ratio / Multiplier
How that differs from any other? Zotac is only cheating people.
No, you failed in buying anythiing Z68 or for Sandybridge as there is sweet fa thats worth while
What do you mean??, anyways I use the Xeon 1230, so no oc party xD, waiting for ivy
currently is the only way if you want to go z68 and take advantages of itGot my Asus Gene-Z mobo and TJ08-E case
Hi,
Now i am happy. Got my Asus Gene-Z mobo and TJ08-E case. Now i have small and powerfull computer what i can overclock. Now i need get somebody buy my Zotac mobo etc.
Asus Gene is very very nice congratulations. You can't retrurn the Zotac?
Wow, that was a long review that has already been summarized in this thread. I'm not sure why the gave the board high points on features found in most other mini-ix boards these days. They also seemed to gloss over the fact that their first sample board burned out (including the CPU) during one of the max overclocking sessions.
any way to disable speedstep so that your OC's hold?
