Pjalchemist
- Nov 12, 2008
I've just noticed the BUZZING so im gonna say no it's made it happen on mine!
i read here that buzzing noise can be fixed by disabling energy efficency option through bios http://forums.itxgamer.com/viewtopic.php?p=574#p574I've just noticed the BUZZING so im gonna say no it's made it happen on mine!
i wrote to zotac about this issue http://www.zotacusa.com/forum/topic/4930-zotac-z68itx-a-e-buzzing-noise/, maybe, since my english is far from perfect, you can help me and write your experience tooI've had that disabled from day one! Buz was never present till BETA BIOS
However rumors of a V2? How do we tell them apart. Response from Zotac is 0
got it from a retailerWhere did you get the board from? A retailer or straight from Zotac?
Either way, let us know how it goes with that one.
[Edit] Just noticed this, but Bit-Tech has posted a review of the board.
i'll let you know when i'm back from vacationi'm eager to see if this "new revision" cures the buzzing issue....
ok so you've a rev 002 and the noise is present, right?I just fitted a different HSF and whilest doing so though i'll have a sneaky look!
5GHz ,1.44V on Stock Intel cooler?.
Anyone seen this
http://www.youtube.com/watch?v=1aq3IQCjR8o
Zotac Z68-ITX WiFi Overclocking 5GHz
I've mesaged asking what settings he use!
Think we should do a different topic of post your Zotac OC and settings?
Is the Z68 chipsett needed for 22nm ivy bridge support?
noise has started again, board sent back for a refund hope to get the asrock soon
Money can buy new parts.
You are changing to Asrock Z68?
1st just use the mutli only.
Leave everything on auto
Get into windows, open cpuz then prime it!
45X should work out the box.
Don't throw away the receipt!
So those watts should be on that 95 or something defaults?
Nope. It's safe.
