Spartan1000
- Nov 24, 2007
Just a heads-up for all the people here who have not yet begun to install Windows 7, or, have begun to install Winodws 7 - Completing the Installation takes A LONG TIME
Somebody look through the source code of the page, and do some tricky geek magic and get us some keys.
Is there a way to remove Vista once im done installing 7? Or do I have to do the process all over again![]()
Ok, I just have to ask: why are you so concerned with the key if:
a) you can install it without one
b) you can use it for 30 days without one
c) you can rearm it for another 30 days, up to roughly 120 days (that's 4 months, yanno) and still not need a key
d) you acquired the ISOs from Microsoft legitimately so you're allowed to install it without a key and use it without one
e) there's no actual reason to use a key save for activation which doesn't mean anything at all really
f) activation incurs no benefits over not using the key to install and use the OS
g) I could go on but you should get the point by now...
SO, what's the deal with the keykeykeygimmeakeythelinksdeadIhavetohaveadamnedkeyNOW things...
I don't get it.
You installed Windows 7 on the same partition as Vista? Or just on the same physical drive on a different partition?
Best answer is... you should always install beta OSes on a clean drive unless you have a specific reason to be testing multiboot/dual boot scenarios.
Setup 3 tabs in firefox refreshing every 1s with check4change addon and got the key in less than 10 minutes.
the second link redirects to the first![]()
Oh, Joe_Average?
I DID need a product key to install it
Now it's just a shame that Virtual PC doesn't seem to support 64-bit OSs.
Uhmmm... no, you don't need a key - but apparently you're simply ignorant of the method to install without the key which is:
At the place in the installation where it asks for a key, you click No, then you click No again, and it continues from there. You can also uncheck the "Activate while online" box and not be hassled with it after the installation.
Simple.
I think I am going to wear my F5 key out trying to get this stupid key...
Most browsers these days will let you right-click on a tab and set it to auto-refresh/reload based on a specified period of time. That's what most of these key leechers are doing now... automating it, harvesting keys...
It's a bit fucking ridiculous, folks, it truly is.
would Window 7 work with P4 Celeron? and DDR1 stuff and AGP?..
