Any patches to fix the stuttering yet? If not, any dev updates on the stuttering issues? Just want to check in each week and hope for the best.
FRAPS is a program which will show you your FPS no matter what game you are playing. It also has other nifty features, like the ability to take screenshots, capture movies, benchmark etc etc.
http://www.fraps.com/
Its a very useful little program, I have it running 24/7 on my PC, so I don't need to bother configuring each and every game to show fps or take screenshots. The free version should be sufficient for you.
can someone help me out a bit?
What are the "tiers"? I always see people talking about tier 1, 2 and 3, but never know what they are talking about.
Also, I know what rvr stands for (realm vs realm), but what's the difference between PVP and RVR?
Ok so am I the only one that does not have an Addons folder in the Interface folder? Dont think that I have the mod from curse installed properly but I have no where for it?
Does anyone know what total sales were for the first week of release? I couldn't find it anywhere.
no fix for the crash to desktop, it happens to me several times a night. Its the only program I amhaving prroblems with. No error just bam it closes itself....
If you press "M" it'll bring up the world map which, if you look closely, is divided into four tiers from left to right. Empire v Chaos would be Norsca/Nordenland representing Tier 1, Ostland/Troll Country representing Tier 2, all the way to Inevitable City/Chaos Wastes/Praag/Reikland being Tier 4.
Dunno about the technical differences between PvP and RvR but I always assumed RvR meant PvP but on a larger scale.
Look on your map and you will see the tiers divided by lines. Teir 1 has 2 zones in it, as does tier 2 and 3. The final tier is made up of several zones and the capital cities.
RvR is just mythics term for it. They focus more on large scale battles. PvP probably means more of a solo player against another. War is not about personal glory but rather a team of players working together.
The world and races are divided up in several ways, first there is 6 races, 3 (Elf, Empire, Dwarf) which are order, and 3 of which are destruction (Dark elf, Chaos, Orc)
The world map is divided into conflicts between these races,
The Elves fight the Dark elves
The Empire fight the Chaos
The Dwarfs fight the Orcs
Each of the 6 races has 4 tiers of progression, each tier is essential one large zone, the first tier is essentially levels 1-10, T2 is 11-20 etc
The paired races zones are connected, so tier 1 for the elves connects straight to the tier 1 for the dark elves, between each T1 zone is an area where those races can fight, this is the open world RvR area where RvR is always enabled, this gives you a battlefront between T1 for all the matched pairs.
You can actually travel to any friendly races tier, so if you're playing empire and you're low level in T1 you can play all the empire quests but also fly to the Dwarf and Elf T1 as well, same for all the Tiers.
Have there been any big patches since the game's release?
I have no memory leak at all. It works its way up to about 1.38gb of ram and then sits there no matter how long I play.
Are you using XP or Vista?
I just installed yesterday and had to download a whopping 210 megs.
If you hare having stuttering problems, try the following (I take no credit, this was taken from another forum):
1. Uninstall your current nVidia display drivers.
2. Install the newest drivers from nVidia's official site (178.13).
3. Go into your nVidia control panel. Make sure you're using the "advanced view."
4. Manage 3D Settings --> Program Settings (it's a tab) --> Add --> Navigate to the WAR.exe file and choose it
5. Turn up AF to 16X, turn up AA to whatever your video card can usually handle.
If you're using a LCD screen, turn vsync on and turn triple buffering on (if you're using a CRT, turn both of these off).
6. Keep the texture filtering quality setting at performance.
Note: If you see some shimmering in-game and you don't like it, turn the texture filtering quality setting to high quality.
7. Set Negative LOD Bias to clamp.
8. Go into your in-game settings.
For moderate/low end GPU, click on balanced. Uncheck lightmaps and specular lighting.
For high end GPU's, keep everything on high quality, but turn off lightmaps and specular lighting, and keep shadows on balanced.
Also download this mod:
http://war.curse.com/downloads/war-addons/details/buffthrottle.aspx
Following these steps should eliminate stuttering issues that are game related. My guild has tested this method on various types of computers and it has worked for all my guildies.
Also, if you are still playing using the beta client install, reinstall the game using the retail disks.
of course it's going to run better... it's telling you to turn lightmaps and specular lightning off and turn shadows to medium. Isn't that going to make it look worse?
