CaptRingold
- Feb 12, 2005
If they're holding out on us so that they can have the supply to backup demand, unlike the video card mfgs, then.. I don't mind, eh, another week.. ![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
CaptRingold said:If they're holding out on us so that they can have the supply to backup demand, unlike the video card mfgs, then.. I don't mind, eh, another week..![]()
dropadrop said:new 90nm FX-55's (San Diego like the new Opterons) should be shipping from the distributor in a week. I don't see venice shipping in lower speed grade processors for another two months though (I could be wrong on venice though).
umbra said:dual core with 1 meg cache each maybe![]()
i'm not certain, but it only makes sense if amd doesn't confuse consumers more by overlapping winchester and venice.dropadrop said:new 90nm FX-55's (San Diego like the new Opterons) should be shipping from the distributor in a week. I don't see venice shipping in lower speed grade processors for another two months though (I could be wrong on venice though).
(cf)Eclipse said:especially if these rumors about a 90nm fx-55 are right (i'm skeptical after looking into it deeply, but one mustn't lose hope now, can they?)
doesn't look like venice will have the thermal drop we hoped for. though it's doing better than the fx-55, the 2.6ghz opteron still has a tdp of 92.6w (though i note it's the only one with that tdp, and 1.4-2.4ghz E cores have a tdp of 85.3w, so i'm guessing 92.6w is good for a few more speed bumps)
(cf)Eclipse said:the sse3 isn't using up that much more power. look at the transition from the fx-53 that has SOI.. rated for 89w. then you have the fx-55. a 8.3% speed bump, but the power goes up to 104 watts, which is a 16.9% power jump. i feel that most of this extra power comes from the strained silicon's higher voltage leakage, not the speed increase (power scales almost linearly with speed)
Decelerate said:Been out of the loop for a bit. That or something new happened that I haven't noticed.
So what's the deal now? The E stepping isn't what we expected? The Winnie remains leader even after the Venice?
Someone should post a summary.
that's what i thought too, but apparently it's not trueHito Bahadur said:I thought the main purpose of the Strained Silicon was to help manage voltage leakage....
(cf)Eclipse said:venice will clock better (~24% according to amd), but at the expense of higher power comsumption... i was silly before and didn't realise that 24% more transistor performance meant higher clocks, not less power draw.
so it seems this way: if you have good cooling, venice will get you higher, but winchester should be good for stock cooling cause it puts out less heat.. but then again, this is conjecture, and we don't know how these things scale with voltage yet.
that's what i thought too, but apparently it's not true![]()
Frallan said:Ok Eclipse once again you have proved yourself to be an optimistUre statment on the arrival of the Venice late Jan to Mid Feb just didn't come true
sadly enough. So we still have dryfires rumor on May and we still have CEBIT
for me Im counting on CEBIT...
(cf)Eclipse said:... i was silly before and didn't realise that 24% more transistor performance meant higher clocks, not less power draw.
