crypt1c.0 said:Just so the huffy who's can say I stayed on Topic, perhaps Venice is for sale... let me check it out.
i pretty much already have... although teh dual cores are gonna be a bit more expensive - i posted prices direct from AMD in the X2 threadFrallan said:It might even be tempting enoug for me to drop the 3700+ idea![]()
solo16 said:http://www.tomshardware.com/hardnews/20050421_121251.html
for what its worth
forgot i saw that like a day ago its nothing new... but still will be nice if new egg gets some
god damnit. that chip does 3.3ghz at less than waht it takes my winchester to do 2.5ghz(cf)Eclipse said:some 3700+ san diego action with chilled water. seems to do 3ghz easily
http://world.altavista.com/babelfish/trurl_pagecontent?url=http%3A%2F%2Fwww.overclocking-masters.com%2Fforum%2Fviewtopic.php%3Fid%3D291&lp=fr_en
Frallan said:Ok now AMD is biting its own tail... B4 they even have Vennice and San Diego out at the retailers they start showing how good the X2 is going to be...
Now Vapo + 4400+ +OC + DFI + Plat Rev. 2 is tempting....
(cf)Eclipse said:remember that it appears to be -30c.. though i dunno how you can do that with waterchilling. i must be reading things wrong.
edit: aha, the temps
OverClocking (Waterchilled -30°)
new if we could just figure out if  is F or C.. or K!![]()
(cf)Eclipse said:carnitine: you have a point. i don't know how much the introduction of dual core parts will lower prices.. but i suspect not too much.
why yes, i have... just didnt think about it.even then, -30C/F would be quite a feat wtih water.cell_491 said:ever heard of antifreeze....
lol...dont worry we all have brain farts every now and then, even a 2/8 mix of water and antifreeze should keep it from freezinglithium726 said:why yes, i have... just didnt think about it
gotcha. the way you worded it implied that the launch of X2 would bring down the price of everything else, not that X2 would be that much more expensive.. both make sense thoughneedmorecarnitine said:I was trying to point out not how much prices will be lowered but how much the difference is
The price difference between a 3700+ and 4400+ will be large so AMD would not be biting its own tail as Frallan described
Vesuvius said:Absolute Zero or 0K is just as crazy as (infinity). It doesn't exist. And at -30C its probably going to be a lot more antifreeze than water, you might as well just be using antifreeze.
it has been done with triple cascade waterchillers running 50/50 mix they get something like -120c coolant temp and -30c die temp anything colder than that you need direct evap (think vapochill but colder cooling a resevoir)Mtnduey said:Anitifreeze could only do so much. If I recall correctly at a 50/50 mixture it can only keep the coolant from freezing down to neg 50 deg C. And when you add the heat of the CPU & Peltier (or whatever method of waterchilling is being done) to the fluid, you simply could not get the water cold enough w/o freezing to maintain a -30deg C CPU temp. Just can't be done. For one I dont think the water would flow quick enough to keep the pump from frying before long. I just dont see how you could possibly maintain a -30 deg C CPU temp with a water chiller, even with the best anti-freeze on the market.
Though it certainly has me wondering.
Don Wong said:I believe there are many areas in space that are at absolute zero
nope...none, at least that we know of. We have not been able to reach absolute zero or found anywhere that is absolute zero that is why absolute zero is just a theory. Also why are we discussing absolute zero? -30c is NOWHERE near absolute zero...absolute zero is approximatly -273c or 0k and at that temperature (actually anywhere near) your cpu wont work infact even light should tecnically stop at absolute zero. Now that i mention that has anyone heard of a bose einstein condensate? it a newly discoverd state of matter (bose einstein condensate>solid>liquid>gas>plasma) anyway to make a boring chemistry discussion quick it slows light down to mear feet per sec pretty impressiveDon Wong said:I believe there are many areas in space that are at absolute zero
1995ish...10 years ago so its sorta new(cf)Eclipse said:just to nitpick, the bose-einstein condensate isn't terribly new.
i love physics.
cell_491 said:well of course the idea isnt new hints the name bose einstein condensate...anyway that shit is mad cool if i remember correctly they got within millionths (or was it billionths) of a degree kelvin from absolute zero
nope your wrong....it was deffinitely billionths http://www.fortunecity.com/emachines/e11/86/bose.htmlashmedai said:I'm not sure if it was quite THAT close, but it was definately a small fraction of a degree away.
However, a big step was when Cornell and Wieman cooled a small sample of atoms down to only a few billionths (0.000,000,001) of a degree above Absolute Zero! That was what they needed to do to see Bose-Einstein condensation.
cell_491 said:nope your wrong....it was deffinitely billionths http://www.fortunecity.com/emachines/e11/86/bose.html
