Thanks - The drive bays can hide alot behind them...RailGunRiz said:Nice wiring job, what case is that?
RailGunRiz said:It's a Thermal Take: Shark
I have a
A8N SLi Premium
2G of OCZ Titanium (Incompatible)
AMD3200+ XP120MM
BFG 6800GT OC
XFI
WDRaptor74G almost got smoked
2 Liteon DVDRw drives
Floppy
500 W Forton Bluestorm PSU
Bassist-X said:How on earth did you manage to get your SATA cables that close anyway if you look at my post I have the same mobo and case with two SATA drives and they are nowhere near the chipset cooler apparatus. In any case I've had the Corsair XMS RAM 2-2-2-5 2x512 sticks and the OCZ 2x1GB 2-3-2-5 and this motherboard doesn't recognize their timings properly at all, in fact it hates CAS latency 2 and defaults it to 2.5 on both sets of sticks. When you say your RAM was incompatible did it just fail to work at all or was it a similar problem? Peace.
Just unplug themmarka87uk said:Hi, I'm just wondering, how easy is it to disable the LED's on the front of the Tsunami? Cheers
Pr3z said:Armor Here...
