Thermite Paste
- Dec 17, 2003
I'll have to say that lag was virtually non-existent yesterday for me at least and we had quite a few peeps online. Even my mine cart was working smoothly (Once I figured out that powered rails work opposite in MC Mania).
Do you think we could give the Elevator mod another go? With the lag gone from the auto carts it may not kick people now.![]()
it includes it but it's not enabled, with no way to protect it spammers and jackasses could have a field day spamming it. Nothing we could do to stop them either since we can't kick them or things like that.
I don't even know what those are... ?
1. Looks like it's SSP only right now.
2. Pokemon can go right to hell.
3. No nurse joy![]()
G1, I need to know if we have an OK to build/use the sand machine that Gooch created.
my opinion is it is ok, since it can only create sand or gravel, and it would remove the need to strip mine deserts and beaches, which kinda ruins parts of the map.
I am against it really. It works by exploiting the fact that the server can't keep up with the rapid block changes. If everyone started doing this the server would bog down to a crawl.G1, I need to know if we have an OK to build/use the sand machine that Gooch created.
Each new update that adds significant changes, we will do the same, expand the boundaries of the town a little more each time. So new content will ALWAYS be added, but it will not take away from those who love area's they already have.
Yeah... I'll have to agree with you there... Should rename the sandpit to stripmine.im also tired to see desolate sandpit and fucked up terrain from strip mining. We need sand ... but its on the surface , not like cobble or dirt.
everything past the current 3k border will be 1.8 so villages will load and new materials will spawn.
Is the current 3k limit the player limit or the actual map edge as I know the player limit is before the map edge?
Also, I'm not sure you're wanting to edit the world, but, what about removing completely empty chunks so they can be regenerated with the world editor?
Sweet, that means I can finally mine that clay that's been staring me in the face forever.Its the player limit not the MAP limit. The map loads an extra 200 units outside of the map edge for "scenery" so that you are not just staring at a water world beyond like in the Alpha test stages.
When we add an extra 3000 units, in reality it adds an extra 3400 total units. the extra 400 would be 200 per side as scenery.
Sweet, that means I can finally mine that clay that's been staring me in the face forever.![]()
every content patch it would get deleted... hardly anyone would want to play on that.
Then the world would be all mine! MUHAHAHAH
No but really, sad Nick is sad.
Is there any possibility of a fresh map once MC is final?
Well for one we will remove all the unfinished/abandoned builds.
All the strip-mined, and blasted terrain will go away.
The world will be uniformly new. Meaning we won't have rings around the world of new content. So we can have above ground ruins, npc villages, rivers, lakes, oceans, and islands, through out the entire world. Not just on the outer boundaries of the world.
And honestly, if once MC Final is out and we still hold onto this world, I will probably just go back to SSP. Not that one player leaving really matters. I just don't see the need to treat this game like an MMO. It's not.
That does sound like A LOT lot of work though... I know I wouldn't want to be the one doing it.I say we just remove all unused/abandoned chunks currently and let everything else re-generate. That way we have a plenty of "new" map and all the creations remain.
Best of both worlds?
That does sound like A LOT lot of work though... I know I wouldn't want to be the one doing it.![]()
